Windows NT 4.0 SAM Database
  • Maxxarcade
    • Jul 2006
    • 973
    I have an PC based security DVR that the company is no longer supporting. The hard drive had a nasty crash and Windows will no longer boot. It shows the Windows NT 4.0 Workstation graphic for a bit before dropping to a blue screen saying the SAM database is corrupt.
    With the drive connected to another PC, I am able to access the "repair" folder withing the windows folder, but the setup.log file is missing. I was able to find images of the 3 boot disks, but I have no ERD. The boot disks cannot find the installation on the hard drive, even though the system boots from it.
    So what I need to do is either fix the existing installation, or find a way to extract the custom software package and all its drivers to try installing on a new OS such as WinXP. Any idea what I could do? I tried making an ERD, but it complains about an incorrect or missing signature or something like that.
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: Windows NT 4.0 SAM Database
    you still might be able to find the software even if the company does not exist, it may just take some looking
    I use doubledriver (google it) to be able to backup drivers from other installs but (you can load hives from other external windows registries). you however cannot do this with full software programs.
    if its a standalone program, you should be able to do something, but if its not, it needs probably a few files copied to the windows directory and maybe a registered service or two
    google the program and see if you can find any alternative downloads. So this person has no install disk? does it require a key?
    • Maxxarcade
      • Jul 2006
      • 973
      It's a Radionics V8200 Series DVR. I already talked to the company that bought out the original, and they don't offer any support on it at all. The security key is plugged into the parallel port.
      I'll check into that driver program and see where it gets me. The data on the drive seems intact other than the corrupt SAM database. Even the Windows Password Reset program I have said it was corrupt and crashed.
      I was able to locate a Windows CD that should work, which I can test tomorrow. Already made an image of the hard drive, so I can experiment at no risk.
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Might be unstable RAM.
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • DynaxSC
          ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
          by DynaxSC
          I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
          Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
          Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
          The behaviour is also really very strange, i.e.:
          • The disk shows always up in BIOS - so it is recognized, so far so good
          • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
          02-23-2025, 01:33 PM
        • eltano4i20
          [HELP] SAMSUNG NP270E4E-K01AR
          by eltano4i20
          1) Error trying to enter the BIOS
          --> [F2] won't let me enter the BIOS. To enter the BIOS, I had to create a shortcut and then type C:\Windows\System32\shutdown.exe /r /fw /t 1 in the destination. This forced it to restart and enter the BIOS.
          Once inside, I went to the BOOT menu, but, surprise, it wasn't there. I got the following message:
          BOOT PRIORITY ORDER (img-05)
          1- Windows Boot Manager
          2- SATA HDD
          3- NETWORK
          4- Debian
          2) Error trying to access the BOOT MENU
          --> I restarted the notebook and pressed [F10] but the BOOT...
          07-04-2025, 12:39 AM
        • 0xx
          2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
          by 0xx
          Hi folks,
          My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
          What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
          I assumed that Windows Update was interrupted due to closing...
          09-14-2025, 03:46 PM
        • mr.malcom
          HP 17-cd0606ng no Windows or Linux Boot, exept idle=poll Boot-Parameter
          by mr.malcom
          this is a very strange Problem:
          Notebook hang instantly on Boot. BIOS is accesable.
          Windows: instant after showing "loading circle", even Windows Boot Stick hang instant (even without installed SSD/NVME )
          Linux: instantly (if Linux Boot in leagacy Mode with log messages: Machine Check exception after 0.25 sec)
          i have tried:
          - only one RAM Stick, another working RAM, both RAM channel
          - BIOS Flash to newest Version F.50, BIOS Reset
          - Memtest86 hang instant at Test 2
          - HP UEFI Diagnostic wont find...
          02-26-2022, 05:19 AM
        • Benass
          Surface Laptop 3 Not Detecting SSD - Need Help!
          by Benass
          Hey everyone,
          I'm having an issue with my Surface Laptop 3, and I could really use some help. I've tried everything I can think of, but my laptop just won't detect any new SSDs I install. Here's a rundown of the situation:
          Problem:
          • My Surface Laptop 3 isn't detecting any new SSDs, including a Sabrent Rocket 2230 256GB NVMe SSD and a Dogfish 256GB M.2 2230 NVMe PCIe Gen 3.0 x4 SSD.
          • Both SSDs work fine in other laptops, so I know they are functional.
          • The laptop does detect a Forsee 64GB SSD from my Steam Deck, and I can successfully install Windows on it.
          What I've Tried:
          1. Compatibility
          07-22-2024, 11:26 PM
