Motherboard good or dead?
  • Phaihn
    • Jan 2009
    • 842
    how do i find out for sure if a motherboard i have is good or not..
    i got a board that when i power it up the cpu fan goes to max the light on th e board light up but i get no post and this board doesnt look like theres anything wrong with it.
    My Computer.
    AMD APU A4-3300 2.5ghz 1mb cache
    Motherboard GigaByte GA-A75M-S2V
    Kingston HyperX Blue DDR3 8GB (2x4GB)
    SB Audigy 2 ZS [B800] Sound Card
    500GB WD Caviar® Blue™
    1 Terabyte WD Caviar® Black™
    2 Terabyte WD Caviar® Black™
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Motherboard good or dead?
    It would help if you listed the model. Some boards have the nvidia bga problem.
    --- begin sig file ---
    --- end sig file ---
    • Phaihn
      • Jan 2009
      • 842
      p4p800-vm/s
      My Computer.
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Make sure your CPU is supported, that you're RAM is good, and your PSU is properly hooked up (remember the 4-pin CPU power connector)
        • Phaihn
          • Jan 2009
          • 842
          every thing was good cpu memory power connectors.
          My Computer.
          • retiredcaps
            • Apr 2010
            • 9271
            Originally posted by Phaihn
            p4p800-vm/s
            Welcome to the club. I got this for free, but haven't started on it yet due to lack of a good solder station. See
            https://www.badcaps.net/forum/showthread.php?t=16928
            • Phaihn
              • Jan 2009
              • 842
              think i found my answer online looks like someone tried to flash the bios .. in windows.
              http://www.tomshardware.com/forum/15...t-bios-upgrade
              My Computer.
              • howardc64
                by howardc64
                Problem
                08-04-2024, 10:36 PM
              • k370
                Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
                by k370
                I have a NM-A321 board that is dead, with no power at all.
                When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
                With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
                • +3VALW
                • +5VAUX
                • 1.2VSUS_PWRGD
                • 3VALW_PGD
                • 1.05VAUX_PWRGD
                Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
                The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
                09-23-2024, 11:57 AM
              • ohren
                by ohren
                09-08-2023, 05:24 PM
              • master_haze86
                A1990 820-01814-A dead not charging - need help with diagnostics.
                by master_haze86
                Good day everyone,
                Let me preface this with letting you know that I have a smalltime computer repair shop but do not have a lot of experience when it comes to board diagnostics. I am good at soldering etc but finding the issue if there isn't an obvious burnt component is not my strong suit.
                The other day I got a customer come in with a macbook A1990 (motherboard 820-01814-A) that would not turn on and had previously been getting the warning message that the battery needed servicing. (Most folks seem to ignore that message, just like the check engine light in vehicles.)...
                09-13-2025, 06:01 PM
              • esqmooo
                HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
                by esqmooo
                Hello everyone.
                This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
                Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
                Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
                I tried long pressing on the power button, after several seconds it would go off then when the button is released...
                03-11-2025, 03:57 PM
