Memory keeps going out
    I have a Compaq CQ60-215DX Running Windows Vista. Also has AMD Athlon-x2 64bit and Nvidia Graphics card. Having problem with memory going out. I replaced it about a month ago and now has gone out again. Has anybody heard of this problem before. Also computer has a bad battery can this be the cause.
    Alan
    Re: Memory keeps going out
    By "memory going out" you mean dying RAM?
    Check the RAM voltage regulator, it may be overvolting them.
      Bad power supply.
      veritas odium parit
        Originally posted by Toasty View Post
        Bad power supply.
        I second this. Also check for bad caps on the motherboard.
          CQ60 is a laptop, making bad caps unlikely.
          I've seen a few HP laptops with AMD chips where the CPU memory controller is going bad. This usually results in one bad memory slot. If you put the "bad" memory in another computer, does it work? If so, try replacing the CPU, which contains the memory controller.
            You were correct one memory slot is bad. Not sure replacing CPU is within my abilities. Works ok using one slot. Should I try to replace CPU or just leave like is.
              is the CPU soldered on? Or in some sort of socket?
                Sorry, off topic, but, hey Shovey, hows the new toy?
                System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFP
                  I have not opened case so I do not know.
                    I would suggest that should be your next move, but somehow I get the feeling you're not comfortable or experienced with doing stuff like this...?
                      replacw the cpu. it sounds harder than it is... just make sure you have an empty egg carton to organize your screws.
                      this is also a good time to clean out the cooling system... they often get clogged with dust.
                      according to google images, it uses a socketed cpu.
                      sigpic
                      (Insert witty quote here)
                        Can anybody tell me where I can get an inexpensive CPU it shows to be AMD Athlon Dualcore QL-62 2.00 GHZ 32 bit.
                          I can't find the service manual on HP's site anymore, but you can download a copy here:
                          That gives you pretty good directions for how to disassemble and replace the CPU. I'd strongly advise you to label your screws, and not rely solely on the manual as I've found HP's manuals sometimes give incorrect screw sizes.
                          That CPU is no longer in production. eBay is probably the easiest way of finding a used pull.
                            Are there any new CPU's that will work in this motherboard.
