Is an ESP12V usable in place of ATX 12V?
  • EvilCensor
    • Jan 2011
    • 8
    My Gigabyte motherboard GA-X58A-UD3R asks for:
    1 x 8-pin ATX 12V power connector.
    However, my Seasonic S12 Energy Plus SS-650HT has a 4 pin ATX 12V connector and an eight pin ESP12V connector.
    Is the ESP12V connector okay for the ATX 12V requirement?
    The PSU - http://www.pcstats.com/articleview.c...id=1995&page=2
  • Shodan486
    • Nov 2009
    • 203
    Re: Is an ESP12V usable in place of ATX 12V?
    Yes.
    Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.
    • Tomylee
      No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
      by Tomylee
      Sorry for the person who’s going to read all this !
      I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
      While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
      During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
      07-11-2025, 11:52 AM
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • 5mall5nail5
      Help identifying connector for ASUS 4090 Strix RGB LED connector
      by 5mall5nail5
      Hi All -
      I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
      Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
      05-04-2025, 07:47 AM
    • bussincaps
      MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
      by bussincaps
      Hello All,
      tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
      Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
      eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
      Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
      I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
      08-03-2023, 12:57 PM
    • michhak
      Toshiba Satellite M50-A keyboard connector on LA-A481P motherboard
      by michhak
      Hi guys,
      i have a damaged keyboard connector on my older Toshiba Satellite M50-A laptop. I know there is LA-A481P motherboard. In attachment pictures there is a real looking connector and i also found a schematic to the connector. But i need help with finding a real electronic part to replace the damaged connector. e.g. on aliexpress (or different page).
      It is 34pin connector and the length from pin n.1 to pin n.34 is 26mm. So it means a pitch length is 0.764 mm. I have seen connectors with 0.5mm , 0.7mm , 0.8mm and 1mm pitch length. But not with 0.75. Is it some special custom connector...
      11-17-2021, 05:45 AM
