When System Restore Fails and All Drives are Inaccessible
  • ASUSP2B-D
    • Mar 2006
    • 30
    I have 98SE on the system; it was running fine NP. Then I got verizon DSL and tried to hook up their Ethernet-to-USB adapter and the system freaked out. As I tried to install the drivers for the plug-n-play adapter, Windows kept asking for both 98 and 98SE original disks. I obliged, having both CD and DVD/CD optical drives available, but inserting both these disks as requested did not satisfy Windows.
    Then both optical drives disappeared from view and access. I couldn't get them back. Microsoft support online doesn't address this problem, but the documentation there does suggest that 98SE does have problems USB conflicts. (Great, I wish I would have seen that earlier....)
    So I tried cleaning out the USB conflicts by going in in Safe Mode to Device Manager and systematically, according to proceedure outlined by Microsoft, eliminating _all_ USB drivers and devices, as well as duplicate entries and leftovers from the past nolonger in use; _everything_ related to USB, and resetting the USB stacks.
    I really thought that would correct the problem; it didn't! The optical drives appear in Safe Mode--they appear in the Device Manager in Safe Mode but the Device Manager doesn't list them at all in Normal Mode-- but each time I boot up in Normal Mode, it is as though they don't exist and I can not access them.
    Ok, so then I tried going in through DOS and doing a system restore in the registry; nope, that didn't work either. System restore operation failed!!!
    Also, I found that not only are the optical drives disappeared and inaccessable, but my floppy drive is _also_ inaccessible. While the floppy drive shows up as being there, when I try to put a disk in it, a message comes on the screen saying there is no disk in the drive, so it isn't reading.
    Does anyone have any ideas on how I can get my drives back??? I could delete them from the system in Safe Mode where they at least appear, and then see what happens...
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: When System Restore Fails and All Drives are Inaccessible
    many highspeed providers have crap software they want you to install.
    sbc/yahoo being the worst.i see many cases like yours.
    get a good router and configure it so all you do is plug into it .
    see lots of issues with usb in 9x.i would use win2k if i had to use any version of windows.
    all the features that count and none of the bullshit of xp.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      yeah plus if you get a router hopefully it was have a good firewall on it too so that is another worry gone.
      what happened with your xp install? did you give up? it was a better idea to put xp.
      personally when weird issues happen with 98 its best to reinstall.
      • ASUSP2B-D
        • Mar 2006
        • 30
        Thanks for the feedback!
        I was trying to get online w/98SE so I could run that mem test; no go. Unfortunately, I don't have the key code for 98SE readily available, so a reinstall isn't an option at the moment.
        I'm trying to stave off pulling everything apart and taking it out of the case to get a good close-up of the caps... but at this point I'm starting to wonder if it just isn't unavoidable; I've spent so much time on this already. I sure appreciate everyone's input.
        Nope, haven't given up on XP. After googling the splash screen problem I found that others have had the same problems w/XP, when they originally thought it was a hardware problem (for some people at least) it turned out to be completely the fault of OS software and after reinstalling XP things went fine. The only thing is that I'm reinstalling on the same HD, and that could be a problem, according to other's experience. Thing is, my other HDs are all taken up and I don't know about sacrificing one of them for something that may not work; I may have to.
        So I'm now reinstalling XP (trying a repair of previous installation didn't help anything) and will see if that helps anything... I'll keep you posted!
        • eccerr0r
          It's 2025: do you know where your 5¼" floppy drives are?
          by eccerr0r
          Oh wow.
          As in the other thread I was trying to revive/re-bootstrap an old Apple IIe and wasn't successful reading or writing any disk. Both drives behave similarly.
          Then I was wondering, what about my PC floppy drives? I have a HH 5¼" HD drive and a combo 5¼+3½ drive. I tried formatting the disk that wouldn't work in the Apple and it didn't work in the PC either!
          Then I tried a HD 5.25 disk ... it won't even touch the disk either! Just like the Apple DD disk, "Not Ready!"
          Weird. Seems the PC drive is having trouble clamping...
          07-07-2025, 12:49 AM
        • iMuhtaseb
          820-02020 A2338 Restore/Revive Failed
          by iMuhtaseb
          A2338 - Pristine condition.. I took out of the board and inspected it.. nothing.. as if the computer is barely used even.
          Anyway, customer said they tried erasing/formatting it and it got stuck on Apple logo preventing to go further.. I asked them why they tried to erase it from the first place? They said it turned off randomly once.. then they erased it and it worked out for a few days then it shut off again..
          I put the computer in DFU; I downloaded the latest Ventura IPSW and restored it.. during the "Installing.." it restarts then it shows the exclamation...
          09-11-2023, 08:43 AM
        • lab10.haifa
          Macbook Pro A2338 820-02020 Stuck on RESTORE MODE
          by lab10.haifa
          Good day, friends. Got this problem with M1 macbook - it starts, chimes, tries to boot and stuck with a message "support.apple.com/mac/restore"
          It works with DFU mode, but it's cannot be restored. With "revive" function - same problem. Internal restore mode doesn't work, as well as Internet Recovery.
          There is no damage on the motherboard. No short circuits.
          Could it be a NAND problem? (but usually, if NAND is dead - mac simply wouldn't turn on)
          Thanks....
          10-08-2025, 02:55 AM
        • yheriatovych
          A2338 820-02020-A 5V, no screen, unable to revive/restore
          by yheriatovych
          Hi. I need some help troubleshooting the issue (which is a bit odd to my limited experience) with the A2338 Macbook.
          Initial symptoms:
          One day the laptop refused to wake up (as it seemed at first), spinning the fan on full blast, with no picture on the screen.
          Force rebooting didn't help. To check if it boots at all I connected the external display and surprisingly it booted to the system, and I was able to log in to the system.
          However, I noticed that it was in some weird state:
          • The fan was still blasting at full speed. It's blasting even when the system
          01-31-2024, 10:22 AM
        • abajor
          A2141 DFU error message now USB C asking 20.49V and configurator says "Recovery"
          by abajor
          I have a A2141 which fails DFU with error code shown in image.
          Now instead of DFU it says "Recovery"
          A little back ground on this laptop. I was thinking of writing a topic on corporate laziness and irresponsibility.
          We acquired a handful of laptops which a very large company wanted to have shredded due to sensitive information.
          Since apple has NSA grade drive formatting I think this is inexcusably lazy that the IT department doesn't just target mode format the drives and release the MDM, and donate the laptops.
          Personally I think a large company...
          05-09-2024, 01:48 PM
