Server cards
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Server cards
    Scored a couple server cards today for $5 a pop:
    1. 3ware HW raid 4 port SATA card:
    the RAM module is a 128mb 4 chip unit... DDR?
    2. Broadcom gigabit card:
    esp. the first card, are these cards worth anything?
    I don't have a use for them at the moment but at that price, i figured that if anything, they had resale value.
    sigpic
    (Insert witty quote here)
  • mariushm
    • May 2011
    • 3799
    Re: Server cards
    The first card... since it's from around 2003, it's probably just SATA1, so 1.5 gbps. It probably also won't support more than 250GB drives or something like that. Not sure.
    The other card... you got lucky with that one. Hardware offloaded gigabit, should still be faster and use less CPU than most onboard network cards (maybe some onboard pci express x1 Intel chips are better). I guess it really depends if they kept the drivers updated.
    Oh... it might even run in regular PCI slot, with the rest of the connector in the air... I know the Intel cards used to work like that but I guess it depends on the implementation. Try to find the manual for the card and see what it says.
    ps.
    http://www.broadcom.com/products/BCM5703
    http://www.techexcess.net/bcm5703-br...r-adapter.aspx
    PCI-X
    Gigabit Server Adapter
    Bus: 32-/64-bit, 33/66 MHz PCI; 64-bit, 33/66/100/133 MHz PCI-X
    IEEE 802.3 compliant Media Access Controller
    PCI and PCI-X bus interfaces
    on-chip buffer memory
    integrated physical layer transceiver in a single device.
    full/half-duplex capability at all speeds,
    10/100/1000 copper PHY
    Support the following 802.3 functions is featured in the MAC: VLAN tagging, layer 2 priority encoding, link aggregation, and full-duplex flow control
    - Microsoft Windows - Linux - Open UNIX 8 - NetWare
    Compatibility
    Dell PowerEdge 1600SC
    Dell PowerEdge 4600
    So yeah, it will work in PCI slot just fine.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Re: Server cards
      more on the SATA card:
      http://www.newegg.com/Product/Produc...82E16816116025
      it is one of those. also, the card said copyright 2004 on it (a 2005 model I bet)
      edit- found a .pdf on the RAID card.
      sigpic
      • mariushm
        • May 2011
        • 3799
        Re: Server cards
        The 3ware chip in the center of the card in your picture says (c) 2003 on it. Anyway, it's sort of a semi-hardware card in reality... see those 2 marvell chips at the end by the sata ports? they're kind of low end hardware sata controllers ... then you have the 3ware chip doing raid 0/1/jbod and buffers writes to ram and so on.
        It's not worth the trouble anymore...
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Re: Server cards
          isn't that the defintion of a hardware raid card? all the raid work is done by the card not the CPU?
          not to mention that it is made by 3ware and virtually compatible with any OS...
          I remember topcat had a 6 port card he swore by... I figured for $5, this card wouldn't be that far off...
          sigpic
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16959
            Re: Server cards
            the 3ware card is a nice one for an older one. It doesn't have the BBU, it seems to be before the BBU's time.... The memory is embedded on their newer cards, I haven't seen one with a module in a long time, like back in the SCSI days long time.... If you use it, make sure write caching is disabled or you'll have really bad data corruption if the system crashes or you lose power.
            <--- Badcaps.net Founder
            Badcaps.net Services:
            Motherboard Repair Services
            http://folding.stanford.edu/
            Team : 49813
            Join in!!
            Team Stats
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Re: Server cards
              see the PDF... there was a BBU option for this series of card; my card is pictured with a BBU installed.
              sigpic
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16959
                Re: Server cards
                Nice, check fleabay for one. You won't regret it, I'm sure it can be had for cheap. These are wonderful cards!
                Team : 49813
                Join in!!
                Team Stats
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Re: Server cards
                  The RAID cad is a 9500S-4LP or a 9500SU-4LP
                  (I have a dozen or so.)
                  The U means RoHS.
                  They are excellent RAID cards.
                  That's what I suggested you buy a while ago.
                  It's full hardware RAID and (if it will physically fit) it works fine in a standard 32-bit PCI slot.
                  The part that hangs out in space is only used in 64-bit mode and won't affect 32-bit operation.
                  [I'm currently using some in Abit IP35-E boards.]
                  It's the last 3Ware PCI-X card that is dual voltage.
                  [That's why I have so many]
                  The next series was 9550 which are 3.3v only so those don't work in standard PCI slots.
                  Using the BBU requires a daughter card in addition to a battery.
                  The batteries alone are cheap.
                  The BBU daughter cards usually run around $100 or so lately. [Way more than the RAID card...]
                  The BBU isn't really needed unless you're in the habit of having brown-outs or black-outs -and- you don't have a UPS.
                  Mann-Made Global Warming.
                  - Dr Seuss
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Re: Server cards
                    Since I have no gigabit switches or the like or extra SATA HDDs, the cards will sit for now... If I thoght I could get something decent for them I'd consider selling them...
                    sigpic
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16959
                      Re: Server cards
                      If you're going to part with that RAID card, I'll take it
                      Team : 49813
                      Join in!!
                      Team Stats
                      • Kemer
                        Graphics Card mounting frame
                        by Kemer
                        Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
                        As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
                        I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
                        What worries me right now is the possibility that...
                        09-14-2024, 08:57 AM
                      • FZG
                        EVGA Nu Audio Sound Card - Not Working
                        by FZG
                        I have an EVGA Nu Audio sound card that is not working properly and I need some help diagnosing the fault (preferably by someone who owns this card and is willing to take some measurements).
                        The card sort of powers up (LED lights are coming on and the relais is clicking, some voltages are present) but it is not detected in Windows. I tried installing in two different PCs and tried several driver versions but the card was never detected anyway. So I thought this is probably not a driver / software-issue and then disassembled the card to take some measurements.
                        I found...
                        03-07-2025, 11:44 AM
                      • benwaterson
                        Gigabyte Aorus 1080ti - card not initialising
                        by benwaterson
                        Hi there.
                        Have searched various forums but haven't come across the exact issue I am having.
                        Bought the 1080ti with a fault (randomly shutting down, black screen , fans full speed etc). Previous owner had replaced thermal pads but many were too thick on inspection.
                        I tested the card in windows, all loaded up ok. Put some load on the card and it crashed. GPU was reporting 92 degrees C at the time.
                        Switched the stock cooler out for an AIO water cooler from my 1080 FE, booted the card back up - temps were much better and allowed some load to be applied...
                        02-05-2022, 11:42 AM
                      • omega
                        Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
                        by omega
                        Hello all,
                        as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
                        Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
                        02-09-2024, 03:34 PM
                        Alcor AU6368 USB 2.0 Flash Memory Card Reader Datasheet
                        The AU6368 is an integrated single chip memory card reader controller specially designed for notebook, hand-held and other PC peripheral devices, which require fewer components for small PCB area. It supports a widely used flash memory card such as CF, MD, SMC, xD Picture Card, MS, MS Pro, MS Duo, SD and MMC. It can be used as removable storage disks in enormous data exchange applications between PC and PC or PC and various consumer electronic appliances.
                        The AU6368 reads digital content saved on memory card that user captured with the portable device such as notebook, digital camera,...
                        10-23-2024, 03:26 AM
