Dell 1800 Issues
  • AlanKilian
    • Dec 2011
    Dell 1800 Issues
    Hi. I've got a Del 1800 FP that won't even show a power LED on the front panel.
    I read +5.98 and +13.67 out of the power supply. The +13 varies around a lot,
    so I'll get a scope on it and see what I can see.
    All caps look "non puffy".
    My main logic board looks different than the ones people have posted about
    in the past, so I'll keep looking around and see what I can find.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Dell 1800 Issues
    Moved from the new member intro thread.
    anyway, looks like you have a PSU issue, since there is no 13v rail. there is a 12v rail, so 13.67 is pretty high (unless you meant 12.67).
    voltage fluctuations are not so much of an isssue, its the ripple.
    caps don't look bloated? what brand? if they say KZJ (or the other bad ucc series, which I can't recall at the moment) on them, then bloated means nothing, as they often dry out w/o bloating.
    last uploading some pics of the board and psu guts would be very helpful.
    sigpic
    (Insert witty quote here)
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • Sathsul
      Dell Latitude 5431 issues with dumping bios
      by Sathsul
      So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
      The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
      However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
      10-28-2025, 07:49 AM
    • mamado mosa
      Slow boot dell latitude 5410 laptop issues
      by mamado mosa
      So i had this laptop dell latitude 5410 10th gen, good condition and new ssd and 16 gb ram .
      The problem is it takes more than a minute to boot ..
      The boot sequence starting with a 30 sec black screen and the the dell logo for 20 and when the windows start loading it takes like 7 sec .
      Can someone suggest something to fix
      06-19-2025, 06:55 AM
    • JKetcham
      Dell 3100 Chromebook Power issues
      by JKetcham
      Hello, wanting to see if anyone has any experience with Dell 3100 Chromebook's and might have some input on an issue I've been seeing with them.
      I work in Technology for a good size school district, and we've began to switch away from Lenovo Chromebooks over to Dell 3100. I like the Dell 3100's because they seem to be more durable than the Lenovo N22's, N23's and 100e's we've used in the past.. but my main complaint with them is they randomly won't turn on.
      Currently, in my building I have about 200 students using the Dell 3100's and daily I have a rash of students...
      05-04-2022, 11:31 AM
    • coputerdiscount
      Dell XPS 15 7590 - Part 2 - USB power issues
      by coputerdiscount
      So back on my first post I had a water damaged Dell XPS 7590 which I was able to repair:
      Dell XPS 15 7590 - Powers via USB-C but not AC (missing PS_ID?) - Badcaps
      Which leans me into a new problem I wanted to start a new thread with.
      This machine now has issues powering or taking power (usb-c/lightning) via its USB ports.
      Symptoms: When a dock is attached, it tends to short out devices attached and does not function, when using a USB A port elsewhere on the laptop, they notify windows of a surge and tend to power cycle the attached device.
      01-23-2024, 03:59 PM
