Annoying WinXP Theme problem
  • Maxxarcade
    • Jul 2006
    • 973
    I have a couple computers with fresh installs of XP Pro, and all service packs/updates. Both have this same annoying glitch...
    Every time I change the theme, whether it be to Windows Classic or XP Green, the taskbar reverts to Blue almost every time I reboot. The color of the desktop background stays the same.
    I've tried a couple registry tweaks, but still no luck. Any idea what could be going on? I never used to have this problem until recently.
  • mockingbird
    • Dec 2008
    • 5488
    Re: Annoying WinXP Theme problem
    Your user profile is corrupt. Make a new user and see if it happens.
    • Maxxarcade
      • Jul 2006
      • 973
      So far that seems to have fixed it. Thanks!
      • cookieCAM
        ICDEZ_CAM
        • Feb 2011
        • 26
        Kinda Wierd.......I've Used XP For 5 Years Mostly Okay OS But I'd Pick 7 Over XP
        Thanks, cookieCAM (Cam)--Updated:March 2011
        • Maxxarcade
          • Jul 2006
          • 973
          Ya, frankly I can't stand XP any more. Just so stale and has dwindling support. I use Win 7 on all my systems for the most part. Just these trash-find PC's that have XP.
          • mockingbird
            • Dec 2008
            • 5488
            I don't know why people go crazy over 7. I just installed 7 Pro on a computer, it's the same thing as Vista basically, except for a few UI differences...
            I still prefer the XP interface, but I realize that I'll have to go to Vista/7 soon to get the Direct3D/OpenGL browser enhancements.
            • Maxxarcade
              • Jul 2006
              • 973
              The appearance may be similar to Vista, but it's 10x faster. I like the ability to easily add icons to the task bar, instead of having to drag and drop from another location or manually add a shortcut. Networking also seems a bit better/faster.
              XP is still very functional, just getting old IMO. It also can't be used with more than 3GB of RAM. Kinda defeats the purpose of having a high-end 64 bit system.
              I used to like the classic gray Windows interface, but it's getting boring/stale to me. It's nice to be able to make a transparent task bar in any color and shade to match my desktop theme.
              • Krankshaft
                • Jan 2007
                • 2328
                I second the XP is getting old comment but my gripes are from a technical standpoint for example. I recently slipstreamed SP3 and burned a new XP install CD. So I wouldn't have to install 3 service packs manually after the OS setup.
                The reason why I did this was because XP SP1 doesn't support hard drives over a certain size. The exact gigabyte cap escapes me at the moment maybe 120?
                It resizes the partition to the max it can support pre SP2. Of course drive management in XP can't resize the drive to it's full capacity even after the service pack installs allow larger drive support. So I have to use a third party app like Partition Commander (Symantec discontinued my old favorite partition magic) to resize.
                Then there's the PITA of manually installing all the drivers for your peripherals. The best one is transferring the drivers for internal nics I need to get a flash drive or burn a CD since I have no network capability. To make this even more entertaining if I don't have at least SP2 installed some USB flash drives won't get recognized.
                The slipstreaming at least allows me to use flash drives for driver transfer and does away with the stupid drive size cap and eliminates manual partition resizing but getting XP in running condition is getting more tedious the older it gets.
                Compare that to Windows 7 where it practically installs itself including almost all of my device drivers. From an ease of install standpoint it takes the cake.
                The interface takes some getting used to but once you get the hang of it the old XP interface seems very primitive by comparison. The XP "classic interface" dates back to Windows 95 so it's had a good run and I can understand why Microsoft wanted to redesign it.
                • Ami Sapphire
                  Extreme Lurker
                  • Sep 2010
                  • 180
                  It's 137GB, for the record.
                  Recovering a BEFSR41 v1 and v2 router from solid red DIAG Light
                  I have two v2s and one v1.
                  I am still looking at these boards nearly every day.
                  What I'm doing: Planning an upgrade of my mining setup from Block Erupters to Red Furys. Though, if the Block Erupters don't sell, I will keep using them for a while.
                  • Scenic
                    o.O
                    • Sep 2007
                    • 2642
                    @ krankshaft: use nLite to integrate service packs, drivers (including chipset SATA drivers if needed), patches and other stuff into the XP CD.
                    you can even remove unnecessary windows components or automate the installation process, so you don't have to enter the key, select the region, do the network settings and all that crap during the installation
                    also, service pack are redundant. you don't need to install SP1 -> SP2 -> SP3, as SP3 contains all previous servicepacks / patches.
                    • seanc
                      • Nov 2008
                      • 1319
                      I moved from using nLite and CDs to Windows Deployment Services.
                      I build an XP installation, do what I want with apps (hide IE), dump my drivers, utilities on the root of the C: drive, run Windows Updates, SLP activate for Dell/HP or leave it as normal and upload it to the WDS server.
                      Then I get a PC, PXE boot it, apply an image in ~12 minutes, transfer data and shove it out the door.
                      • Maxxarcade
                        • Jul 2006
                        • 973
                        I've had to manually install LAN drivers on Win 7 when using late model hardware, but it's still faster and easier than XP. From install CD boot until I'm at the desktop is usually around 20 minutes or so. Once I have the LAN going it will take care of the rest. I also primarily use Gigabyte boards, which have decent install CD's.
                        I'll admit that I upgraded for the looks as well. No more Gray/Green/Blue/Silver taskbar that I get tired of looking at. And like I said earlier, >3GB of RAM in most modern PC's these days is a no go for XP.
                        • theone111
                          by theone111
                          3. Problem: TV shuts down
                          07-22-2024, 10:36 AM
                        • Zeonalbasta
                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                          by Zeonalbasta
                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                          09-13-2024, 01:17 PM
                        • Gibon378
                          Problem with stopping audio and video for no reason
                          by Gibon378
                          PC Specs:
                          • CPU: Ryzen 5 1600
                          • GPU: GTX 1080 Palit JetStream
                          • MOBO: ASRock ab350 PRO4
                          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                          • PSU: XFX 650W (don't remember what model)
                          • OS SSD: ADATA SP920
                          • OS: Windows 10 21H2
                          Problem description:
                          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                          11-19-2022, 09:41 AM
                        • perzyk23
                          Lenovo T580 - LCD Panel problem - error 0288
                          by perzyk23
                          Good morning,
                          I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                          10-25-2024, 12:42 AM
                        • lazaro.089
                          Asus Zephyrus M16 / GU603ZW problem
                          by lazaro.089
                          Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
                          CPU: Core i9-12900H
                          Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
                          Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
                          The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
                          08-26-2025, 06:33 PM
