What software to use for stress/burn-in testing?
  • incapacitance
    • Jan 2006
    • 29
    What software do you guys use for burn-in and stress testing? Just want to make sure my CPU and RAM are working OK. I run Windows, BTW.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: What software to use for stress/burn-in testing?
    https://www.badcaps.net/forum/showthread.php?t=1094
    i usually just memtest86+ overnight. sometimes i also run prime 95 in windows
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      I like to use memtest (a few passes) and then load up windows, make sure it's stable, and run the distributed.net client for awhile to pull some juice. The problem with memtest is that it doesn't stress the CPU much, so it doesn't stress the power requirements of the board.
      Ludicrous gibs!
      • Mustang
        • Dec 2003
        • 203
        Here's Prime95 running alongside ATI Tray Tools. Tray Tools is nice because you can volages, temps, fans etc while stress testing. It's very customisable and can save a log file as well.
        • dood
          Deputy dood
          • Mar 2004
          • 2462
          I just use MBM5 to keep track of my voltages while testing... Does tray tools only work if you have an ATI card in your system?
          Ludicrous gibs!
          • Mustang
            • Dec 2003
            • 203
            Yes, just ATI and W2K or newer only. It's main function is a replacement to the Catalyst Control Panel. The monitor function is just 1 of many extras that come with the program. Very nice program
            • TerraPhantm
              • Feb 2006
              • 10
              I use prime95, sometimes its the only program that is able to tell me that I oc'd too much.
              • Inforgalaxie
                Testing Software
                by Inforgalaxie
                Hello, i need to know what is the software you use to test the laptops when you repair the motheboard before sending to yours clients.
                05-31-2023, 06:43 AM
                Copy DMI info easily with Hex editing software and Macro script
                by SMDFlea
                Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
                Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
                02-28-2023, 02:14 PM
              • NeedsPractice
                Backup To OneDrive Software? Everything! Best Software?
                by NeedsPractice
                I contacted Microsoft and they said they do not have software to where you could backup all your files to one drive. I mean you can copy some of your files to your one drive folder and back stuff up. However, it does not do this automatically.
                I have around (10) hard drives I want to backup to the cloud with One Drive. What is the best software to do this with?
                AOMEI Backupper
                I Drive
                Easeus
                I do not want a Cloud Plan. I just need the software to take my DATA and Transfer it to the cloud in a nice, readable, viewable fashion. I wish...
                02-04-2022, 06:04 PM
              • Russ17
                JVC LT-55C870(B) Corrupt Software??
                by Russ17
                I have a JVC LT-55C870(C). All that happens upon applying power is the red led flashes slowly (1Hz).
                If I hold the OK on the remote while powering on, the led flashes at 2Hz, but without a USB Device attached, it obviously does nothing, no screen or backlight.
                Any thoughts on this being corrupted software?
                Owner says the TV experienced a power surge.
                If software is a possibility, can someone point me in the right direction to download the correct software. Is there a procedure to force software to load from USB?
                10-10-2023, 12:34 PM
              • howardc64
                Vizio SmartCast TV software bug that looks like hardware
                by howardc64
                Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                11-16-2024, 05:17 PM
