KVM switch - any experiences/recommendations
  • bigbeark
    • Jan 2010
    • 661
    I recently bought a Compaq 4110 8 Port PS/2 KVM Switch with cables.
    I expected a simple mechanical switch that would hook up multiple boxes to a single keyboard mouse and monitor. Sort of like a rotary switch, think car headlight switch where you would select the box you wanted and then power up that box.
    Since I have some older machines that may not support USB keyboards and mice, I was keen on the PS/2 hookup.
    The actual switch turns out to be quite a sophisticated electronic device. You can power up all eight computers and toggle between them using the switch. You use the keyboard to toggle between the boxes. The manual suggests max resolution of 1024x768.
    I have not used anything like this before. Does anyone have any experience of these devices and opinions about them. Any mistakes to avoid? Thanks for the input.
  • digge
    • Apr 2006
    • 296
    Re: KVM switch - any experiences/recommendations
    Make sure not to play around with the cables too much while using it. Best case it will just hang, worst case you will fry a ps/2 port. So turn everything of when connecting/disconnecting and youll be fine. That is the only caveat i know compared to an USB KVM.
    Then ofc there is the DVI/HDMI problems some have when swapping between computers but as its ps/2 im guessing its VGA only?
      Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
      This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
      09-06-2024, 05:30 AM
    • Natob82
      Micro Momentary Push Switch?
      by Natob82
      Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
      12-21-2022, 05:22 AM
    • grimacelord
      NEC TurboExpress On/Off Power Switch Replacement Help
      by grimacelord
      I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
      I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
      I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
      11-09-2023, 09:49 AM
    • SluggerB
      Help making a switch work the opposite way with a relay
      by SluggerB
      I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
      I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
      It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
      02-07-2025, 07:57 PM
      Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more cams
      Panel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
      ( needs more cam circuits for the machine to work correctly again )
      https://www.ebay.com/itm/275321870186
      To
      3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
      ( not 4 positions but the right amount of cams circuits )
      https://www.ebay.com/itm/274660439950
      I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around...
      03-18-2023, 05:12 PM
