Asus PVR-416 TV Card
  • Maxxarcade
    • Jul 2006
    • 973
    Anybody know where I could find the software package for a PVR-416? It was an OEM card from an HP Media Center PC.
    I do have the drivers, but the tuner won't pick up a signal in Media Center. Radio works fine.
    What i need is the original program that would have been with it, so I can use the card outside of MCE, and also take advantage of the aux. inputs.
  • mockingbird
    • Dec 2008
    • 5484
    Re: Asus PVR-416 TV Card
    Which chipset does it use? Connexant (Brooktree), or Phillips?
    do you get input with AmCap?
    "We have offered them (the Arabs) a sensible way for so many years. But no, they wanted to fight. Fine! We gave them technology, the latest, the kind even Vietnam didn't have. They had double superiority in tanks and aircraft, triple in artillery, and in air defense and anti-tank weapons they had absolute supremacy. And what? Once again they were beaten. Once again they scrammed [sic]. Once again they screamed for us to come save them. Sadat woke me up in the middle of the night twice over the phone, 'Save me!' He demanded to send Soviet troops, and immediately! No! We are not going to fight for them."
    -Leonid Brezhnev (On the Yom Kippur War)
    • Maxxarcade
      • Jul 2006
      • 973
      It has a Philips tuner and a Conexant C23880x chipset.
      • Maxxarcade
        • Jul 2006
        • 973
        At first I got a blue screen in AmCap, then I tried some program called ChrisTV Lite. It put some crappy spyware program called Relevant Knowledge on the computer. For all the time I've spent trying to get this POS card to work, I could have bought a new HD card to replace it.
        Apparently the card is also called a Hauppage Roslyn/Blackbird.
        • mockingbird
          • Dec 2008
          • 5484
          Download dscaler, and try it with that.
          I'll see if I can find software from Hauppauge's site.
          • mockingbird
            • Dec 2008
            • 5484
            Ok, I figured out that the card comes with the HP Media Center M300 PC.
            The driver page is here:
            Link.
            It's a pretty ordinary card, should work fine with DScaler. You can try Hauppauge's application, though I don't know if it will recognize it.
            • Maxxarcade
              • Jul 2006
              • 973
              Link.
              I do have the latest driver from HP, but I can't find an application that works with it. I'll try Dscaler, but if I can't get the card to work in MCE, it's kinda pointless anyhow.
              I wonder if the WinTV PVR card in my HTPC would work with the front panel connector in the HP. Then I could get a new HDTV card for my HTPC.
              Also, the PC I'm working with is an M490n. I put a fresh install of Windows MCE 2005 on it, since the original 2004 COA on the case worked fine with it.
              • Mad_Professor
                A Mech Warrior
                • Feb 2011
                • 1587
                I have the same card.
                If you need software,
                GBPVR works great on windows.
                if you had linux on it, mythtv works flawlessly with closed captions on.
                There is a mythtv binary for windows but I think it's frontend only.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  I never did figure out myth tv... I always used tvtime for my linux tuning needs.
                  sigpic
                  (Insert witty quote here)
                  • razor_amd
                    by razor_amd
                    12-15-2020, 07:07 PM
                  • ShadowAi
                    ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                    by ShadowAi
                    Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                    Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                    After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                    03-15-2024, 10:46 AM
                  • shelby5041
                    clock radio / radio lifespan?
                    by shelby5041
                    hi
                    ive got a modern digital clock radio approx 15yrs old
                    my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                    since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                    the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                    it uses very little power just a few watts i would imagine that may have something...
                    09-14-2024, 03:30 AM
                  • kotel studios
                    Philips SAA7134 TV tuner card - requiring drivers and software
                    by kotel studios
                    Sorry if I posted this in the wrong forum.
                    As mentioned in the title I'm looking for Philips SAA7134 TV tuner card driver and software. Sadly I couldn't find anything online. Maybe someone here has them?
                    02-09-2025, 07:25 AM
                  • Rofix
                    Asus H110 M-K network card problem
                    by Rofix
                    Hello I wanted to kindly ask for advice or this Asus H110 M-k motherboard, which unfortunately does not detect the network card to connect to the internet, I checked some voltages on the REALTEK8111-CG chip, on pins 11, 23, 32 I found 3.3 V
                    Thanks to everyone in advance for any advice​...
                    11-22-2024, 05:24 AM
