More is Better?
+ More Options
Posts
  • ddscentral
    • Mar 2008
    • 151
    • Lithuania, EU
    Re: More is Better?
    Originally posted by PCBONEZ
    A 32-bit OS can't address more than 4 Gb anyway which means even if you have more, it the system can't use it because the system 'can't see it'.
    That's not exactly true. For example, Windows Vista and 7 with PAE (Physical Address Extension) can address way more than 3.x GB (with a kernel patch), but Microsoft does not want us to use more than 3.x GB on 32bit OS mostly for commercial reasons (the code to use 4GB+ RAM is there, but is disabled) . Many 32bit server editions of Windows do allow using more than 4GB of RAM.
    With Linux, you need a kernel with PAE support to address more than 4GB of RAM on 32bit versions of Linux.
    You do need a CPU with PAE support, but most modern CPUs support it.
    http://en.wikipedia.org/wiki/Physical_Address_Extension
    • Scenic
      o.O
      • Sep 2007
      • 2640
      Re: More is Better?
      even Win2k has a patch to allow the use of the full 4GB and possibly more.
      a friend of mine tried it and it works fine. i currently don't have a link though (i could ask him if anyone wants that patch)
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Re: More is Better?
        I'm aware of that.
        PAE is intended for servers and in fact is slow due to the extra step both ways in the accessing RAM process .
        Using it to speed up a consumer PC is counter productive.
        - So why would you?
        Why would you slow down your RAM access times in exchange for bragging rights on having more RAM that you probably will never use anyway?
        I used to have hot rod but I wanted a bigger engine so now I drive a Peterbilt.
        - Good thinkin'!
        Now you have a really big engine....
        Zoom Zoom.
        Mann-Made Global Warming.
        - Dr Seuss
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Re: More is Better?
          It's not a patch.
          It's a switch in boot.ini
          - Dr Seuss
          • Scenic
            o.O
            • Sep 2007
            • 2640
            Re: More is Better?
            whatever he used (idk), it was a tool patching a handful of system files. not just the boot.ini.
            kinda makes me wonder what that tool is right now... i guess i'll ask him tomorr...erm..today.. 4am
            • ddscentral
              • Mar 2008
              • 151
              • Lithuania, EU
              #26
              Re: More is Better?
              I'm aware of that.
              - So why would you?
              - Good thinkin'!
              Zoom Zoom.
              Well, at least you can use all your RAM and still maintain compatibility with 16bit programs and some devices which don't have 64bit drivers.
              But I do agree that for most 4GB+ users, 64bit is the way to go.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Re: More is Better?
                Oh I like W2k too.
                But more than 4GB on it is a waste.
                - Dr Seuss
                • Wizard
                  • Mar 2008
                  • 2296
                  #28
                  Re: More is Better?
                  I'm still wondering what chipset that supports 512MB desktop SDRAM DIMMs?
                  I know 830 chipset in PIII notebooks supports two 512MB for one 1GB max.
                  Don't speak up about VIA or Nvidia. Intel or server chipset will do. I had poor issues with VIA & Nvidia in past and best left behind.
                  Cheers, Wizard
                  • Mad_Professor
                    A Mech Warrior
                    • Feb 2011
                    • 1587
                    #29
                    Re: More is Better?
                    Intel 440BX which was widely used by ASUS and ABIT for slot 1 and socket 370 setups. I still have p2b-f and p3b-f in working condition. I used both up until 4 and half ago before I consolidated them into guest's on my xenserver.
                    Sadly all the hardware quality went downhill after that.
                    Anyways..
                    here's a list of intel chipsets
                    http://en.wikipedia.org/wiki/List_of_Intel_chipsets
                    Here's a list of SIS chipsets
                    http://en.wikipedia.org/wiki/Silicon_Integrated_Systems
                    • Scenic
                      o.O
                      • Sep 2007
                      • 2640
                      Re: More is Better?
                      Cheers, Wizard
                      My Gigabyte 8IDX ("P4 Titan") supports these. i845 Chipset with 1.5GB max (3 slots).
                      as for non-x86 hardware, old powermacs are fine with them too.
                      my two powermac G4 "Sawtooth" & "Gigabit Ethernet" (both 400MHz) work fine with them out of the box. quite impressive having 2GB RAM in a 400MHz box
                      edit: apparently, the i845 supports up to 3GB SD-RAM (3x1GB) :O
                      the gigabyte website says so too.. don't have anything bigger than 512MB to test though
                      http://www.gigabyte.lv/products/page/mb/ga-8idx/specs/
                      • Wizard
                        • Mar 2008
                        • 2296
                        #31
                        Re: More is Better?
                        That sad... sounds like intel was really *determined* to shove people to use P4 via more memory than PIII even PIII 1.4GHz were outpacing the P4 even at 2.8GHz! Back then when I entered athlon scene, I had no choice of good chipsets, it was either nvidia or VIA. The least problem was nForce2.
                        And this also explains lack of desktop boards using Pentium M except for few models by few makers.
                        Eventually I reached 775 using pentium dual core instead. I did not own P4 after athlon.
                        But I took advantage of P4 dirt cheap cost as temp solution for work and for dad's PC.
                        Now I'm working on replacing work PC with C2D as funds allows.
                        Cheers, Wizard
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Re: More is Better?
                          That's exactly what they were doing.
                          Intel even switched to Serverworks chipsets on their OWN dual Tualatin servers just to not make a Tualatin chipset that supports over 512Mb RAM.
                          - Dr Seuss
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            Re: More is Better?
                            I think only one version of the i845 does.
