Dell Studio XPS 16 Notebook Blue Screen Trouble
  • Drew
    • Oct 2010
    • 40
    I recently just Purchased a Dell Studio XPS 16 Notebook. Within a week or two of use I had my first blue screen. It's been about a month and a half since I purchased it and I have had 3 blue screens. It seems to occur when I close the laptop to go to sleep in the night and it goes into hibernate mode and when I boot it up the next day it says it there was an unexpected shutdown, I look to see what the error was and it was a blue screen each time. I have absolutely no idea what can cause this or if its something to even worry about. All help is greatly appreciated.
    Intel Core i7-840QM (1.86-3.2Ghz, 8M/8 threads)
    6GB, DDR3, 1333MHz 2 Dimm
    ATI Mobility Radeon HD 5730 - 1GB
    RESOURCE DVD,BACK-UP,MADISON,XPS 1645
    500GB 7200RPM Free Fall SensorSeagate Hard Drive
    Windows 7 Home Premium, 64bit, English
  • yyonline
    • Jul 2009
    • 692
    Re: Dell Studio XPS 16 Notebook Blue Screen Trouble
    When Windows blue screens, it writes an event to the system log. First step is to check there, and post the details of the error. Without that information, I can only guess...
    Another thing you can do is to change the system failure action in System properties. (Control panel -> System Properties -> Advanced tab). Un-check "Automatically restart" under System Failure. This will leave the blue screen on the screen, which will give you time to write down the error. Why do it this way instead of looking in the log? Sometimes the on-screen error gives you the name of a file, such as a driver. This information isn't always recorded in the log, in my experience.
    After you write down the error info, hold the power button down for 5 seconds or so to power off the computer.
    So...Once you have an error code, post it, and we can offer you some advice.
      • 31063
      return it under warranty.
      • Drew
        • Oct 2010
        • 40
        Here is a list of the errors and the date they occured:
        9/24
        The computer has rebooted from a bugcheck. The bugcheck was: 0x0000000a (0x0000000000000000, 0x0000000000000002, 0x0000000000000000, 0xfffff80002fe1477). A dump was saved in: C:\Windows\MEMORY.DMP. Report Id: 092410-24616-01.
        10/2
        The computer has rebooted from a bugcheck. The bugcheck was: 0x0000003b (0x00000000c0000005, 0xfffff88002cf25fa, 0xfffff880094eba60, 0x0000000000000000). A dump was saved in: C:\Windows\MEMORY.DMP. Report Id: 100210-19500-01.
        10/12
        The computer has rebooted from a bugcheck. The bugcheck was: 0x0000009f (0x0000000000000003, 0xfffffa8006140060, 0xfffff80000b9c518, 0xfffffa800698f8c0). A dump was saved in: C:\Windows\MEMORY.DMP. Report Id: 101210-24367-01.
        10/25
        The computer has rebooted from a bugcheck. The bugcheck was: 0x0000009f (0x0000000000000003, 0xfffffa8006152a20, 0xfffff80000b9c518, 0xfffffa80087332b0). A dump was saved in: C:\Windows\MEMORY.DMP. Report Id: 102510-14710-01.
        So it was 4...guess I forgot one. Let me know if you need any more information.
        • Drew
          • Oct 2010
          • 40
          I'm probably going about doing that over Thanksgiving Day week, until then I have the machine. In the mean time I would like to find out why this error is occuring and if it is damaging my system at all.
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            Go over to the Microsoft Technet forums and send them the memory dump. They should be able to tell you whether it's Windows or your laptop.
            A working TV? How boring!
            • yyonline
              • Jul 2009
              • 692
              All of those could be caused by a buggy driver. Have you added any hardware to the laptop since it shipped? It could even be something seemingly trivial like a USB device. If you have, make sure to go out to the manufacturer's website and download the latest drivers. Windows 7 is fairly new, and many hardware devices had buggy drivers early on. The drivers that come on the CD with your device aren't always the most recent.
              Next thing I'd try is to goto support.dell.com, enter your service tag number, and download the latest drivers for the hardware that shipped with your computer.
              If that doesn't work, it may be malfunctioning hardware, instead of a driver issue. Dell usually puts a hardware diagnostic program on a hidden partition. To access it, press F12 on startup when you see the Dell logo. Select diagnostics from the boot menu. When it loads, select the thorough test. It will test all your hardware. Stay close by, as it will prompt you to do things periodically. If it finds a failure, call Dell to set up warranty service.
