Acer AL1916W(s) ccfls
  • AcerNewby
    • Jun 2012
    • England
    Hi All,
    I'm new and reading the posts am out of my depth already! I found the site after getting no help from A*er technical. Easy one I guess. I'm in the UK and been given the above monitor. My friend said it was taking longer and longer to come on but was fine when it did. Eventually it wouldnt come on at all. I am a factory mechanic not an electrician, but having had similar problems on the cnc machines I mainatain I suspected the ccfls. Am I barking up the wrong tree. The tube holders are stamped with 6811. Could anyone direct me to a supplier, UK ideally, if I am heading in the right direction that is! I hate creating landfill if a cheap fix is possible.
    I hope you don't mind my ill informed question. Thanks in advance.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Acer AL1916W(s) ccfls
    This doesnt actually sound like a lamps problem- do you want to do a few tests first.
    Lamps are quite difficult to handle/replace also expensive relative to a second hand 19" monitor. Whilst it might sound difficult reading the posts the tests are simple and we can
    give step by step instruction - small steps -based on your ability.
    Do you have a multimeter and soldering equipment and can you use them.
    Welcome to the forum-
    We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Examples of what is needed
    https://www.badcaps.net/forum/attach...1&d=1290283049
    https://www.badcaps.net/forum/attach...7&d=1280167246
    It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc.
    • Koda
      • Aug 2011
      • 317
      • Macedonia
      It's easy to see if it is a problem with CCFL's, just shine a light on the display and see if there's any kind of picture. If there is then it's either an inverter problem of the CCFL bulbs gone bad. Also the problem can be caused by bad solder joints on the inverter transformer(s) or bad joints on the CCFL's meaning they can be good but not getting power. This applies if the monitor turns on and stays on. What you described sounds like you might have bad capacitors since the monitor would take a long time to turn on and now it doesn't come on at all. My advice is to pop the thing open and check the caps first. If all seem ok then you have another problem.
      Guns don't solve problems. I'll take 12
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        I find replacing CCFL's in desktop monitor pretty easy usually. at least the ones iv'e taken apart they just slide out.
        laptop monitors, no, hell no.
        but this screams inverter. when caps start to dry up on your power board, it can cause longer and longer lamp warmup times
          by momaka
          03-15-2023, 10:17 PM
        • maralexbar
          How to force Acer Aspire Series to bootup BIOS/UEFI on external Monitor?
          by maralexbar
          I ask this question in general as there are many Acer Aspire models with UEFI Insyde BIOS that do not boot to the BIOS on an external monitor (VGA, HDMI, etc) showing only the Internal LCD (LVDS, eDP etc).
          It's a pain to work on Acer notebooks with a broken screen and not being able to access the BIOS using an external monitor.
          If anyone knows how to force the external monitor as primary for Notebooks of those models
          11-02-2024, 09:18 AM
          09-06-2024, 05:27 AM
          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
          09-07-2024, 05:00 AM
          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
