Problem with Dell Inspiron 530S Cannot do dual channel, even with matched RAM
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Even when it's a 775 board! Also manufactured in 2008.
    It appeared to be fine in early August or late July!
    Now, the following will occur:
    If I try to use both channels, the BIOS will go bleep--bleep--bleep--bleep-----bleep--bleep--bleep--bleep and repeat!
    Or I just get turbo fan!
    The board only is usable in single channel!
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Re: Problem with Dell Inspiron 530S Cannot do dual channel, even with matched RAM
    Did you try each stick separately?
    A man convinced against his will is of the same opinion still.
    • Toasty
      • Jul 2007
      • 4171
      Bad Northbridge?
      Incorrect RAM voltage in BIOS?
      Noisy vCore or VRM in general from bad caps?
      Timing/speed of RAM correct for board?
      veritas odium parit
      • RJARRRPCGP
        • Jul 2004
        • 6304
        No Vcore problem and the timings are right. Also using a matched dual channel kit.
        And the PC appears to be fine in single channel.
        It cannot be Vcore if I'm able to install Vista and apply all service packs in single channel. Zero OC'ing.
        And with a bad northbridge, Windows installation should have failed, even with single channel.
        I'm been wondering if I need to reflow the solder for the DIMMs?
        The board only has a fit if I populate the other half of slots.
        The northbridge appears to be a P35.
        Arc A770 16 GB
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Bull. It's not that 2.1 V crap, and you cannot change the VDIMM in the BIOS.
          Arc A770 16 GB
          • Toasty
            • Jul 2007
            • 4171
            How about running Memtest86?
            Had a matched set of Corsair do that after 3 years.
            BIOS set to do the "full" checking on boot instead of quick?
            PS: Got another board to check sticks in?
            veritas odium parit
            • brethin
              • Dec 2008
              • 1907
              Not true windows can and often does install fine with a partial failure of the northbridge relating to memory management.
              More information would help like what speed is the memory you are trying to use have you trying lowering the speed when using both sticks. Are you installing the pair in the proper slots 1 and 3 or 2 and 4. Try a single stick in each slot 1 slot at a time.
              • RJARRRPCGP
                • Jul 2004
                • 6304
                Unless you mean just a dead channel. And I can't change any frequency.
                Interestingly, it seems I also can't populate any of the slots on the other half.
                It seems that I have to put RAM in the white-marked slot and the black one right next to it for it to boot!
                Arc A770 16 GB
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  did you try both dual channel pairs? a lot of boards require a certain slot populated first or else it goes bleep-bleep like that...
                  sigpic
                  (Insert witty quote here)
                  • RJARRRPCGP
                    • Jul 2004
                    • 6304
                    It don't matter which slot and even with the RAM that appears to be the original!
                    (Samsung of 1 GB total 512MB x 2) (Like on my Asus P5QL Pro)
                    Samsung appears to be typical for OEM.
                    Arc A770 16 GB
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      sounds like you have a bad northbridge then.
                      sigpic
                      • brethin
                        • Dec 2008
                        • 1907
                        So you are saying slots 1 and 2 work but 3 and 4 fail when you just try 1 stick testing 1 slot at a time? If that is the case then it sounds like the northbridge to me maybe a bad mosfet if you are lucky. I use this http://www.drivestar.biz/desktop-ddr...led-p-461.html its handy.
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          Interestingly, it seems that I can use both slots on one side, but not the other:
                          Like this:
                          11 00
                          And not:
                          10 10
                          Nor:
                          01 01
                          Nor:
                          10 01
                          Arc A770 16 GB
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            And it's currently like this:
                            00 11
                            Arc A770 16 GB
                            • brethin
                              • Dec 2008
                              • 1907
                              dual channel for that board should be either
                              10 10 slots 1 and 3
                              or
                              01 01 slots 2 and 4
                              checking each slot 1 at a time using only 1 stick
                              10 00 slot 1 does it work?
                              01 00 slot 2 does it work?
                              00 10 slot 3 does it work?
                              00 01 slot 4 does it work?
                              if those tests pass then test with 2 sticks at a time and try.
                              11 00 slots 1 and 2 (this is single channel mode using channel A) does it work?
                              00 11 slots 3 and 4 (this is single channel mode using channel B) does it work?
                              if all those tests pass then try.
                              10 10 slots 1 and 3 (this is dual channel mode using both channels) does it work?
                              01 01 slots 2 and 4 (this is dual channel mode using both channels) does it work?
                              • RJARRRPCGP
                                • Jul 2004
                                • 6304
                                10 10 slots 1 and 3
                                or
                                01 01 slots 2 and 4
                                11 00 slots 1 and 2 (this is single channel mode using both channels) does it work?
                                00 11 slots 3 and 4 (this is single channel mode using both channels) does it work?
                                10 00 slot 1 does it work? -> No problem found.
                                01 00 slot 2 does it work? -> No problem found.
                                00 10 slot 3 does it work? -> No problem found.
                                00 01 slot 4 does it work? -> No problem found.
                                11 00 slots 1 and 2 (this is single channel mode using both channels) does it work? -> Yes
                                00 11 slots 3 and 4 (this is single channel mode using both channels) does it work? -> Yes
                                10 10 slots 1 and 3 (this is dual channel mode using both channels) does it work? -> Failed! (usually repeated bleeping)
                                01 01 slots 2 and 4 (this is dual channel mode using both channels) does it work? -> Failed! (usually repeated bleeping)
                                Arc A770 16 GB
                                • brethin
                                  • Dec 2008
                                  • 1907
                                  Looks like a bad northbridge then im afraid. You could teats all the caps and the mosfets but my guess is they will test fine.
                                  • brethin
                                    • Dec 2008
                                    • 1907
                                    You might also try another CPU. I have seen rare cases where a bad CPU prevented memory to work in dual channel mode. But that was only on AMD cpus, never seen it happen with a intel cpu its always been a bad northbridge.
                                    • RJARRRPCGP
                                      • Jul 2004
                                      • 6304
                                      Let me guess, bad BGA on northbridge?
                                      Arc A770 16 GB
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        no, just a bad chip.
                                        sigpic
                                        • eccerr0r
                                          old X58 triple channel board... memtest86 memory speed?
                                          by eccerr0r
                                          Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                                          Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                                          Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                                          06-28-2025, 09:06 AM
                                          DELL Inspiron 3250 Inspiron 3000 i5-6400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3250 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3250 boardview and Inspiron 3250 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:44 PM
                                          DELL Inspiron 3268 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3268 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3268 boardview and Inspiron 3268 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          DELL Inspiron 3650 Inspiron i5-6400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3650 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3650 boardview and Inspiron 3650 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
