MSI 975X Platinum 2.b
  • Super Nade
    • Jun 2006
    • 294
    Guys,
    This is from a preview thread by Coolaler of xtremesystems. The caps on the board look like Rubycon, right?
    http://www.xtremesystems.org/forums/...d.php?t=103982
    Q6700 @ 3.6 GHz
    Zippy GSM-6600P
    Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
    Abit IP35Pro
    ATi HD4870
  • Fatal0E
    • Jan 2004
    • 252
    Re: MSI 975X Platinum 2.b
    Panasonic
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      the ones i can see are panasonic.
      • PeteS in CA
        • Aug 2005
        • 3583
        • USA, Unsure of Planet
        Looks like a mix of FCs (blue with gold markings) and FMs (black with gold markings).
        PeteS in CA
        • Shroomie
          • Apr 2006
          • 356
          Yep, Panasonic. T-vents.
          If there's a good PSU on that, it should last a while.
          You know there's something wrong when you open up a PSU and are glad to find Teapos.
          Why I don't buy cheap cases!
          • linuxguru
            • Apr 2005
            • 1564
            The CPU is a Kentsfield quad-core (Conroe Extreme Edition) with 4 x 2MB L2 cache, right? By the look of the monster heatsink on it, it's not going to run cool, nor is it going to be able to fit in a 1U cabinet anytime soon. But the next 12 months of the Intel-AMD spat is going to be very interesting...
            • Super Nade
              • Jun 2006
              • 294
              Aah o.k, I'm still a newb guys so don't be too hard on me.
              Yes, its a Kentsfield Quad monster! The HSF is not stock however. It is an aftermarket solution, probably the new Thermalright one.That CPU OC's from 2.4-->3.2GHz on stock volts! That's going to be one bad ass monster!!
              Q6700 @ 3.6 GHz
              Zippy GSM-6600P
              Abit IP35Pro
              ATi HD4870
              • Galvanized
                • Mar 2006
                • 468
                Your Tuniq Tower 120 is rated as one of the best for cooling with air. But it scales in at 795g w/o a fan. A fan would add another 120+g. Most boards are rated for a 500g HS that sits low on the chip. Because it is high & heavy, use real care when moving the case, never transport the rig with the sink attached. Aside from weight, another disadvantage of these cross flow HSs(Ninja included), is the board population is not getting any scrubbing, cooling air. This can have an impact on the long term life of board caps.
                You will note that some vertical HSs are tilted so the discharge air is directed at the VRM & caps between the CPU & I/O plate. The arctic Cooling Freezer Pro has it's lower fins curved for this purpose.
                Given a choice, I'd use a SI-120 but go with the Tuniq if you already have it, just note what I've said about board cooling & weight.
                • Galvanized
                  • Mar 2006
                  • 468
                  SuperNade, this should prove to be a good read. Note PWM (VRM/FETs) temps/cooling. This heat is linked to the caps through the board traces.
                  http://forum.abit-usa.com/showthread.php?t=103462
                  • Super Nade
                    • Jun 2006
                    • 294
                    Nice read. Thanks. That was a very detailed experiment.The dude must have loads and loads of patience!
                    Q6700 @ 3.6 GHz
                    Zippy GSM-6600P
                    Abit IP35Pro
                    ATi HD4870
                    • Galvanized
                      • Mar 2006
                      • 468
                      Something new from TR http://www.overclockers.com/articles1340/
                      Some German comparisons http://www.hartware.de/review_597_8.html
                      Not avalible State side...Yet. Basic w/8mm heat pipes=no bling but light & efficient.
                      • Super Nade
                        • Jun 2006
                        • 294
                        Ye I read the one on ocforums. A 120mm holder was long overdue. I wonder how CF and SLI folks feel about this? The fan would touch an SLI or CF card for sure.
                        As for the second review, Mein Deutsch ist nicht so gut, aber Ich lerne gern Deutsch! Sprechen Sie Deutsch?
                        Q6700 @ 3.6 GHz
                        Zippy GSM-6600P
                        Abit IP35Pro
                        ATi HD4870
