General Capacitors to Stock...
  • Welch
    • Dec 2011
    • 9
    So I live in Alaska, and having things shipped to me each time I need them isn't exactly the most effective or economical way to do things. Instead I'd rather have some caps in stock just in case I need to replace a onesy twosy. I've often gotten systems in that use like 2 caps on the entire motherboard that are completely different from others and they are the ones that show the bulging signs. Replacing them often brings a board back from the dead.
    So I was curious if the veterans among you have a list of common capacitor sizes you recommend keeping around the shop that are often used on boards. I've noticed too that the diameter isn't nearly as important as some places make it out to be, i've never had issues with room (with the exception of this PSU i've been working on).
    My own personal note is that 6.3v/1000uF are very common, having a good 50+ of these probably wouldn't hurt. Any other sizes that are very common... say 10v/1500-1800uF?
    Id like to have enough of the right caps where I can not worry about having to order out for more but once in a blue moon.
    P.S...... also there are lots of brands on the badcaps.net store, I realize that they try to only carry high quality brands (i've used both Rubycon and Samxon) but for instance on the 6.3v/1000uF ones, there are about 10 different choices, some look to be identical short of their model "number". I'm assuming some of those are higher end with a longer expected life, any insight into which to choose? these are mostly used on motherboards, perhaps the occasional LCD....
    Thanks Guys
  • mariushm
    • May 2011
    • 3799
    Re: General Capacitors to Stock...
    In monitors, I see most of the times 470uf, 820uf, 1000 or 1200uF ... 25-35v (even though the psu is 5v or at best 12v)
    For computers, I would think 16v (for 12v coming into the boards) and 6.3/10v for 5v or lower areas would be the most common. 820 to 1500 seem to be common values for capacitors on motherboards.
    I've stocked on Panasonic FM/FR and Nichicon HM/HN.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      16V 3300uF 10mm, for Antec and other computer power supples...
      • retiredcaps
        • Apr 2010
        • 9271
        Motherboards
        1000uF 6.3V
        1500uF 6.3V
        3300uF 6.3V
        LCD
        22uF 50V
        47uF 50V
        1000uF 16V
        1000uF 25V
        470uF 25V
        PS - try to get the smallest diameter possible for fit reasons
        3300uF 16V
        2200uF 16V
        1000uF 10V
        47uF 50V
        --- begin sig file ---
        --- end sig file ---
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16959
          Add 2200uF 6.3v, 1800uF 6.3v, and 1500uF 6.3v for motherboard stuff.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5045
            • US
            yeah i've seen a bunch of 1800 6.3's on input vrm, and a few 1500-1800 16v's too, but not as often, but...often enough
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Need some 16v caps for mobos.
              For screens it's best to go with 35v [works for both 25v and 35v].
              You also have to have some uF/volts combos in different diameters.
              If you don't work on the same thing all the time you could easily have 50 to 100 sizes stocked and -still- not have everything that comes up covered.
              [I know this because I stock that many sizes.]
              Not sure why you think you have a problem anyway.
              I've bought stuff from Alaska several times [5? 6? maybe] and it usually gets here in 4 days +/-1 via USPS. [Priority mail or not.]
              Shipping to Alaska takes about the same.
              Frankly, because of Customs, it takes much longer to get things to/from Canada than it does to/from Alaska.
              Mann-Made Global Warming.
              - Dr Seuss
                After all of...
                07-13-2024, 08:14 PM
              • dragon3x
                by dragon3x
                power on.
                Here are some examples :
                switching supply area).
                than 6.3 V.)
                03-21-2025, 02:46 PM
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
              • Cama
                Solar Inverter - SMH-II - 2 missing capacitors
                by Cama
                I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
                My model is : EASUN SMH-II 7 KW
                Mother Board : P/N 18947-002401250250
                Maybe the EASUN SMH-II 4.2 KW have the same capacitors
                Thank you...
                09-12-2025, 02:50 AM
              • Ady2017
                Are there any datasheets available for Elna RJG capacitors?
                by Ady2017
                I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                05-25-2025, 02:19 PM
