error code 0x80072f8f 20000 When widows upgrade to 10
    • 31294
    Re: error code 0x80072f8f 20000 When widows upgrade to 10
    what software is it?
    i'm running CPS 1.6 and 2.0 on 64bit
      LCD LED TV Service Menu Codes
      TCL LED TV Service Menu Code
      LG LED TV Service Menu Code
      10-31-2024, 03:58 AM
    • Curtissimo
      HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
      by Curtissimo
      Hi everyone.
      I have a HP Elitebook 850 G8.
      Serial: 5CG2324XM0
      ProdID 6L8D5EC#ABA
      It has a Winbond W25Q256JVEN Chip.
      I need to remove BIOS Password.
      I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
      Attached my dump.
      I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
      I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
      What I did:...
      08-26-2025, 04:42 AM
    • Sorrow1
      Intergraph TDZ 2000 mainboard post code 2F/2E
      by Sorrow1
      I try to repair an old Intergraph TDZ 2000 from 1998. It is a dual Pentum II machine based on Intel 440LX chipset. There is a non-removable bios chip named PhoenixBios B1787840. I cannot see any physical damage to the board. All caps look OK.
      It shows no picture and POST stops with code 2F/2E regardless whether or not any graphic card is plugged in. If memory is removed, it stops on previous code 28/17 and stars beeping. I tested both CPUs in another machine and I also use RAM from another machine.
      When I recorded video of POST card and played it in slow...
      01-03-2024, 04:13 AM
    • DynaxSC
      MSI PRO Z690-A DDR4 (MS-7D25) - stuck during boot every second time - debug code 16 & A1
      by DynaxSC
      Hi Folks
      I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
      Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works
      09-29-2024, 04:27 PM
    • saghi88
      looking for part number (Marking code 46BF) Case DFN8 3x3
      by saghi88
      I am looking for the part number of this component so I can order it. I cannot identify it based on the marking code; I think it is an LDO IC. Can anyone determine the manufacturer's part number from the marking code?
      I have uploaded images showing the dimensions and the marking code of the IC. I believe the package is a DFN-8 with dimensions of 3 mm × 3 mm × 0.9 mm.
      Thank you in advance for your support
      11-21-2025, 03:38 AM
