What are some quality AT Power Supplies?
  • barney
    • Sep 2011
    • 3
    Does anybody know of any good, stable AT power supplies with good build quality? I am putting together a retro 386 gaming machine and want to find a quality AT power supply.
    Thanks.
  • dmill89
    • Dec 2011
    • 2534
    Re: What are some quality AT Power Supplies?
    My personal recommendation would be either to find a good used/NOS one (Delta, SeaSonic, etc) or get an ATX to AT adaptor(if you do this make sure the ATX PSU you use has a strong 5v rail since it is the most heavily used by an older system). Most of the new AT PSUs currently available are gutless wonders.
    Here's the link for the AT adaptor:
    StarTech ATX to AT Motherboard Power Converter Cable
    Here's the AT PSUs currently available on Newegg
    Neither one of them is exactly spectacular.
    Here are some NOS AT PSUs I found on EBay:
    FSP/ Sparkle SPI-250G SPI250G 250W AT PS2 Power Supply = $55
    Delta AT POWER SUPPLY DPS-200PB-8 56.04200.1B3 91.AB347.004 = $50
    • mariushm
      • May 2011
      • 3799
      The 386/486 machines will most likely still use -5v, -12v (afaik one of these was used on ISA slots) which are no longer available on ATX power supplies.
      So the ATX to AT cable won't do much good.
      You're going to have to pick an AT power supply or an old ATX 1.3-1.4 power supply... the cheap kinds on Newegg that still say Pentium IV on them. But basically look for -5v and -12v on the label.
      The requirement for power supplies to provide -5v was made optional around ATX 2.1 so anything older than that should still have it.
      • dmill89
        • Dec 2011
        • 2534
        I forgot to mention that info in my post, thanks for putting it up.
        This would be an excellent candidate for use as an AT PSU:
        TOPOWER ZU-500W 500W = $35
        It has -12v and -5v rails and a strong (46A) 5v rail. TOPOWER is not the best PSU around but they relatively decent and are better than most PSUs out there that still have -5v and -12v rails.
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          I've got the 450W of this (excepted it's branded Zumax instead of Topower) and it's got Fuhjyyu caps in it...
          don't buy it.
          • dmill89
            • Dec 2011
            • 2534
            don't buy it.
            That's the thing about TOPOWERs they tend to be decently built PSUs but have junk caps. However most of the other PSUs in current production that still have -12v and -5v rails are both poorly built and have junk caps, so that TOPOWER is probably one of the better options for a brand new current production PSU(especially after a recap) even with junk capacitors it will probably last a couple years, a NOS PSU would probably be the best option if he can find a decent one that isn't hideously expensive(the fact that good NOS 200w-250w AT PSUs are going for $50+ on EBAY is nuts, case of extremely limited supply I guess).
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              don't buy it.
              well, if the guts were ok, one could buy it, use it long enough to make sure it works, and then do a recap.
              there is a user here called brethin who IIRC has a few old AT psus he is looking to get rid of... he may have scrapped them already though.
              off topic:
              if they still exist, that reminds me, I have a really nice AT case that lost it's PSU due being a gutless wonder (CHICAGO PSUs= )... too bad the board was the PC-CHIPS 386 cacheless board of doom and I have no extra sdram for my pII/PIII AT board... maybe I should put the case up for "adoption"...
              sigpic
              (Insert witty quote here)
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                if you're looking for something NEW
                http://www.newegg.com/Product/Produc...82E16817338025
                Athena is OK, they make a lot of server stuff (not saying its good server stuff)
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  those AT units are death traps.
                  the worst modern gutless wonders I have seen were athena AT units. as in small heatsinks, 4 diodes, few/no filter caps, no input filtering, thin wire, bad fans, etc.
                  they make powmax look good.
                  hell, they make echo star look good!
                  look at the pics. look how thin the wires are.
                  do yourself a favor and buy a used hipro or delta or the like...
                  sigpic
                  • barney
                    • Sep 2011
                    • 3
                    I've been looking around ebay. I'll think I 'll go for the ATX power supply with the AT adapter. Are Enermax power supplies any good?
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      Sometimes... you would be better off with a Used Hipro unit or a used OEM unit (like the 250W PSUs found in pIII era Compaqs).
                      sigpic
                      • mariushm
                        • May 2011
                        • 3799
                        Again... you need the power supply to deliver -12v and possibly -5v as well if it's an old motherboard.
                        The adapter cable simply assumes the ATX power supply will deliver these voltages on some pins, but starting with some versions of the ATX standard those voltages were made optional and later they were removed completely.
                        The pins still exist in the ATX connector so the adapter will route them where they should go, but new power supplies won't even have a wire going in those spots.
                        Here's the ATX connectors, both the more recent 2.0+ version and the old 1.0 version:
                        Note how the -5v wire (white) is present on the old connector (to the right) and it's missing in the new connector ( n/c on new one). The adapter cable needs to have the wire in the left connector to route the -5v to the AT motherboard power input connector:
                        Don't buy from eBay. You're not saying where you live... so here's assuming you're in US, buy this:
                        http://www.newegg.com/Product/Produc...82E16817152032
                        It has both -5v and -12v.
                        This also has both but I'm not sure of the quality: http://www.newegg.com/Product/Produc...82E16817707003
                        Anyway, for a 386 or 486, they'll be good enough, those machines don't use more than 60-100 watts anyway.
                        If you're up for a bit of soldering, I guess you could buy a decent power supply with -12v (should still be plenty modern ones) and generate the -5v from the -12v line using a negative voltage regulator.. for example something like this:
                        http://search.digikey.com/us/en/prod...05FA-ND/805802
                        You just feed it ground on pin 1, -12v from the power supply through pin 2 and out comes -5v on pin 3 ... which assures the power supply -5v as available even if no components on board will use it.
                        • dmill89
                          • Dec 2011
                          • 2534
                          These Might also be good options for an ATX to AT conversion:
                          FSP 300-60ATVS = $16
                          Seasonic SS-300FS = $18
                          They are old (NOS) OEM units left over from manufacture and are hard to beat for the money. Both of these units are old enough to still have -12v and -5v rails, plus a strong +5v rail.
                          • GLISIT
                            by GLISIT
                            01-16-2025, 02:29 PM
                          • iMic
                            Vintage AT Power Supplies - Selecting Capacitors
                            by iMic
                            Back after a long hiatus with some old power supplies that need repairing. I've recently picked up a couple of 386SX systems, two 486DX systems, a SiliconGraphics Indy and an iMac G3 that either have verified leaking capacitors in their power supplies, or are likely to in the near future. For the sake of simplicity, instead of tackling all at once, I'm starting with the 386's and one of the 486's.
                            The 386's power supplies are Seasonic SS4040A's, with caps that are visibly leaking, and 9 replacement caps per unit are required. Most appear to be from the Rubycon...
                            02-19-2023, 06:45 PM
                            09-06-2024, 05:59 AM
                            HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                            This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            09-12-2024, 02:15 PM
