Okay so i self taught myself a lil about lcd tvs today and i go to fix a 37" tv i picked up. i find the bad cap, desolder it and then i couldnt find a 16v1000mf 105c cap anywhere but there is a 16v1500mf 105c cap on a motherboard i dont use anymore and was wondering if that would work just fine?
LG Bad Cap Help
Tags: None
Re: LG Bad Cap Help
It could and probably would if its on the secondary side of the PSU, I have swapped caps on secondaries many times so far with great success. Although you should remember the rule about swapping caps with higher rated ones - never go more then 50%+ capacity and never go with smaller capacity then the original.Guns don't solve problems. I'll take 12
Re: LG Bad Cap Help
second side of the psu being furthur away from the pins that the power connector connect to?Comment
Re: LG Bad Cap Help
I'm not a born-again expert (yet) but yes, generally farther away. You can usually look at the circuit and tell where you switch over from the high voltage to the low voltage. A rectifier is a good indication. If I'm wrong, someone please correct me. I've been out of this game for a long while, but the thread hadn't been answered and I wanted to try to help the guy out.Comment
Re: LG Bad Cap Help
I wish it works fine. I know the trouble of doing this cause I've done it myself, unfortunately did not worked.
Good luck.Comment
Re: LG Bad Cap Help
I ordered a 1000mf 16v cap for it and soldered it to the board, it works now! got a 1800 dollar 37" tv for free basically lolComment
Re: LG Bad Cap Help
not free, you paid 0.4-0.5$ for the cap
)))) Anyway congratz on the free tv, btw is it a quality low esr cap or just any cap you could find?? If it is a low quality cap, chances are you will bi replacing it within weeks/ months...
Re: LG Bad Cap Help
the capacitor actually costed me $1.39 with $7 in shipping and handling but because they screwed up and took so long to get it to me plus charge me $7 for s&h that wasn't supposed to be there i got a $25 coupon from them. And the capacitor is this. http://www.radioshack.com/product/in...uctId=12460839 im not sure if its has a lower esr or if its a normal cap.Comment
Re: LG Bad Cap Help
Ughh... not really good. The capacitors Radioshack sells are not brand name, so you can't tell how good they are.
You should have asked for our advice and buy a good brand capacitor from this site or a reputable store from digikey.com or newark.com - about the same shipping fee and cheaper price.
What you have will obviously work for now, as your tv works, but it's quite possible it will have a small life.Comment
Re: LG Bad Cap Help
Digikey.com sells quality low ESR capacitors and their shipping prices are usually in the $2.75 USD ish range with deliverly in usually 2 to 3 days.
Badcaps.net also has a capacitor store.--- begin sig file ---
--- end sig file ---Comment
by quicknameI'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
I decided to verify that the batteries were... -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
Channel: BIOS Requests ONLY!
Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
by cmlewis89Hi folks,
I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...12 Photos -
Recapping the power supply board for a Samsung 305T monitor, everything is Capxon except 2 Rubycons. I can't find data sheets matching these online, so don't know what ripple numbers, impedence, etc, to look for. There are a few different looking GL series data sheet PDFs, but the listing that matches the capacitance and voltage is a much bigger case size. I've narrowed down selections with lead spacing and case diameter, and what's in stock at Digi-key
1 x Capxon 1000uf35v GL C720(is this a part number or batch number, can't find it anywhere) 105c
1 x Capxon 1000uf35v...-
Channel: General Capacitor Questions & Issues
- Loading...
