Whats Causing This Problem ?
Tags: None
Re: Whats Causing This Problem ?
the desync? like the screen being cut up?
Try it on another computer. I've seen something like this quite a few times. It's usually caused by the graphics card / its drivers combined with powersaving stuff (it clocks itself down to the bare minimum to save power)
The graphics works off the intel 2600k ' not sure whats going on...Thats the only problem i have...Comment
http://en.wikipedia.org/wiki/Screen_tearing
My ATI HD 4850 shows minimal tearing for a picture on a 2560x1600 display. Maybe you need a better video card.Comment
Just enable vertical sync in the intel control panel, problem solved!Comment
Force vsync on in the driver.
If still not helping, and your browser is Firefox, type about:config and press enter
In the filters box, type "acceleration" and you should see "layers.acceleration.disabled" popping up in the list below. Double click on it until you see "True" under value on the right. Restart the browser.
This disables the hardware acceleration of font and images inside the browser and switches back the classic 2d acceleration - the old style is not that sensitive and should have less tearing.Comment
I tryed all the other options and still the same..I dont see vertical sync in intel control panel..I looked through every section and dont see that..I have a new video card i will install in it sometime later or tonight & try that...I tryed Firefox & Chrome and still did the same thing alsoComment
You obviously don't have the latest driver installed. I have the 2500k and even I have the vertical sync option, it's in the advance configuration tab.Comment
I will go back and look again..I am getting older...LoL
Here is the driver i have ' its the same on the asus & intel site
8.15.10.2509Comment
I just found it! Its under 3D Custom settings...I will try it now...
UPDATE! I enabled it but same thing...I will keep trying or just install the new video card later or tomorrow...Last edited by colormebad; 03-02-2012, 05:03 PM.Comment
by theone111I have an LG Plasma TV 60PM6700 for the past ~12 years.
In the last ~3-4 months I have been having some issues.- Problem: It started with random picture disappearing (sound still worked).
Solution: Had to turn off TV wait a few seconds before turning it on again. - Problem: Then it got worse and the TV started to shut down and when turning on the no picture just sound.
Solution: Had to turn off TV wait about 10-20 seconds and turn it on again to solve. - Problem: TV shuts down
1 Photo - Problem: It started with random picture disappearing (sound still worked).
by Zeonalbastai have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double... -
by Gibon378PC Specs:
- CPU: Ryzen 5 1600
- GPU: GTX 1080 Palit JetStream
- MOBO: ASRock ab350 PRO4
- RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
- PSU: XFX 650W (don't remember what model)
- OS SSD: ADATA SP920
- OS: Windows 10 21H2
Problem description:
Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders... -
by perzyk23Good morning,
I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise.... -
by lazaro.089Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
CPU: Core i9-12900H
Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and... - Loading...
