Ask the Guru's: Removal of Recovery Partition - Vista to Windows 7 upgrade?
  • Toasty
    • Jul 2007
    • 4171
    I have a Toshiba Satellite L355-S7831 laptop that came in with major system problems and would not repair itself. Turned out the hard drive, a Hitachi 5K320-250, was failing and after several runs (days!) of HDD Regenerator, it finally settled down.
    With Vista (Home Premium) being the pig it is, I went looking and found a Toshiba Windows 7 Ultimate .iso, with SLIC 2.1, and installed it. The system ran much better, but there was still the failing disk to worry about.
    Located a comparable, new, WD Black WD2500BEKT drive and used Acronis True Image Home to clone the drive. Used the files method not the sector-by-sector approach as I didn't want to transfer pseudo bad sectors to the new disk.
    Worked perfectly and several full disk checks have shown no errors. The system is also noticeably faster as the original HD was 5400 rpm and the new one is 7200 rpm.
    Now, the questions are:
    What purpose does the "TOSHIBA RECOVERY VOLUME" that is in a 1.5 GB partition at the beginning of the disk serve?
    Is it unneeded as the system is now Windows 7 not Vista?
    CAN it safely be removed (by repartitioning) without crashing the present W7 install?
    SHOULD it be removed in case there is an error and W7 tries to use it thinking it's VHP?
    Your thoughts and recommendations, please.
    Toast
    veritas odium parit
  • Perineum
    • Aug 2010
    • 30
    Re: Ask the Guru's: Removal of Recovery Partition - Vista to Windows 7 upgrade?
    That partition is bootable by hitting a qualifier key in the BIOS during bootup.
    It will boot up into a customized OS and will wipe and reinstall the laptop back to it's factory condition, including all the original crapware and trialware.
    As you have now made the smart move to Windows 7 that partition is not needed anymore.
    Typically I just format the existing HD and do a fresh install of Windows 7. In your case I would just remove the recovery partition.
    Be aware that Windows 7 makes 2 partitions by default. First one is a 100meg partition and the second is the remainder of the drive. Touching either one of those partitions will result in a non-boot scenario.
    • Toasty
      • Jul 2007
      • 4171
      Thank you for that information.
      >>Be aware that Windows 7 makes 2 partitions by default. First one is a 100meg partition and the second is the remainder of the drive. Touching either one of those partitions will result in a non-boot scenario.<<
      That's news to me...
      I have installed W7 Ult in other systems and that never came up...? I see what you are saying from the info on the web (Googled it) about it and just looked at 2 of my W7 systems (via Disk Management) and there is no 100MB partition.
      Toast
      veritas odium parit
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        I would use a bootable gparted disc to delete the unneeded partition and expand the existing one to take up the free space.
        sigpic
        (Insert witty quote here)
        • Toasty
          • Jul 2007
          • 4171
          Thank you.
          I have Easeus disk partitioning software installed.
          Will doing as you suggest, create a problem at the front of the disk for booting?
          The recovery partition is moot since I have the W7 DVD, correct?
          Any problems would be handled by inserting same for "Repair Options", yes?
          Toast
          veritas odium parit
          • yyonline
            • Jul 2009
            • 692
            Toast
            If you install onto an empty hard drive, Windows 7 setup creates the special diagnostic/boot repair partition. If you install onto an already partitioned hard drive, Windows 7 setup does not create the extra partition. The special partition is basically the same as creating a system repair disc once Windows is installed.
            Unless you want to go back to the factory OS, the recovery partition is useless. If you might want to go back to the factory OS for whatever reason, make an image of the drive first so you can put it back later.
            • Toasty
              • Jul 2007
              • 4171
              Nope. Have no intention of reverting this system to Vista.
              I'll do an image of the system onto a external drive, then delete that partition.
              Thank you!
              Toast
              veritas odium parit
              • Perineum
                • Aug 2010
                • 30
                Ahh, never noticed that upgrades / installing to partitioned drives did not make the 2 default partitions. Mind you, I build a lot more new machines than I do upgrades to Win 7.....
                • RJARRRPCGP
                  • Jul 2004
                  • 6301
                  Yes, go ahead and wipe it! It's better to wipe the HDD with MHDD or DBAN!
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • Toasty
                    • Jul 2007
                    • 4171
                    Partition removal complete. No errors. Success!
                    Thanks to all!
                    Toast
                    veritas odium parit
                    • volinakis
                      Chromebook recovery failed - how to fix it
                      by volinakis
                      So I had a Asus C433T Chromebook enrolled and after I modified bios I had to reinstall Chromium. I made a USB recovery stick with Chromebook Recovery Utility but I got "an unexpected error has occurred ..." message. I did try with another USB stick, etc. etc. -all steps found on internet about this issue and nothing worked.
                      Finally I found a site where they suggested to try with an older image and ... it worked!
                      What I did:
                      - when “Chrome OS is missing or damaged” message appeared I pressed Tab key and found: read only firmware id: Google_Rammus. xxxxx.xxx.x....
                      09-18-2023, 03:26 PM
                    • myth77
                      macbook pro a2141 can not make recovery
                      by myth77
                      So, i dont know almost anything on macs..but this is my nephews so i had to try. Its 16 inch macbook pro from 2019...It all started when he left something on the keyboard when closing the mac and there it was the crack on screen. At first it was like working but later no. After that he told me that it wouldnt power on?...hear fans but nothing..tried like 100 of stuffs but nothing helped.
                      So, he bring it to me...first i open it and figured he did also. there was lots of dust i cleaned everything...and started it...the broken screen showed only backlight but nothing on the screen. I...
                      06-19-2022, 11:21 AM
                    • ugamazing
                      820-00850 & 820-01949, No WiFi *In Recovery*
                      by ugamazing
                      I've got two boards with the exact same issue, and it's confusing the hell out of me. In short:
                      1. Both boards behave *exactly* the same; they will show WiFi networks to connect to, and will boot fully to Internet Recovery, but they each show zero available WiFi networks once booted to Internet Recovery. I also cannot switch WiFi "off", as in, the toggle will not move.
                      2. Both boards will erase perfectly fine using the "erase mac" function; I can wipe them with disk utility, but if I try to install MacOS from Internet Recovery, it says to connect...
                      01-25-2023, 05:39 PM
                    • TimScrawn
                      MDM removal on 16 inch 2019 A2141 MBP & 15 inch 2018 MBP A1990
                      by TimScrawn
                      Hi there,
                      This is my first post. I just wanted to come here to get a clear answer from some people about MDM removal on the 16 inch 2019 A2141 MBP & 15 inch 2018 MBP A1990. I have seen a lot of things on MDM removal, and wanted to know exactly what is needed to remove it, and what the best option is in 2024 when running Sonoma.
                      I know that Checkm8 have an MDM removal service now, that seems to be a permanent removal. I also have heard you can remove the T2 ROM and use a programmer to read the data and change the serial number. Im not 100 percent sure if this is a...
                      06-23-2024, 09:41 AM
                    • alfredposadas09
                      cant enter recovery mode lenovo c13 yoga chromebook
                      by alfredposadas09
                      cant enter recovery mode lenovo c13 yoga chromebook try esc+refresh+power at first scenario i was able to enter recovery mode but it was failing to reinstall os .. i try to change ssd and when i try this i cant enter recovery mode now...
                      11-09-2024, 10:09 AM
