FM's at Mouser vs. HE's at Future Electronics.
  • Evil Lurker
    Warranty Voider
    • Feb 2011
    • 454
    It seems as though FM pannies are pretty much jellybean when it comes to SMPS output filtering caps. Problem is the darn things are very expensive from Mouser plus you have to buy a ton of them to get the price break.
    The thing is HE nichicons can be had at almost a quarter of the price at Future Electronics. The kicker is the ripple current rating on the HE's is too low to mach the crap caps specs on most applications. Now if they had HD's it would probably be a good fit but unfortunately they don't carry them.
    Can I get away with going up in capacitance to the next size made in the same voltage, or should I go up in voltage and keep the capacitance the same to meet or exceed the ripple current ratings of the cap being replaced?
    Don't get me wrong I think pannies are great, its just why buy them when you can get three caps that will work in a pinch for the price of one?
  • mariushm
    • May 2011
    • 3799
    Re: FM's at Mouser vs. HE's at Future Electronics.
    Why don't you get from Digikey, since you're in US ?
    Prices get pretty good when you're buying a minimum of 50 or better.
    Usually as you go up with the voltage, the ripple and impedance are better but it's not always 100% true.
    I'm not sure what to say about going up in capacitance.
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      no, go up in voltage keep capacitance the same. Match or exceed ripple and ESR values and be sure it can fit on the pcb.
      I'm not experience enough to tell ya about changing capacitance, but from my low knowledge I think you could change the capacitance but you would have to figure out/eliminate un-needed caps. If the circuit requires a cap there to complete the circuit or not. If it does, could a jump wire to the replacement cap work? or does the circuit need several caps to filter/smooth out the ripple. But I could be wrong. *Waits for someone to yell "HEY STUPID!"
      IMO the HE are too low. Have you try at digikey for HD?
      • brethin
        • Dec 2008
        • 1907
        Going up in votage is fine.
        Going up in capacitance a small amount is sometimes ok, but avoid it if at all possable.
        Always match or exceed ripple.
        Always match or go lower on ESR.
        As for can size I tend to use the largest that will fit.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          KZE = HD and Digikey lists both.
          Mann-Made Global Warming.
          - Dr Seuss
          • chth96
            Is it no harm to replace with capacitor without ripple current rating?
            by chth96
            When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
            Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
            But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
            Rubycon YK DataSheet (b...
            04-19-2024, 05:19 AM
          • SwedishDiesel
            Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
            by SwedishDiesel
            Howdy folks,
            I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
            10-30-2021, 12:47 AM
          • Antonynl
            What are typical ripple voltages on a laptop motherboard?
            by Antonynl
            I have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
            So I have two questions:
            1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
            2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
            Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....
            12-09-2022, 06:51 AM
            by momaka
            03-15-2023, 10:17 PM
          • JohnsonJ
            Allen&Heath XONE92 DJ mixer repair
            by JohnsonJ
            Hello everyone.
            I'm having issues with my DJ mixer, and after taking it apart and checking everything out, it seems that I need to replace 2 rotary potentiometers for the filter, and that the PSU has some caps burned. Hopefully these 2 fixes will solve my issues.
            The potentiometers I will just replace (hopefully the repairman I spoke with will indeed send me the spares, in case he doesn't, I'll update here if we can find a suitable replacement), but for the PSU caps I'd kindly ask you forum members, if anyone could help guide me in the right direction. I'm having difficulty...
            12-12-2020, 11:19 AM