              It may be worth trying to restore the computer to the factory state. There's usually a hidden restore partition on consumer Dells. Check your owner's manual for how to access it. Back up all your personal files first! It's annoying to have to do this, but Dell will likely require you to go through this step before you can get warranty service on the computer without a failure code from Dell's diagnostics program.
              • Drew
                • Oct 2010
                • 40
                Alright, I'll start doing those things now and will post the results when I have finished.
                • 370forlife
                  Large Marge
                  • Aug 2008
                  • 3112
                  A friend got a new dell inspiron about 3 months ago. Started to randomly blue screen, turns out it already had a bad stick of ram. Ram was kingston brand, too.
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    I'd rather try a clean install instead of that. I always wipe the darn recovery partitions. Preinstalled systems are designed to give you trouble in the first place - otheriwse how would the tech support guys earn their pay?
                    When i bought my HP DV5 last summer, it wasn't able to PLAY A DARN MP3 without stuttering and hiccuping. Clean install fixed that.
                    • Drew
                      • Oct 2010
                      • 40
                      With hearing that I think I'm going to call dell technical support this weekend and have them check the hardware and if there isn't a problem with any of it I'll do a clean install. As of right now I don't think it would be reasonable to just go and do a clean install when the cause of the problem hasn't been identified.
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        http://hcidesign.com/memtest/download.html <- Let that run for a few hours and it'll tell you whether your RAM is bad.
                        • john9871
                          • Mar 2016
                          • 5
                          • India
                          Here's the mail I got recently for my problem
                          Yeah, well.... This is a week old computer and I have been getting the system service exception constantly.... it is definitely related to Internet because that's when it happens... no idea what is causing it but it is continual. Hope Microsoft figures this out.... seems I'm not the only one... I am an IT manager so not an idiot when it comes to the computer.
                          Or otherwise try this: http://www.deskdecode.com/system-ser...on-0x0000003b/
                          • rtimran52
                            • Mar 2015
                            • 7
                            • india
                            DELL XPS 1645 PCB DARM5CMB8D1 UMA CONVEARSION .Pls any help
                            • HTR-Informatique
                              Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                              by HTR-Informatique
                              YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                              I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                              On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                              I also changed the screen because the PC fell and the screen was broken.
                              I changed the battery with a new and original battery.
                              I also had corrosion/oxidation on the...
                              02-09-2025, 06:51 AM
                            • siuras676
                              Dell XPS Plus 9320 blue screen and rebooting
                              by siuras676
                              I have a Dell XPS 9320 in for repair, and the machine has a strange issue.
                              First, a bit of history: the laptop came in after liquid damage and was completely dead. I've repaired all the broken traces, replaced the damaged components, and it now powers on.
                              However, it's now showing a Windows blue screen related to hardware (as seen in the picture), along with another Dell error I've never seen before.
                              Has anyone encountered this issue on a Dell machine before and could point me in the right direction? I've checked the power rails around...
                              04-07-2025, 12:10 PM
                            • Swedishpower
                              Dell G3 15 3500 black screen
                              by Swedishpower
                              Hello
                              I have search everywhere for a solution for my problem, but cant find it anywhere.
                              When I was away to trow some garbage i always look in the electronic bin.
                              and this time i find a laptop.
                              Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
                              the lamp for charmig is white.
                              Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
                              but no Dell logo.
                              I tryed with a hdmi cable to another screen, still black.
                              I started to search solution and tryed...
                              07-06-2025, 06:18 AM
                            • Abdulrhman Alabsi
                              Dell precision 7530 blue screen
                              by Abdulrhman Alabsi
                              I have problem in my laptop, When I try to enter to windows it showes me blue screen, I changed hard driver and ram but it did the samthing...please give me the solution of it
                              02-09-2025, 10:39 AM
                            • MahmoudNasser
                              Dell Inspiron 15-7567 Blue Screen
                              by MahmoudNasser
                              Model: Dell Inspiron 15-7567
                              SN: FZF5YF2
                              MB Part number: LA-D993P Rev:1.0
                              When I run Windows or any flash drive that contains Windows, it gives me a blue screen with the message “ACPİ BİOS ERROR.”
                              - I tried changing the Sata Operation settings (AHCI-RAID ON)
                              - I tried repairing Bios File (Rebuild Bios Region - Clear me)
                              But without any benefit
                              Please help​...
                              05-15-2024, 08:59 AM
