Network cogging
  • Wizard
    • Mar 2008
    • 2296
    Network cogging
    At my work, I need to make sure none of computers is causing the network to cog making the browsing website a frustrating experience so how can I check for that malware or bad host list. I need to do that checking first before we complain loudly at our ISP.
    Cheers, Wizard
  • brethin
    • Dec 2008
    • 1907
    Re: Network cogging
    Not really sure what you are asking but you should notify your network Admin and they will know what to do if browsing is slow on your works network.
    • seanc
      • Nov 2008
      • 1319
      Re: Network cogging
      Check the speed that your router is connected to your DSL service.
      Is it the same speed every day or every time you restart the modem?
      If you have a linux based firewall that allows you to perform a packet capture, do that.
      • digge
        • Apr 2006
        • 296
        Re: Network cogging
        Would need much more info to give really good pointers. However one easy way would be to just make sure each computer don't have any programs running, and just watch the activitylight on the networkcard. If its just giving a blink here and there, should be fine, if its blinking furiously something fishy is going on. Finding out what can be done with some netstat maybe or other tools.
        • Wizard
          • Mar 2008
          • 2296
          Re: Network cogging
          Cogging is what I mean by I click on anything, wait, and wait....if I click then one second later click again it responds better but slowly. And happens all the time and this is not at my home. It is at my work. It is not the network speed or the ISP's speed. I need to make sure all of the computers is not jamming the network then I have case to complain about loudly to the ISP.
          Is there a way to investigate that?
          Cheers, Wizard
          • retiredcaps
            • Apr 2010
            • 9271
            Re: Network cogging
            For these types of problems, I usually use a network protocol analyzer to see what is "on the network". You can use free tools like
            http://www.wireshark.org/
            http://www.ethereal.com
            to see what is causing the slowdown.
            --- begin sig file ---
            --- end sig file ---
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Re: Network cogging
              It's the fallout from Japan..
              ~ snicker ~
              Mann-Made Global Warming.
              - Dr Seuss
              • Toasty
                • Jul 2007
                • 4171
                Re: Network cogging
                http://network-tools.com/
                Traceroute, Ping, Domain Name Server (DNS) Lookup, WHOIS
                Can disconnect all machines but one and see if problem exist or remains?
                veritas odium parit
                • seanc
                  • Nov 2008
                  • 1319
                  Re: Network cogging
                  You could well just have a DNS lookup problem.
                  Try changing your DNS servers to use OpenDNS - 208.67.222.222, 208.67.220.220.
                  • howardc64
                    Samsung UN55JU650DF network/streaming problem
                    by howardc64
                    Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                    This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                    07-09-2025, 12:44 PM
                  • davg
                    Home network connection problem
                    by davg
                    I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
                    03-06-2021, 07:13 AM
                  • japlytic
                    Maximum speed should be marked on network ports
                    by japlytic
                    I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
                    One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
                    12-19-2024, 05:04 PM
                  • hikomalek
                    SYMSI70 gas heater, TOP247Y exploded, power supply, snubber network
                    by hikomalek
                    Hello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
                    When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
                    Transformer:
                    |Info| Primary | Aux | AB | CD|
                    |Ratio|1|25|40|12|
                    |Voltage AC|230V|9.2V|5.8V|19V|
                    |Voltage DC (*1.41)|230V|13V|8.1V|27V|
                    I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up...
                    09-19-2025, 03:30 AM
                  • harp
                    simple win network with optimization issue
                    by harp
                    simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
                    06-23-2025, 11:01 AM
