HELP - What kind of cable is this?
  • ethanbriz
    • May 2011
    Hello! I'm hoping someone can help me identify the cable in the photos below. I recently acquired some of these, and I have spent quite a while on Google, but haven't been able to find anything. There are no brand/model numbers anywhere on the cable or packaging. My knowledge of these things probably isn't anywhere near yours, so any information at all you might be able to give me would be greatly appreciated! Thanks!
  • Wizard
    • Mar 2008
    • 2296
    Re: HELP - What kind of cable is this?
    This looks like it is used for medical monitoring system.
    Cheers, Wizard
    • Patch2
      Cable Repair
      by Patch2
      I have a broken connector (believe it's a 6 pin mini-DIN) on a cable. The metal shroud and all but one of the pins are separated from the cable, and just stuck together for the photo. The other end is an unknown rectangular connector. The cable is for the foot pedals on an Italian made electronic piano, and the company is out of business. Looking for ideas on how to fix it. I have a soldering iron, but I'm not very skilled at soldering, so getting a retrofit for the broken end may be beyond my ability. The other end would be easier to replace, if I could get a mini-DIN cable with the same number...
      01-02-2025, 06:04 PM
    • Tr0ll
      by Tr0ll
      Original T-con:
      First replacement T-con:
      10-07-2023, 07:48 PM
    • conghuyms
      I need datasheet cable eDP LCD 30 pin slim pls help me!
      by conghuyms
      My 30-pin eDP cable from the mainboard to the LCD screen got cut and damaged at the screen connector side. I found another cable and took the screen-side connector from it, but the wire colors are different. So I really need the wiring diagram for both ends of the eDP cable to solder it back properly. If anyone has the diagram, please kindly help me out. Thanks a lot...
      08-22-2025, 11:16 AM
    • fweonea
      HP-Pavilion x360 Laptop Dead After USB-C Cable Connection
      by fweonea
      While at university, I connected my HP-Pavilion x360 14-dw0156ng laptop, running Windows 10, to a monitor using a provided USB-C cable. Immediately after this, my laptop's screen turned black and the device stopped working entirely. There are no signs of life such as fan noise or LED indicators, holding the power button does nothing. I've previously used this same monitor model and cable without issues, the cable typically charges the laptop as well.
      I've attempted holding the power button for over 30 seconds, removing and reinserting the battery, and trying to power it on with only the...
      01-16-2024, 11:35 AM
    • marce002
      Help me make charger USB C cable with no cc pins!!
      by marce002
      Hi all, please
      I just want to make a "usb c" charging cable from 5V power supply (have cut cable w/ red black green and white pins connected from factory.... i just want to use 500mah max !
      How do I connect this ? if I do not have CC1 /2 physically wired, how to proceed?
      NOTE: an identical new (not cut) USB A to USB C cable charges my phone but not the remote control!
      here is a picture of the remote, the cable to be used and a picture of what are the factory connected pins
      thanks in advance!!
      11-17-2023, 09:16 AM
