Whats Causing This Problem ?
  • colormebad
    colormebad
    • 114
    http://www.youtube.com/watch?v=f-ih_kR5YoA
  • Scenic
    o.O
    • Sep 2007
    • 2640
    Re: Whats Causing This Problem ?
    the desync? like the screen being cut up?
    Try it on another computer. I've seen something like this quite a few times. It's usually caused by the graphics card / its drivers combined with powersaving stuff (it clocks itself down to the bare minimum to save power)
    • colormebad
      colormebad
      • 114
      The graphics works off the intel 2600k ' not sure whats going on...Thats the only problem i have...
      • severach
        • Aug 2007
        • 1055
        http://en.wikipedia.org/wiki/Screen_tearing
        My ATI HD 4850 shows minimal tearing for a picture on a 2560x1600 display. Maybe you need a better video card.
        sig files are for morons
        • Mad_Professor
          A Mech Warrior
          • Feb 2011
          • 1587
          Just enable vertical sync in the intel control panel, problem solved!
          • mariushm
            • May 2011
            • 3799
            Force vsync on in the driver.
            If still not helping, and your browser is Firefox, type about:config and press enter
            In the filters box, type "acceleration" and you should see "layers.acceleration.disabled" popping up in the list below. Double click on it until you see "True" under value on the right. Restart the browser.
            This disables the hardware acceleration of font and images inside the browser and switches back the classic 2d acceleration - the old style is not that sensitive and should have less tearing.
            • colormebad
              colormebad
              • 114
              I tryed all the other options and still the same..I dont see vertical sync in intel control panel..I looked through every section and dont see that..I have a new video card i will install in it sometime later or tonight & try that...I tryed Firefox & Chrome and still did the same thing also
              • Mad_Professor
                A Mech Warrior
                • Feb 2011
                • 1587
                You obviously don't have the latest driver installed. I have the 2500k and even I have the vertical sync option, it's in the advance configuration tab.
                • colormebad
                  colormebad
                  • 114
                  I will go back and look again..I am getting older...LoL
                  Here is the driver i have ' its the same on the asus & intel site
                  8.15.10.2509
                  • colormebad
                    colormebad
                    • 114
                    I just found it! Its under 3D Custom settings...I will try it now...
                    UPDATE! I enabled it but same thing...I will keep trying or just install the new video card later or tomorrow...
                    • theone111
                      by theone111
                      3. Problem: TV shuts down
                      07-22-2024, 10:36 AM
                    • Zeonalbasta
                      Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                      by Zeonalbasta
                      i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                      The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                      09-13-2024, 01:17 PM
                    • Gibon378
                      Problem with stopping audio and video for no reason
                      by Gibon378
                      PC Specs:
                      • CPU: Ryzen 5 1600
                      • GPU: GTX 1080 Palit JetStream
                      • MOBO: ASRock ab350 PRO4
                      • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                      • PSU: XFX 650W (don't remember what model)
                      • OS SSD: ADATA SP920
                      • OS: Windows 10 21H2
                      Problem description:
                      Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                      11-19-2022, 09:41 AM
                    • perzyk23
                      Lenovo T580 - LCD Panel problem - error 0288
                      by perzyk23
                      Good morning,
                      I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                      10-25-2024, 12:42 AM
                    • SDNarcia
                      Dell 15R-5521 keyboard problem (KBC?)
                      by SDNarcia
                      Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                      As additional information,...
                      07-20-2024, 10:47 PM
