Scanning BIOS Image in Hard Drive , but wont seek floppy
  • kiddznet
    • Jul 2010
    • 176
    There seems to be thousands of folks out there would love a solution to this one
    Is the anyway to fool the board to boot from floppy?
    939 DualCore AMD Opteron, 1800 MHz (9 x 200)
    Abit AN8 / Fatal1ty AN8 SLI Series
    3072 MB (PC3200 DDR SDRAM)
    ATI Radeon HD 4300/4500 Series (1024 MB
    Lian LI Aluminium mesh case
  • digge
    • Apr 2006
    • 296
    Re: Scanning BIOS Image in Hard Drive , but wont seek floppy
    Need a bit more information to be able to help you. Dont quite follow what you mean.
    Do you have a harddrive with a bad bios on it, or is it a motherboard that has a bad bios?
    Either way name the specific model and someone might be able to help.
    • Scenic
      o.O
      • Sep 2007
      • 2642
      ^ some motherboards look for a backup BIOS file on the HDD, but not on a floppy.
      they (board manufacturers) expect you to use a FAT formatted USB stick (which would be recognized as a HDD by the BIOS)
      yet another way to kill off the FDD's..
      • japlytic
        • Oct 2005
        • 2086
        It is highly unlikely that motherboards would support Linux partitions for BIOS recovery.
        Also, I've read that later HDDs store a basic BIOS on the logic board, while the main BIOS is stored on a hidden section on the magnetic media.
        • kiddznet
          • Jul 2010
          • 176
          Ive got this GA-965P-SE board doing this
          google "Scanning BIOS Image in Hard Drive" and you will see what I mean Its affected hundreds of GA boards
          I cant take it to a shop theres none in this part of the world
          Gotta figure out meself
          One POSSIBLE solution might be to get a drive that has been loaded on exactly the same board and try it?
          http://forums.tweaktown.com/gigabyte...n-problem.html
          • seanc
            • Nov 2008
            • 1319
            Random, never seen this error, did a quick search and gleaned the following:
            Get a HDD with disposable data, format as FAT32. Stick the BIOS file ONLY on the root of the HDD and power up.
            If FAT32 doesn't work, try alternate versions of FAT, or NTFS.
            • kiddznet
              • Jul 2010
              • 176
              Formatted a little 6 gig drive here in FAT 32 and tried putting the bios on that....nada
              the board doesnt run very long 30 seconds or so before stopping
              PCI analyser sez FF 50
              • Philly Cheese Steak
                • Mar 2011
                • 114
                Try causing another error like booting with all sticks of ram out to WAKE the BIOS up, to get you by..........See if it helps.
                X99 5930K
                X99-gaming 9
                EVGA 1080 Vanilla
                Gskill 16GBRip JAWS@2400
                SSD'S
                Corsair AX1200
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  Maybe it works like Dell's systems where the BIOS needs a specific filename aswell?
                  http://forums.mydigitallife.info/thr...-BIOS-recovery
                  • kiddznet
                    • Jul 2010
                    • 176
                    If we solve this one we will be famous
                    I see lots of Gig owners terribly peed of with this fault and nowhere that I have found so far a cure for it from the manufacturer
                    • kikkoman
                      • Jul 2007
                      • 691
                      have you tried with NO drive connected at all?
                      "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
                      • kiddznet
                        • Jul 2010
                        • 176
                        I have the board GA - 965P-SE sitting on a phone book
                        Ive tried everything,every combination no drive usb stick and Floppy
                        manages to post the message and an analyser in the PCI slot reports FF 50
                        It wont run very long but will reboot the same message again
                        • seanc
                          • Nov 2008
                          • 1319
                          Gigabyte boards reboot when they're trying to fix themselves using the backup BIOS.
                          Does your board even look like it's accessing the HDD or not?
                          Only fix I can suggest is to replace one of the BIOS chips with one which has a known good flash.
                          Sent a board back to Gigabyte for the 'power up, wait and reboot' issue recently, they re-flashed the BIOS.
                          • kiddznet
                            • Jul 2010
                            • 176
                            Repair by manufacturer impossible, I paid five bucks for the board!
                            • seanc
                              • Nov 2008
                              • 1319
                              It's come back from Gigabyte with that note has it?
                              Are you sure there's not some other issue lurking that is causing it to reboot then? Other posts on the net state that it should hang with this error.
                              • digge
                                • Apr 2006
                                • 296
                                Have you tried booting it while holding HOME or END? At least on some boards that will initiate some kind of clear bios settings, should be the same as removing the battery though but might as well try it.
                                Other then that all i can think of is flashing the bios with some kind of programmer, not sure if that particular board have an SPI header or similar, or if you have access to some kind of chip programmer.
                                • brethin
                                  • Dec 2008
                                  • 1907
                                  Place the bios file on a cd, remove all hard drives, when it boots it should look on the cd for the file and flash the bios. If this doesn't work you have other issues.
                                  • kiddznet
                                    • Jul 2010
                                    • 176
                                    Any Linux gurus out there can suggest anything?
                                    This board opens to the monitor but will not seek any drive.
                                    • kikkoman
                                      • Jul 2007
                                      • 691
                                      i think it does seek the drives, but (as suggested elsewhere on the net) the image the BIOS is looking for is not a plain binary or hex file but it's written in the HPA (http://en.wikipedia.org/wiki/Host_Protected_Area) of a HDD. Some suggest it does so even if the normal BIOS is a-okay.
                                      Perfect example of the "it's not a bug, it's a feature" thing. seriously, they call it "Virtual Dual BIOS" or something like that.
                                      Where and how it's written there - no idea.
                                      it also looks like the BIOS is not socketed (and it's a 8-pin SO case SPI flash chip) so you won't find the usual preflashed chips on ebay.
                                      your best bet is either hotflashing it in another board (you need one with a SPI BIOS chip, obviously) but it's a bit tricky since there's no socket...
                                      ...or using an external programmer that does SPI.
                                      guess I'll think twice about buying Gigabyte in the future. not that i've been particularly fond of them in the past.
                                      • Scenic
                                        o.O
                                        • Sep 2007
                                        • 2642
                                        well.. if international shipping wasn't so much of a ripoff, i'd say send the board over here and i'll reflash it.
                                        i've got the tools to flash those 8pin serial eeproms..
                                        revived quire a few gigabyte boards so far
                                        @kikkoman: the "virtual dual bios" boards have a single bios chip, divided in two software ones exactly half the size of that eeprom, emulating a real 2-chip dual-bios.
                                        never had a single real dual-bios (with 2 chips) fail yet. even the update procedure on them is pretty much bulletproof.
                                        the updater writes the new bios to the primary bios chip (well.. or the primary virtual bios), but not the second one. you can reboot and check if everything's fine, and if it is, you go into the flash utility integrated into the bios and tell it to clone the primary bios to the 2nd chip. pretty clever.. that way a new bios wont kill both chips at once if its the wrong file or its corrupted or something..
                                          HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:20 PM
                                        • federalhouse
                                          **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                                          by federalhouse
                                          I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                                          **Background:**
                                          I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                                          **What I've Tried So Far:**
                                          1. I accessed
                                          08-01-2024, 07:03 PM
                                          HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          09-06-2024, 10:56 AM
                                          HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
