MacBook Pro Hard Disck to SSD Ocz Agility 3...
Tags: None
Re: MacBook Pro Hard Disck to SSD Ocz Agility 3...
real shame they used that brand of SSD. I'm only using Intel SSDs. It may not be the fastest SSD like the OCZ, However the OCZ has a poor reliability record. They really don't get along with Dell laptops BTW. I chose Reliable over speed.
http://www.ocztechnologyforum.com/fo...rtex2-Agility2
For details. the OCZ they recommend not cloning, with the Intel I just cloned the existing drive and done Intel provides cloning S/W too. -
Then I installed on a macbook pro with 4 gigs ddr3 i5, and boots in 12 seconds. Overall performance is very good on this unit, I am very surprised and is almost at the level of intel. Perhaps the fastest I've tested with Windows for example has been the brand Kingston ... if it is true that the new intel are the creme de la creme .... Greetings fellow and thanks for your response.Comment
The Intel from my research are not the fastest. Just the most reliable. From my reading the MacBook Pro OS also does not support trim on the SSD
And yes I would say any SSD will improve the computer. I put one in an older single core and the startup time is much better and the applications load real fast. I now do not mind using it. I cloned the old drive as I didn't want to have to start over with a faster computer and set everything up again. I'm a bit lazy that way.
My Desktop I do not mind re-doing periodically. The laptop is my do anything financial computer.
With a 12 seconds boot it sure is nice isn't it.
You might want to visit the OCZ forums and look for tips and utilities to keep it running best.Comment
Thanks for the help, soys the best ... I love this forum.Comment
by envymHi everyone!
I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...06-27-2025, 08:54 AM -
by ElewaysHi
I've an Apple macbook A1707 with Hdd defect.
This product don't work with a normal Hard disk, but the hard disk it's a BGA component on the logic board.
My question is:
Can i exchange the hard disk, by desolder the bga Hard disk and replacing this?
Can i replace with a different one (es 500 gb instead of 250 gb)
This Macbook has T1 security check.
Thanks and best regards
Luca -
by Flasman90I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
- "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
- "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
...08-30-2025, 10:27 AM -
by tobeend1. RESET MACOS WITH IPSW
a. Power off MacBook, press and hold the power button to enter Recovery
b. Open Disk Utility, remove Macintosh HD
c. Reboot, connect to the network to Activate Mac.
d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
e. Release the other keys, but keep holding the Power key for another 10 seconds
f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click... -
by federalhouseHi everyone,
I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
**Background:**
I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
**What I've Tried So Far:**
1. I accessed...1 Photo - Loading...
