7300GS Loose Resistors - Help!
  • bigbeark
    • Jan 2010
    • 661
    I have a 7300GS 256MB PCI-E video card here, made by E241819. other marking PE0734.
    I tested it and instead of a display I get very distinct striped wallpaper patterns. Not a lot of artifact noise.
    On examining the backside I detected two resistors that had come loose but somehow had not fallen off, but were clinging to the board near R571 and R570. There was evidence that the resistors had been attached to R571 & R570.
    I have a 50-50 chance of resoldering them in the correct position (see photo).
    They are marked 123 and 223 and I assume they related to the stencilled labels
    R571 and R570.
    NOTE: The resistors are loose, I just put them just sitting on those solder pads. Don't know if this is the correct position.
    Does anyone have a similar video card, and, if so, could you advise me of the correct placement of these resistors?
    There does not seem to be heat damage, just they were not securely soldered and fell off.
    Thanks for your help
  • seanc
    • Nov 2008
    • 1319
    Re: 7300GS Loose Resistors - Help!
    I'm confused, first you said they hadn't fallen off, then you say that they fell off.
    If they haven't fallen off and one side is still attached, or the glue is holding them on, just add some new solder.
    • bigbeark
      • Jan 2010
      • 661
      No there was no resistor on 571 and on 570 there were 2 resistors one on top of the other. When I touched the top one, they both fell off. I wasn't smart enough to note which was on top. I didn't expect both of them to fall off when I touched them.
      I don't know if they have the same resistance value. They are so tiny i dont think I could measure them with my multi-meter.
      I just want to make sure I get them in the right place.
      • seanc
        • Nov 2008
        • 1319
        Right, I understand now.
        I have a 7300Gx, I'll check later.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Can you zoom out a ways so I can see what the whole card looks like and where these are on it?
          Thanks.
          Mann-Made Global Warming.
          - Dr Seuss
          • Spode
            • 41
            I've had resistors fall of cards before with no ill effect.
            A striped wallpaper is usually indicative of bad memory on the board. Whether that is caused by the resisters being out of place is another question
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              Depends on where they are located. If they are used to drive a transistor (or for any other application like that), then they would be quite important. Yours apparently weren't.
              As for the resistors on bigbeark's card:
              123 = 12 x 10 ^3 = 12000 Ohms
              223 = 22 x 10 ^3 = 22000 Ohms
              E241819 is the UL number of the PCB manufacturer. Doesn't really say much about who made the video card, though. Does your video card have a fan on it? Perhaps you might find some info there.
              Other than that, your best bet is an image search on Google until you find a video card that looks like yours. Once you do, note the manufacturer, then do some more image searching (perhaps even eBay would help) to see if you can find a picture of the area in question.
              As a last resort, you can just solder the resistors one way. If card doesn't work properly, you switch them around.
              Either way, get some liquid or paste flux - it really helps when it comes to soldering SMT stuff. Basically, you first clean the pads where the component goes, then add flux to both the component and the board. Finally, put some solder on the tip of the iron, hold component with one hand (preferably with tweezers or something like that), and touch one side of the component with the iron. The flux will automatically make the solder stick to both the component and the board.
              • TinkerTron
                Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                by TinkerTron
                Hey everyone,
                I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                Instead, here's what's been bugging me so far:
                The schematic...
                03-06-2025, 02:03 PM
                Acer Nitro AN515-44-R570 Notebook 5 Specification for Upgrade or Repair
                This specification for the Acer Nitro AN515-44-R570 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the AN515-44-R570 boardview and AN515-44-R570 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-06-2024, 04:40 PM
              • brightest_z
                Hot Air Blew Away Resistors Near Bios
                by brightest_z
                Hi All - I'm in the midst or reprogramming the bios on my gen1 Surface Laptop Studio and I accidentally blew away 2 resistors nearby the bios. I don't have another board to measure values of the missing resistors and schematics aren't available, bbut the bios is a 6x5mm Winbond WSON8, W25R256JWPQ model. The traces are conductive to Pins 3 and 7 (IO2 & IO3 respectively) so I have reason to believe they are 10k pull up resistors since IO2&3 pins are used for Quad SPI instructions.
                Does anyone with more knowledge, and experience than I, know if this is the case?
                12-11-2024, 08:34 PM
              • jinu_j
                LED driver circuit. Burnt Resistors
                by jinu_j
                Hi Folks
                This has to do with a LED light driver rated for Output - DC36-65V 300mA. This is used to drive a 15W LED panel light.
                Now this does not work so opened up and found 2 resistors burnt to crisp. Sensing a learning moment, i looked around the circuit to figure out that it is built around the OB2538 chip. The circuit to a large extent follows the sample application circuit mentioned in the data sheet. I have traced the actual circuit and the same is also attached for reference.
                But i have some queries on this circuit
                1. The resistors that burnt to crisp...
                08-26-2020, 01:24 AM
              • repair-it
                Pioneer VSX-40 ,Trying to ID these resistors
                by repair-it
                I am trying to determine why these two resistors are the colors that they are. This is a Pioneer amp. The ones I am concerned about are the RED & GREEN colored resistors. I need to replace them and want to be sure to use the properly rated component....
                12-16-2024, 02:08 PM
