Anyone know about NETLIST Ram?
  • Big Pope
    Approved Vendor
    • Dec 2005
    • 426
    Is it a good brand? I bought with very cheap price from someone last year........
    My SAMXON Capacitors Database HERE!!
    X-CON is a new brand for SAMXON's Polymer Capacitors.
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Anyone know about NETLIST Ram?
    i have never seen that brand.
    looks like a real interesting company http://www.netlistinc.com/
    has samsung chips. i have never had issue with samsung ram.
    i just bought 2x1gb transcend. unfortunately one stick is samsung chips and the other is hynix...... both are good brands though.
    • Big Pope
      Approved Vendor
      • Dec 2005
      • 426
      Oh, thanks. NETLIST seems a brand in U.S.A. As i know, Transcend is Taiwan ram factory, the quality is so good. However, i don't understand why you are not bought the ram with same brand chips? You buy together or not?
      • Newbie2
        • Sep 2005
        • 885
        This is common. PQI along with other manufacturers like NETLIST buy RAM chips from a RAM manufacturer and then "assemble" the RAM module. One manufacturer I think makes their own RAM chips and puts it on their own RAM modules is Micron.
        My gaming PC:
        AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
        ASUS M4A77TD AMD 770 AM3 Motherboard
        PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
        G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
        TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
        WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
        ASUS Xonar DG 5.1 Channel PCI sound card
        Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
        Antec Three Hundred Mid-Tower Case
        Microsoft Windows 10 Pro 64-bit
        Microsoft Windows 7 Ultimate SP1 64-bit
        • Rainbow
          • Aug 2005
          • 1374
          There are also Samsung memory modules, but Samsung also sells the chips to other module manufacturers.
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            most companies that make ram produce their own sticks. micron sticks are branded crucial. twinmos use their own chips and are reliable,
            the only problem is when you see a generic stick with all samsung chips for instance and no samsung brand sticker. who are you gonna call for rma. lifetime warranty yeh.
            anyway i buy a lot of transcend cos it is reliable and cheap, availability is good and rma through a major chain here no probs. usually it is their jetram brand chips or more recently transcend chips. i was suprised to see samsung and hynix on their sticks. perhaps it is cheaper to buy from the majors than make your own.
            i will check these sticks and see if they work dual channel otherwise i have the option of return or sell them to a customer some time along the line heh. yes they were the last 1gb sticks in the shop unless i wanted to pay more for OCZ.
            i dont need fast ram cos my D975PBZLK doesnt like that i just want 2gb to see if it improves my photoshop performance. i know i am working with a gig swap sometimes.
            • Rainbow
              • Aug 2005
              • 1374
              I used to buy M.tec modules when they were available. It was TwinMos cheap brand, IIRC, both modules and chips marked M.tec. The interesting thing is that the chips on PC133 modules are 6ns (or at least marked so ...something-6). I've tried overclocking with one of these modules and it worked fine up to 150MHz (CL3 IIRC) Of course, they run at 133MHz with CL2. Not bad for cheap brand.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                lots of those lifetime warranties are worthless.too many weasle words and gotchas.i wont buy noname stuff to save 5 bucks a stick when i can get name brand stuff with a warranty i can expect to be honored in the rare case it fails.
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  yes and actually if i have had a part fail quickly i might not even want to use an identical part received after successful rma. things like ram/hdd fails etc mean several hours of work to reinstall windows. no sense to save money buying generic parts for office/customer machines especially.
                  here is a generic stick of sdram bought in desperation one day. The chips are Micron and look nice. The company who assembled the stick is unknown from the packaging. the part failed after a few months making crashes and corruption.
                  so the above type of generic is what would not be recommended to buy.
                  one thing i look for in ram presently is the packaging. i have seen store employees wrap loose sticks in foil or use normal static filled bags to package the ram. they dont wear wrist straps when handling the loose ram and might take sticks out to show customers many times before one gets bought.
                  so i look for proper sealed packages like below which show kingston ram packages and transcend.
                  another factor is returns. some stores just put them back on the shelves, so when a package is still factory sealed you know that did not happen. nothing like going all the way to a customers premises for a repair and finding you brought a broken returned part.
                  • Big Pope
                    Approved Vendor
                    • Dec 2005
                    • 426
                    Mircon -75E Good. That's the good chips in SDRAM.
                    I also keep a pair good SDRAM for testing. MOSEL PC133 CL2:
