SSD worth it? recommendation? for this computer
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    It's my new take-it-everywhere laptop, an Asus X44H...
    Specs:
    -i3 CPU
    -4GB RAM
    -Intel HD3000 graphics
    -320GB 5400RPM Seagate SATA 2.5" HDD
    So, it takes a long time to boot up, and I'm sure it's not good for the mechanical drive that I take this on the bus...
    Thing is, I need a fair amount of capacity. The 64GB drive in my Lenovo is fine since I can use an external disk at home...
    So, any recommendations? And do you think it would be worth it for this computer to have an SSD?
    I'm looking at http://www.newegg.com/Product/Produc...82E16820227777 but I'm not really sure if that's a good once, I've heard bad things about OCZ drives.
    Anyway, info is appreciated
  • mariushm
    • May 2011
    • 3799
    Re: SSD worth it? recommendation? for this computer
    Really, you're gonna use a 200$ ssd on a 400$ laptop?
    Get this: http://www.newegg.com/Product/Produc...82E16820148448
    Or this is you're OK with 64 GB: http://www.newegg.com/Product/Produc...82E16820148441
    These Crucial M4 , Samsung 830 and the Intel SSD are some of the best drives.
    If you want the highest battery life, the Samsung 830 is to go for - it can be a difference of 10% battery between ssd drives.
    • retiredcaps
      • Apr 2010
      • 9271
      For all my computers now, I use hibernate instead of shutdown. It makes a difference especially on my netbook.
      If you want to do a clean boot up each time and are running windows, run msconfig and check your startup items and disable all but what is necessary.
      --- begin sig file ---
      --- end sig file ---
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        I know how to optimize a computer :P See?
        http://hardwareinsights.com/wp/2011/...r-pc-for-free/
        But thanks anyway lol. And I hate Hibernate..
        Anyway, I am leaning toward this:
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          Optimized computer and windows 7....what an oxymoron that is!
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            Lol. Then maybe you can explain why my clean install of XP on a Dell 745 with a 2.4GHz Core 2 Duo CPU and 4GB RAM is so slow?
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Slow / Bad HDD? Check SMART.
              Perhaps a bunch of dell crap in the background? How clean are we talking?
              sigpic
              (Insert witty quote here)
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16958
                I have no idea, I have that IDENTICAL machine with x64 running on it, its slick as snot, I use it every day....its my shipdesk computer. HDD is a 320gb WD black. Its a very nice little rig, I have no beefs with it.....its actually gross overkill for the duties it performs.
                Team : 49813
                Join in!!
                Team Stats
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  For me, It comes down tha that w/o pirating 7 is mostly out for me... The newest I have is Vista Home premium.
                  I *could* get a 7 Pro upgrade copy for $20. I think I am limited to one and only one copy. However, the only computer that I have that uses Windows exclusively is non-multi-core and 32 bit (pentium M). My only other computer with windows as a boot option is my main laptop, which's Vista partition almost never sees use. It just isn't worth $20 for something I won't use.
                  sigpic
                  • mariushm
                    • May 2011
                    • 3799
                    The article misses the most important part of optimizing an operating system, disabling services that are not required to run.
                    The icon removal tip is pointless and the first tip on xp is just a trick, it basically defers some driver loading and network stuff for after user logs on - the OS will still crunch the drive for those 10s or so you feel were cut down from boot.
                    The Crucial M4 is a very good drive, can't go wrong with it. Be on the lookout for daily deals because there's an updated model of the M4 released and they may discount these to make room for the new ones.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      I've stopped disabling services a couple years back, it makes less difference than you may think. Disabling animations and smooth scrolling makes the system feel snappy enough.
                      In Win7, i only stop completely stupid services like the windows media player network service which fills the C drive with album art whether you're using WMP or not, and annoyances like the program compatibility assistant. Disabling services is more work than it's worth, because sometime or the other a program is going to mysteriously fail to run, and you'll have to figure out which one of the disabled services it wanted running. Been thru that more than once.
                      A working TV? How boring!
                      • shovenose
                        Send Doge Memes
                        • Aug 2010
                        • 6575
                        Well, I put a different HDD in there (Seagate 250GB SATA) and the performance is significantly better. I also installed the Chipset driver BEFORE installing Norton Business Suite this time...
                        Also, it looks like Win2K now because I adjusted the settings for best performance, except I did enable the show windows contents while dragging bcuz it's very useful
                        It's not like I needed to lower the settings, because the Radeon HD 4350 1GB can handle everything just fine, BUT it's a sort of placebo effect I think! Because the Dell literally feels 10x faster... maybe that WD HDD really was messed up!
                        Hey anybody want to buy a computer? it's got a 250GB WD HDD in it LOL! jk
                        • shovenose
                          Send Doge Memes
                          • Aug 2010
                          • 6575
                          Icon removal tip is NOT pointless, on lower-spec systems (pentium iii, etc.) it's actually quite useful. Try it!
                          The registry edit for startup makes things look faster, while they aren't. However, I wanted people to think it's faster! Besides, it doesn't harm anything...
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            ...and the truth comes out...
                            You know and I know that we've had the discussion about trying to use techie toys to look cool... It generally doesn't work.
                            Money can't buy a personality... but if you want to be cool, start there.
                            sigpic
                            • shovenose
                              Send Doge Memes
                              • Aug 2010
                              • 6575
                              Money can buy toys that I enjoy. At least for a week
                              I got a lot of "nice laptop" at school today. One day of slight recognition sure is an improvement!
                              Now, before we get completely off topic, I'll try to get a good deal on that 128GB M4 drive and buy it.
                              • mariushm
                                • May 2011
                                • 3799
                                Removing the icons would save about 200 KB worth of memory and 1s of disk access, needed to read the 1 KB files from a single folder.
                                When the computer would need those KB, the icons would be paged to disk. You notice the old system runs faster without them because due to low memory, Windows probably has to read them back from the swap file.
                                Basically, if the system is properly optimized in the first place, the impact of reading the icons information back from swap file would be minimal.
                                Instead, by removing the icons from the desktop, user potentially loses much more time going through the menus (and have those icons cached and have registry accessed and several folders scanned to build the start menu)
                                The steps that have most impact are generally:
                                1. set page file to a fixed one 2-4 GB (less than 2^32 bytes is recommended)
                                2. clean registry if you want to, it doesn't make a damn difference to the performance. It's like having a sql database full of empty spaces after removing a bunch of records - the kernel uses binary trees and indexes to read the data.
                                3. disable unneeded services. Stuff like background intelligent transfer, fast search, system restore, wireless and bluetooth (if user has no wireless) are constantly monitoring and doing something and keep memory active (can't be paged) so systems with little memory are impacted by this
                                4. now it's time to do the defragmenting - with the page file fixed, any defragmenter worth its salt would move the page file at the beginning of the disk, therefore disk access would be miminal so you'd notice an improvement. With page file left varying, it would usually be created by the OS around the middle of the partition, so it would have room to expand.
                                5. tweak the startup, remove stuff that's set in autorun (java auto update , adobe acrobat fast startup etc)
                                6. tweak display acceleration and crap if the video card is slow. some newer cards are good enough tweaking animations and stuff won't matter, it's just visual, feels slow but the system isn't in reality
                                ...and there's others things but really, icons on desktop... it's embarassing.
                                the 10s delay startup thing can cause problems for people, for example let's say a user starts a software that uses a usb dongle as protection mechanism. It's possible that driver didn't load yet, so the software invalidates the license...it's unnecessary. If you disable the services you don't need, then the system would boot up fast anyway.
                                (apologies for being off topic)
                                • lti
                                  • May 2011
                                  • 2553
                                  How long does this computer take to boot up?
                                  In my experience, cleaning the registry can also break installed software and will eventually corrupt the registry, forcing the user to reinstall Windows.
                                  • shovenose
                                    Send Doge Memes
                                    • Aug 2010
                                    • 6575
                                    Which computer?
                                    The XP Dell or the Asus X44H?
                                    • c_hegge
                                      • Sep 2009
                                      • 5219
                                      I never defragment. It makes no difference to the performance and wears out the HDD. I do agree with you though on removing icons. I don't think it ever has made a difference and don't think it ever will.
                                      @shovenose: I would say unless you can find a cheap SSD, forget it. It's not worth it on a cheap laptop.
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        I disagree. On units with a 5400RPM or slower HDD, it DOES make a difference when fragmentation is severe. My Dell Latitude D400 once was crippled by this; a defrag (using the auslogics utility) had a large impact.
                                        sigpic
                                        • eccerr0r
                                          It's 2025: do you know where your 5¼" floppy drives are?
                                          by eccerr0r
                                          Oh wow.
                                          As in the other thread I was trying to revive/re-bootstrap an old Apple IIe and wasn't successful reading or writing any disk. Both drives behave similarly.
                                          Then I was wondering, what about my PC floppy drives? I have a HH 5¼" HD drive and a combo 5¼+3½ drive. I tried formatting the disk that wouldn't work in the Apple and it didn't work in the PC either!
                                          Then I tried a HD 5.25 disk ... it won't even touch the disk either! Just like the Apple DD disk, "Not Ready!"
                                          Weird. Seems the PC drive is having trouble clamping...
                                          07-07-2025, 12:49 AM
                                        • abajor
                                          Evaluating Mechanical Hard Drives SMART Data in Linux (Ubuntu) Using the Disks Utility.
                                          by abajor
                                          I've gotten into the habit of Looking at peoples Mechanical Hard drives with a Ubuntu thumb drive to boot their system.
                                          I understand the raw values are not really uniform between manufacturers, but I have noticed that high seek and read error raw values at the very least correlate to a drive that is going to have sub par access time, and extremely slow OS booting.
                                          The odd thing is I've often seen very high seek and read error rates on drives with fairly low on time.
                                          Does anybody have any other takes on evaluating smart data? I've used Crystal Disk Info, It seems to present...
                                          04-23-2024, 11:43 PM
                                          HP Compaq Pro 6000 SFF Compaq Pro 6000 E5400 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Pro 6000 SFF can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro 6000 SFF boardview and Compaq Pro 6000 SFF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:44 PM
                                          HP Compaq Elite 8000 SFF Compaq Elite 8000 E5700 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Elite 8000 SFF can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite 8000 SFF boardview and Compaq Elite 8000 SFF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          HP EliteDesk 800 G1 EliteDesk 800 i5-4690S Specification for Upgrade or Repair
                                          This specification for the HP EliteDesk 800 G1 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G1 boardview and EliteDesk 800 G1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                          09-12-2024, 03:30 PM
