Just Joined!
  • Chuckster_In_Jax
    • Feb 2012
    Just Joined!
    I am a collector of vintage computers and am trying to revive a motherboard from Gateway 2000 486 machine. It has an Intel Classic R mobo. It would boot into CMOS and you could make changes and save, but when you tried to boot from floppy or hard drive it would always say the drives failed. Because of past experience with bad tantalums and Aluminum Electrolytics, I tested those first with a multimeter. Found several that were shorted and was combing the web for suggestions for high quality components when I hit this site. Lots of good info and has helped me greatly in making a decision on what brand to buy.
    Also found from a manufacturers site that one of the causes of failed capacitors is high ripple current from a bad power supply. Turns out high ripple will cause the mobo capacitors to overheat and prematurely fail. After I recap the mobo, I'll put the oscilloscope on the power supply and make sure ripple is low coming out of it.
    Thanks again for the valuable info!
    Chuck
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Just Joined!
    Welcome!
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      Re: Just Joined!
      welcome to component level repair wonderland!
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • c_corr
        Asus P4C800-E VRM issues
        by c_corr
        This board had the initial fault in VRM with high side Mosfet from PWM1 (phase 1) getting very hot. It also had the VRM caps quicly heating up in 10-15 seconds after power on.
        This board uses mext ICs and Mosfets in VRM:
        - ADP3180 PWM controller - in 3 phase mode
        - ADP3418 as Modfet drivers
        - High side Mosfets STD38NH02L (from ST)
        - Low side Mosfets STD90NH02L
        Some of the symptoms were very similar with the "Dead Asus P5P800-VM" in this forum.
        I had the sawtooth voltage on Vcore too this was probably the cause of the Vcore caps...
        02-08-2025, 11:59 PM
      • chth96
        Is it no harm to replace with capacitor without ripple current rating?
        by chth96
        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
        Rubycon YK DataSheet (b...
        04-19-2024, 05:19 AM
        Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
        I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
        I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
        I tested the battery cells there are installed right now and they are testing good with no issues that I...
        02-04-2025, 08:08 PM
      • harp
        high voltage high resistance marking resistor
        by harp
        Is there any reason why high voltage high resistance resistor use weird marking and value on it? Standard nomenclature, EIA value not used?...
        08-26-2024, 01:42 PM
      • karatzdi
        Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
        by karatzdi
        I know some might say... just buy another one. Sell it as parts..!
        So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
        Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
        Spent some time downloading the Service...
        06-11-2024, 08:38 AM
