32 bit card in 64 bit slot=power fault?
  • Maxxarcade
    • Jul 2006
    • 973
    I've been fixing up an old Proliant DL380 G3 to use as my new security DVR.
    The problem is, my DVR card causes the system to say "power fault detected in PCI slot 2". The card has both notches, so I figured it would work on 3.3v PCI-X. Guess I was wrong.
    If anyone can find me a 3.3v compatible DVR card, I'd be eternally grateful. Otherwise I'll need to sell this system at a loss. I have about $250 into it. I installed 6 brand new 73GB 15k RPM hard drives and a new cache battery module. It runs great, but I can't use it unless I can find a compatible card.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: 32 bit card in 64 bit slot=power fault?
    What is the card?
    The 'words' for the spec card you are looking for:
    PCI v2.1 is 3.3v and 5v compatible.
    PCI v2.3 is 3.3v only.
    PCI v2.1 is sometimes called 'universal'.
    If it's v2.1 specification compliant it should work with either voltage.
    Mann-Made Global Warming.
    - Dr Seuss
    • Maxxarcade
      • Jul 2006
      • 973
      Originally posted by PCBONEZ
      What is the card?
      Just a generic Fusion 878A based card with 8 inputs. I looked at the data sheet, and the 878a is 5 volts. The 23881 on the other hand is 3.3v. I just bought a card with one of those chips, but the seller just told me that it doesn't work with Ubuntu. I just can't win.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        HP says the mobo is PCI v2.2 compliant.
        Should work with either voltage.
        Perhaps the problem is the mobo slot won't kick-down to 32-bits and/or 33MHz to accommodate the card.
        HP might do something weird like that on a server.
        Check the BIOS for slot related settings.
        - Dr Seuss
        • Maxxarcade
          • Jul 2006
          • 973
          The thing is, there were no voltage conversion circuits on the card. So it wouldn't have enough voltage to operate regardless. The 878a chip is 5v only.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Slots 2 and 3 are on the same PCI-X bus so if you have cards in both of those slots the two cards will have to be capable of operating at the same MHz and #-bits to work at the same time.
            - Dr Seuss
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              They don't convert the voltage on the card.
              That spec PCI-X slot has both 3.3v and 5v pins available from the slot.
              - Dr Seuss
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                I vaguely remember [not from here] someone having the same trouble running a 32-bit/33MHz card in one of those servers before only that time it was a RAID card.
                - Dr Seuss
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  BTW: The 3.3v and 5v they speak of is the signaling voltage, not the card power voltage.
                  - Dr Seuss
                  • Maxxarcade
                    • Jul 2006
                    • 973
                    I guess I will just sell the server, since I just got refunded for the new card I was going to try. Really a bummer, because I wanted a DVR with fast hot swap drives :-(
                    I'm gonna be so mad if I can't get back what I put into it. I've been losing money like crazy on little things like this the past few months.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      You could try the HDHomeRun route. No slot needed.
                      Depends on what you are trying to do exactly.
                      - Dr Seuss
                      • Maxxarcade
                        • Jul 2006
                        • 973
                        Just looking for a good real time, networked 8 channel security DVR that doesn't cost more than my whole server rack is worth basically.
                        Now that I think about it, I probably should have tried that other card anyway. So what if I would have had to use Windows on it.
                          ESR meter came to the rescue again today with a PLC I/O card fault
                          by sam_sam_sam
                          I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
                          I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
                          One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
                          12-18-2023, 08:17 PM
                        • Kemer
                          Graphics Card mounting frame
                          by Kemer
                          Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
                          As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
                          I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
                          What worries me right now is the possibility that...
                          09-14-2024, 08:57 AM
                          HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook Specification for Upgrade or Repair
                          This specification for the HP 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) boardview and 14-am047tx + 1 YR Full Standard Extended Warranty + McAfee Scratch Card 1PC User (1 YR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon...
                          09-06-2024, 08:30 AM
                          Alcor AU6368 USB 2.0 Flash Memory Card Reader Datasheet
                          The AU6368 is an integrated single chip memory card reader controller specially designed for notebook, hand-held and other PC peripheral devices, which require fewer components for small PCB area. It supports a widely used flash memory card such as CF, MD, SMC, xD Picture Card, MS, MS Pro, MS Duo, SD and MMC. It can be used as removable storage disks in enormous data exchange applications between PC and PC or PC and various consumer electronic appliances.
                          The AU6368 reads digital content saved on memory card that user captured with the portable device such as notebook, digital camera,...
                          10-23-2024, 03:26 AM
                          Postcard 32 4-Bit 4-Digit Diagnostic Card PC Analyzer Manual
                          Diagnostic Card is a powerful diagnostic tool for technicians and administrators to troubleshoot
                          various problems of IBM compatible PCs. It is easy to install, yet extremely powerful to use. With
                          Diagnostic Card in hand, you no longer have to go through tedious and time consuming process of
                          trying to figure out what is wrong with your PC hardware. Diagnostic Card will tell you exactly
                          what is wrong with your PC in just seconds. It saves you time and money.
                          Our new and improved design...
                          11-01-2024, 06:29 AM