                            - Dr Seuss
                            • Scenic
                              o.O
                              • Sep 2007
                              • 2640
                              Re: More is Better?
                              the plain i845 (without letters) does. newer revisions (i845E, i845G*) don't
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                Re: More is Better?
                                I have some Itox i855 boards that run Pentium M + have a PCI-X slot.
                                [Same board was released as a DFI branded board too.]
                                Uses Pentium M for low power and the PCI-X permits decent hardware RAID cards.
                                Great for a file server or NAS setup that's on 24/7.
                                There are also a few Sossaman/Xeon based boards that can do that but desite the 'xeon' marketing they can't do 64-bit OS's. [Who cares on a file server though.]
                                There is an Intel server board that does this that is consistently only $10 on ebay because it's E-ATX and only has one PCI-X and one PCI-E slot. - That's FINE for a RAID file server/NAS.
                                And there are standard ATX socket 771 boards which can use Xeon Low Volt 5113, 5128, 5133, 5138, 5148 CPUs.
                                The 5138 is 35 watts, the rest are 40 watts.
                                I think they all use Speed-Step or equivalent to reduce power use even more.
                                The boards and RAM are more expensive but the CPU can be less than C2D.
                                Interestingly you can pick up a 5148 for under under $20 if you're patient while the others still tend to cost a fortune.
                                The 5148 is equivalent to C2D 6550 but only 40 watts. [2.33GHz 4M 133.]
                                - And if you want you could run two.
                                Such boards also tend to take a lot more RAM for later on should you actually need it. [16-64GB isn't unusual.]
                                - Dr Seuss
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Re: More is Better?
                                  Typo .. [2.33GHz 4M 1333.]
                                  - Dr Seuss
                                  • Wizard
                                    • Mar 2008
                                    • 2296
                                    #37
                                    Re: More is Better?
                                    Also Xeon 5160.
                                    I know there are some boards that uses P-M. Little known part is Asus produced an adapter for several compatible Asus boards, is CT-479. When I had it together, performance is excellent with 1.73GHz 740 CPU. But my dad needed faster PC so I had to give him my P4P800-VM with 2.8C GHz P4. I still have the kit to put back together later once I found a cheap board that is worth 25 since boards are still out of production for years. But this is rapidly getting pointless that I now have 2GHz P-M notebook working from two notebooks.
                                    P4P800 SE BIOS 1008
                                    P4P800-VM BIOS 1016
                                    P4P800-E Deluxe BIOS 1007
                                    P4C800-E Deluxe BIOS 1021
                                    P4GD1 BIOS 1005
                                    P4GPL-X BIOS 0205
                                    Last two boards is PCI-E and still fetching crazy price. I'm pissed.
                                    Cheers, Wizard
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      Re: More is Better?
                                      5160 isn't a LV Xeon. - I was only mentioning the LV versions.
                                      - Dr Seuss
                                      • tsavpyn
                                        Requests to Intel Flash Programming Tool for Linux Ubuntu x86_64
                                        by tsavpyn
                                        Dear all,
                                        I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
                                        Now I have a problem that I am unable to dump my BIOS into bin file.
                                        My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
                                        I searched for FPT but there is no Linux version and none of them work.
                                        I hereby request a copy of Intel Flash Programming Tool for Linux x64.
                                        I would really appreciate it if anyone...
                                        05-28-2024, 11:18 PM
                                      • abajor
                                        Evaluating Mechanical Hard Drives SMART Data in Linux (Ubuntu) Using the Disks Utility.
                                        by abajor
                                        I've gotten into the habit of Looking at peoples Mechanical Hard drives with a Ubuntu thumb drive to boot their system.
                                        I understand the raw values are not really uniform between manufacturers, but I have noticed that high seek and read error raw values at the very least correlate to a drive that is going to have sub par access time, and extremely slow OS booting.
                                        The odd thing is I've often seen very high seek and read error rates on drives with fairly low on time.
                                        Does anybody have any other takes on evaluating smart data? I've used Crystal Disk Info, It seems to present...
                                        04-23-2024, 11:43 PM
                                      • Dan81
                                        The Cheap Duo - Two SiS machines
                                        by Dan81
                                        Just as the title states. Two cheap SiS machines, surprisingly stable.
                                        What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                                        The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                                        CPU - P3 1100MHz Coppermine...
                                        04-16-2022, 12:28 PM
                                      • ivtec
                                        Ubuntu 22.04 wont boot stuck in initramfs help
                                        by ivtec
                                        Hi folks i installed Win10 in 1 HDD and Unbuntu 22.04 in other HDD and installed Grub manager ,it has been working fine till i installed new updates. now it wont boot and doesn't make recovery either and stuck on initramfs ,i type blkid and get this see pic attac. bellow ,althou it boot in Win10 .Any help will be apreciated ....
                                        06-02-2025, 10:56 AM
                                      • bigbeark
                                        Linux Distros : Mint, Zorin and Ubuntu - my 2 cents
                                        by bigbeark
                                        I started up one of my old boxes and discovered Ubuntu 11.04 on it, and it was still able to access Youtube etc. I always liked Ubuntu before they migrated to Unity desktop. I switched to Linux Mint and never looked back. But I decided to check out Ubuntu 16.04.4 because it was supposed to be a return to "classic" Ubuntu.
                                        Major disappointment, still got the crappy tile things, with an Amazon tile(!). I had to row through the Software store to load Synaptic and when I loaded hardinfo and a few other apps they didn't show up in the tile bar. Also no log file viewer and no...
                                        03-23-2018, 04:46 PM
