Dell Dimension B110 in depth review
  • gg1978
    • Dec 2004
    • 431
    Just got a Dell Dimension B110 (2.53Ghz Celeron D, 256M DDR400,80G HD, DVDROM/CDRW, 15" LCD" for $345 shipped to my door..
    I chose the 15" LCD option as i already have a 173FP, so i went with the 156FP option instead, to knock $50 off the price. Honestly, the 156FP looks like a 2001FP, just baby sized.. Has a nice crisp picture, with good colors, for a small analog 16mS LCD anyway..
    As for the B110 itself:
    It's got an Intel OEM i865GV motherboard, with Sanyo Oscon's, United Chemicon, and Sanyo caps on it.. I doubt if this little guy is going to have cap problems..
    No AGP slot obviously, but that's true for all 865GV boards. It's standard microATX, so it's easily changed out if desired, the only non standard connector is the one for the front panel audio, and even that could be rewired. I dropped another 256M DDR400 module in to bump the RAM to 512M and enable dual channel mode, which the BIOS reports. Motherboard has the ICH5 southbridge, so there's a pair of SATA connectors if you feel like replacing the stock ATA/100 drive. The board should be capable of operating 800FSB northwoods as well as some of the Prescott core chips..
    The 80G Drive i received in my B110 was one of the new black cased Western Digital 800BB's, with 2M cache. Seems passibly quiet, and decently quick. The CDRW/DVDROM is a Toshiba/Samsung drive, which is quite good enough for a system in this class..
    The one thing that really stood out is that this little guy has a solid 250W Delta NPS series power supply, which is quite nice for a budget class system.
    Like i said before, if you don't like the integrated graphics in the 865GV, putting a PCI vidcard in is possible, as well as a motherboard swap..
    The USB keyboard included is quite nice, though i don't care much for the non-optical USB mouse included, though a optical Logitech was a $20 option.
    System only has an additional 92mm Nidec Beta V thermistor controlled cooling fan, with a duct over the large passive heatsink on the CPU. Even with Prime95 cranking away, the air coming out of the 92mm grille is just lukewarm..
    Most annoying part was cleaning it's OS image up to remove the crap that OEM's like to have at startup, though none of the programs removed gave any trouble uninstalling. If i were lazy, i would have just burnt the drivers folder to CD and loaded an XP Pro image on it, but i wanted to operate it with the stock XP Home image first.
    Verdict:
    Quite a nice little box for web/office/music/mom box.
    Performance/gaming enthuiasts wouldn't be quite happy with it, though it can be upgraded to be a nice little LAN gaming box with a new motherboard.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Dell Dimension B110 in depth review
    At first glance, I thought this was spam!
    Thanks for the writeup.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      $345 is a great price with lcd. impossible to compete with that building from parts. intel are great boards, very stable.
      no agp/pci-x is poor but depends on the use of the computer whether it is an issue.
      I saw Lenovo are using ECS in their new own brand cheap desktops. will they be able to compete with dell?
      • gg1978
        • Dec 2004
        • 431
        I think it's a decent little box for less than $350.. Of course with i865GV integrated video only, that's its biggest limitation, and one that can be worked around. I'd certainly take an Intel OEM board over an ECS anyday.. Though ECS isn't bad if you don't expect much, and only want a working system at the lowest possible motherboard price. Of course you have less quality components on the board too, so then again you get what you pay for..
        I wonder how much the OEM i865GV board is, in "Dell" quantities??? The Oscon caps are the latest SP series, i believe there's 8 or 10 of them, all 560uF, 4.0VDC rated..
        • SwedishDiesel
          Dell Dimension PSU Compatibility - B110 PSU in 4550
          by SwedishDiesel
          Howdy folks,
          I've risen from the grave to ask more questions about old obsolete Dells.
          I've acquired a Dell Dimension 4550 which is in need of a PSU - I've several PSUs from Dell Dimension B110s, and I'm wondering if one of them could be used. The PSUs and the 4550 use a 20-pin connector and a 4-pin connector.
          The issue is, I've been told that Dell really likes using proprietary hardware, and there were concerns about damage being caused by an incompatible supply. Because of this I'm assuming it's not just a simple plug-and-play and that there's more...
          12-18-2022, 06:58 PM
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
          Dell Dimension 8200 Schematic
          LA-1221...
          10-04-2024, 07:48 AM
        • master3112
          by master3112
          07-29-2025, 01:55 PM
        • F R 2568
          Dell Latitude 5420 does not start (no post) need help to find the reason why
          by F R 2568
          Hello all,
          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
          If the laptop is only connected to the AC adapter (battery removed):
          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
          The power/battery...
          01-08-2025, 05:45 AM
