IWILL MPX2 - PLEASE - SOLID HELP & ADVICE NEEDED!!!
  • jackthedog
    • Jul 2006
    hi,
    *** little while ago my system BIOS went BOOTBLOCK - I resolved this by flashing.
    please see this thread for history of this + system specs:
    http://forums.2cpu.com/showthread.php?t=72815
    and some more history here:
    http://forums.2cpu.com/showthread.php?t=72051
    *** not too long after resolving BOOTBLOCK, i was in the middle of loading dvfootage onto a drive and my Matrox G550 video card completely crapped out on me - screen was filled with blocks of different colours etc...
    i put in another AGP video card to test and all was well
    *** replaced the test AGP video card with an old Matrox PCI video card, and now my system will not boot up at all (i don't think this has anything to do with the PCI videocard though?): by this i mean the green power light will come on, as will the system harddrive light, as well as all system fans, psu + fans, optical drives, etc..
    BUT I HEAR NO FAMILIAR SINGLE BEEP(NO BEEPS AT ALL IN FACT) AND CERTAINLY NO BIOS POST!!!
    THE FANS JUST SPIN, THE LIGHTS STAY ON, BUT NOTHING HAPPENS - and certainly, the monitor tells me its not receiving a signal.
    ***when my matrox card crapped out on me, i thought my 4 year old ANTEC TRUE550W was the cause, as many others had problems with it, and i had had some other stuff happen prior to that that suggested so (ie., 1 or 2 random restarts and some data loss) - in fact, i was ready to buy a bigger ZIPPY psu, but thought i should at least test my Antec first.
    ***tested my Antec PSU with a multimeter today, and although the system did not post, and so i COULDN'T test it under full load, my PSU 3.3v, 5v, and 12v readings were as follows:
    3.31V
    5.0V
    11.91/11.92V
    also, please know that my multiplier is set to 16 and my FSB is stock @ 133, stock vcore too.
    what's going on here?
    all help and advice greatly appreciated,
    jackthedog
  • gonzo0815
    • Feb 2006
    • 1600
    Re: IWILL MPX2 - PLEASE - SOLID HELP & ADVICE NEEDED!!!
    Well, as on that forum, the Antec postings aren't that very good, i would check the caps in that psu at first. It depends how old that psu is, if it is older than 1 year it could probably som bulging cap. If it is older it is probably shure that the caps on it has left the magic fluid out.
    But keep in mind that this will void warranty, and that there are probably some lethal voltage on it, even unpluged.
    • zlr8r
      Advice on newer EC chip programming eg. MEC5107-LJ BGA
      by zlr8r
      Hey all, was wanting to know what cheapest option is for programming EC chips such as the MEC5107-LJ
      i searched online and found such programmers as the SVOD4, Vertyanov Successor , and the RT809h type but didn’t see this particular BGA EC chips listed? So hoping for some advice here , cheers.
      09-16-2025, 09:54 AM
    • Borse2008
      by Borse2008
      • There’s
      07-15-2025, 04:55 AM
    • Green Probe
      Mosfet Advice
      by Green Probe
      Hi, Im looking to replace some EMP21N03 mosfets on an Alienware motherboard, but I'm having trouble finding a legit supplier. The ones that are available from China have pictures with the engraved logo looking very scratchy and sketchy. Nobody in the US sells them. I'm trying to find a compatible mosfet, but I'm not well versed enough to be confident im making the right choice. Does anyone have a suggestion or advice that could help me find the right mosfet? Thanks!
      05-22-2025, 10:49 AM
    • user234
      Gigabyte Eagle 3060 Ti - Boardview / Advice request please
      by user234
      Recently installed a new motherboard but during the process I seemed to have damaged my Gigabyte Eagle 3060 Ti card.
      My motherboard ROG STRIX B550-A is detecting an issue with the VGA (light ON)
      I have attached 2 photo's of my GPU board, one above and the other is what I believe to be the 5V - as you can see, this has visual damage so looks suspicious to me.
      If I replace this part what are the odds this will resolve the issue? - any additional information on where to source the parts would be much apricated too!
      This is...
      05-10-2025, 04:25 AM
    • artvandalai
      Advice on rewiring this stepup transformer?
      by artvandalai
      I bought this Chinese made step up transformer to run some 220v appliances. Some of the wires were brittle and broke off. I attempted to improve some of the wiring with spade terminals and heatshrink tubing as the wires were just soldered straight to the connectors. Any advice on how to rewire the broken wires on this step up transformer? I'm unsure how to go about rewiring this to a better safe working condition.
      01-14-2025, 01:00 AM
