Empty Solder Hole?? Why?
  • pnutbutters
    • 17
    • usa
    I have a power board for a flatron LG monitor
    One side of the board has a chip that is completely missing solder from the through hole..
    Could this be correct? Or should I fill it with solder and see if that fixes the issue..
  • t.j.
    • Apr 2010
    • 383
    • canada
    Re: Empty Solder Hole?? Why?
    so there a chip/cap there an no solder on one leg? if yup! i would think that would be a bad contact point an would solder it! or with unit run it! use piece of plastic an put pressure on it an see if makes difference!
    • pnutbutters
      • 17
      • usa
      I think it's actually a chip, probably a power regulating chip of some sort. but any component that has a leg coming through the board should have solder to fill it yeah?
      • crtfool
        • Jun 2010
        • 82
        Do not solder that leg if it never had solder! I have seen this many many times - it is a function of the chip that is not used in that installation, and soldering it may do nothing......but, it could do a lot of damage!
        • mariushm
          • May 2011
          • 3799
          Some power regulators have a pin that's an optional function (adjustment of voltage output) - by default the chip converts any voltage to a value preset in the chip like 5v or 3.3v but if there's a resistor connected to that optional pin, the chip will output a value different than the default, like 2.8v for example.
          On other chips, that pin is connected to the metalic pad that's usually connected to a heatsink. The monitor manufacturer may purchase chips that perform a certain function from various manufacturers, where one kind of chip may use that unsoldered pin while the other chip may not use it.
          ex 12v to 5v linear regulators
          chip 1: input - adjust - output , tab = ground
          chip 2: input - ground - output , tab = ground
          chip 1 can be either fixed 12v to 5v or it could be for example 12v to 9v with adjustable pin connected to resistors to lower the default 9v to 5v
          chip 2 must be fixed 12v to 5v ...
          depending on the chip type, they may or may not solder the adjust pin to the board to generate at output 5v
          So no, don't solder anything where it seems there was no solder initially.
          • t.j.
            • Apr 2010
            • 383
            • canada
            sorry for the bd info! should have asked if it looked like there was a solder puddle on pad!
            • corrize
              Best way to solder LVDS connector for beginner (and qfn) ?
              by corrize
              Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
              I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
              I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
              See the test :
              https://youtu.be/bNAzC-EvqHs?t=1767
              With hot air from bellow the board, that's...
              03-09-2023, 02:57 AM
            • petemanuk
              BGA solder balls not connecting - help pls
              by petemanuk
              So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
              I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
              I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
              11-16-2022, 05:21 AM
            • myth77
              UV solder mask - high temp resistent, recomendation?
              by myth77
              Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
              Is there any solder mask...
              03-28-2022, 04:04 AM
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • silberdrache
              Burnt Hole under IC on MacBook Pro M1 Pro 14"
              by silberdrache
              I'm new to this Forum, so I hope it's the right place for this topic.
              Im a student from germany, and as a hobby I repair electronics. I started microsoldering maybe 1-2 years ago.
              I have a MacBook Pro 14" m1 Pro with 10 Cores and 16/1tb storage. The board Number is 820-02098-A.
              The MacBook has a light water damage. Coffee got spilled over it, but the Mac continued working only the battery didn't charge anymore and when the battery was empty the Mac turned off and doesn't show any sign of life now.
              I opened it up and there were only three drops of coffee...
              11-10-2025, 11:19 AM
