is it bad to have the heatsink puching against caps?
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    i put the board from a 1u server (dual p3) - into an atx case. and i also got bigger heatsinks (the original super tiny ones reached up to 97c sometimes idle not kidding
    now my temps are better but i had to push the heatsink really hard against the caps was worried id tear them out. it seems ok though but will this be bad in the long run?
  • seanc
    • Nov 2008
    • 1319
    Re: is it bad to have the heatsink puching against caps?
    Pushing against the top of the caps, or pushing them out sideways?
    Both are bad.
    The former could create a short, the latter could damage the capacitor, capacitor lead or bung seal.
    • Rob Northen
      • Jan 2010
      • 137
      • Denmark
      Heatsinks tend to get.. warm and caps up close ?
      VERY BAD!
      • seanc
        • Nov 2008
        • 1319
        I also forgot the other obvious point that Rob mentioned :P
        • berniedd
          • Mar 2007
          • 119
          Definitely not good. If you want cooler processors, you could grind down the offending appendages on your new heatsinks to avoid hitting the caps. Better yet, upgrade the fans to faster/better units instead of the heatsinks.
          • stevo1210
            • Oct 2006
            • 4156
            yes, you might actually end up frying those caps!
            Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              hmmm...ok. this was supposed to be server fr my house eventually so it must be reliable.
              ok so im seeing this isnt good.
              but to whoever asked, pushing the sideways.
              would i have been safe to say if it still works a weeks later it'll be fine. and btw theyre rubycons so theyre good if it were an ost or something i wouldnt even have done it
              • dood
                Deputy dood
                • Mar 2004
                • 2462
                I just replaced some Rubycons that had been cooked by an excessively hot SFF PC. Even Rubycons will cook if exposed to higher temps. Pushing the caps sideways pulls the leads through the bung on the one side, which can lead to leakage of the electrolyte.
                It's one thing to mount caps sideways so that they clear (by soldering one leg slightly out of the board), but it's a whole 'nother thing to pull one sideways that's already hard soldered to the board.
                I would shoot for taller, not wider, heatsinks.
                Ludicrous gibs!
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  i didnt realize the caps were super close to the socket when i ordered the sinks on ebay
                  • dood
                    Deputy dood
                    • Mar 2004
                    • 2462
                    Well, lesson learned. Always keep an eye on how close things are to the socket before you order oversized HSF's !
                    Ludicrous gibs!
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      An option is to cut or notch the heat-sinks for cap clearance.
                      Not hard to do with aluminum.
                      Mann-Made Global Warming.
                      - Dr Seuss
                        • 31028
                        foto's ?
                        • StevieC
                          Talkative Loon
                          • Sep 2008
                          • 19
                          So we know that it's bad if the heat-sink is PUSHING on the cap. What about if it's just touching or merely brushing the cap with virtually no contact at all?
                            • 31028
                            some airspace would be preferable.
                            or chill the fuck out of the heatsinks.
                            what i did once on a dual p3 slot-type, was to remove the small fans from each sink and fit a 120mm blowing DOWN over both sinks at the same time.
                            that workd well.
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Yes you want some airspace there.
                              Heating up caps => bad.
                              According to most cap manufacturers for each 10 degrees C you raise cap temp the cap's Life-Span is reduced by 50%.
                              - It's logarithmic.
                              - It stacks up fast.
                              Assuming a cap is good for 12 years at 50C....
                              .... it's good for 6 years at 60C, 3 years at 70C and 1.5 years at 80C.
                              And before it goes there again...
                              The 'Lifetime' given in datasheets doesn't have much to do with Life-Span.
                              The 'Lifetime' given is actually 'Endurance Lifetime' which is how many hours you can abuse the snot out of a cap WITHOUT causing permanent damage.
                              There are equations to estimate Life-Span from the advertised 'Endurance Lifetime' but they are only good to +/-40% accuracy.
                              If the equations determine a Life-Span of 8 years then with +/-40% what it really means is "anywhere from 4.8 years to 11.2 years."
                              So: from a practical standpoint those equations don't give useful numbers and are a waste of your time.
                              - Dr Seuss
                                by momaka
                                03-12-2025, 03:42 PM
                                by momaka
                                03-15-2023, 10:17 PM
                              • eryjus
                                by eryjus
                                05-10-2023, 11:21 AM
                              • Paxman_Swede
                                by Paxman_Swede
                                Hello!
                                01-14-2025, 09:51 AM
                              • captain150
                                by captain150
                                03-16-2025, 07:34 PM
