NLS Data Missing
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    NLS Data Missing
    There was a power outage. Win Server 08 installed on a 40G Seagate Drive.
    Won't boot. WHY???
    First try turning it on after outage: SYSTEM DISK NOT FOUND PRESS ENTER TO REBOOT
    2nd try: windows started loading like normal then BSOD (something about video driver initialization)
    3rd try: NLS Data Missing...
    Bad drive?
  • mockingbird
    • Dec 2008
    • 5488
    Re: NLS Data Missing
    Boot into the recovery mode and run Chkdsk /F on the drive. If you do a sector-by-sector scan, it will tell you if the drive is failing.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      I can't boot into Safe Mode.
      And my fucking SeaTools CD doesn't seem to work. Man, this is frustrating!
      • dumpystig
        • Jul 2011
        • 485
        Bad day, Shovey?
        System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFP
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          Pretty much, lol
          • dumpystig
            • Jul 2011
            • 485
            You sorted your probs yet?
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              I replaced the drive and did a clean install of Windows Server 2008. So far so good I haven't tried to get the data from the other two drives in the server yet tho...
              • Mad_Professor
                A Mech Warrior
                • Feb 2011
                • 1587
                is it sata or ide?
                did you replace ide cable? I've had cables do that.
                • seanc
                  • Nov 2008
                  • 1319
                  Is this your 'dodgy' 40GB Seagate drive?
                  Use MHDD to check the SMART attributes - it's probably a pending sector, so just do a scan with REMAP set to on.
                  • shovenose
                    Send Doge Memes
                    • Aug 2010
                    • 6575
                    It's not the known bad one... even though yes it's a 40GB Seagate.
                    Thing is, I know I had a few bad Seagate drives around, except I forgot to mark them and over time they must have ended up in the good drive pile... this could be one of those. I'm going to scan this one when I get a chance...
                    • eltano4i20
                      [HELP] SAMSUNG NP270E4E-K01AR
                      by eltano4i20
                      1) Error trying to enter the BIOS
                      --> [F2] won't let me enter the BIOS. To enter the BIOS, I had to create a shortcut and then type C:\Windows\System32\shutdown.exe /r /fw /t 1 in the destination. This forced it to restart and enter the BIOS.
                      Once inside, I went to the BOOT menu, but, surprise, it wasn't there. I got the following message:
                      BOOT PRIORITY ORDER (img-05)
                      1- Windows Boot Manager
                      2- SATA HDD
                      3- NETWORK
                      4- Debian
                      2) Error trying to access the BOOT MENU
                      --> I restarted the notebook and pressed [F10] but the BOOT...
                      07-04-2025, 12:39 AM
                    • welcometoo
                      acer nitro 5 AN515-55 no display / caps lock
                      by welcometoo
                      Hi brothers, please i need help diagnose acer nitro 5 no display issue.
                      model: nitro 5 an515-55
                      motherboard part number: GH51M LA-K862P Rev: 1A
                      i received this laptop with a short in power line, it was a capacitor + a mosfet on VCORE line , the laptop turned on cpu and gpu getting warm all voltages seem ok except vcc_gt but no display/caps lock activity also no hdmi out.
                      i flashed new bios also ec(ene kb9022) the same result .
                      disabled discrete graphics (rtx 3060 ) by cutting its power and shifting a resisror near pch VCC_GT comes but still the same...
                      07-05-2025, 11:11 AM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • theflyingsquirrel
                      Samsung Chromebook Pro missing 1.2V power rail and no boot
                      by theflyingsquirrel
                      I am trying to repair my Samsung Chromebook Pro. There is no boot. Upon turning on, the screen is blank and there is no backlight. Power LED is blue. I tried refresh with power and esc refresh with power with no avail.
                      When I measure the 1.2V rail, it is pulsing. It will jump from 0 to 1.2V then 0 again. I replaced the 2 MOSFET and even power management IC and it is the same. Resistance from midpoint between mosfet to ground is 0.5 kOhm but it will show 250 Ohm first before jumping to 0.5 kOhm. So it feels like it was charging up some capacitor. Since MOSFET and IC was replaced, I...
                      06-11-2025, 08:11 AM
                    • DynaxSC
                      MSI PRO Z690-A DDR4 (MS-7D25) - stuck during boot every second time - debug code 16 & A1
                      by DynaxSC
                      Hi Folks
                      I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
                      Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works
                      09-29-2024, 04:27 PM
