No power off
+ More Options
Posts
  • stevo1210
    • Oct 2006
    • 4156
    No power off
    My friend has a PC that has one of the strangest issues I've ever seen. He called me over today to have a look and I was basically stumped. Basically you can't turn it off whatsoever. This only happened about a month or two ago after he removed the PSU to clean it since it was clogged with dust. Once he put the PSU back in it wouldn't turn off.... meaning when you used windows shutdown, it would turn off then about 3 seconds after it would turn back on by itself. Changing to a new Delta PSU made no difference at all... so I can rule the PSU out.
    All options such as wake on LAN, wake on ring/PME is set to disabled or off. After power failure or whatever ist's called is also set to *stay off*.
    The motherboard is an Intel genuine desktop board with an 865 chipset and the CPU is an Intel Pentium 4 2.4GHz.
    I'm stumped. I think it's a hard ware issue since we even went through the effort of re-installing Windows 7 with XP etc. and that didn't change anything!
    Thanks.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: No power off
    Either has Nichicon HM or has 85C 4&5mm caps and one of them is a partial short [leaky].
    Mann-Made Global Warming.
    - Dr Seuss
    • seanc
      • Nov 2008
      • 1319
      Re: No power off
      I know someone with a Gigabyte board that does this too - 8iG1000MK so I think it's even the same/similar chipset.
      There was nothing obviously wrong when I looked at it, I think the person just leaves it on.
      If it comes back I'll replace the board in it.
      • c_hegge
        • Sep 2009
        • 5219
        Re: No power off
        Definately sounds like there's some issue with the motherboard. Exactly what, though, is hard to say. It could be the caps, like PCBONEZ suggested, or it could be something else.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Re: No power off
          shorted green pwr on wire... something might have fallen in there...
          all of the standoffs are the correct length? you could be shorting in that way as well.
          sigpic
          (Insert witty quote here)
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Re: No power off
            I have two 8iG1000MK in stock and they don't do that.
            One did have HM and I think both had crap for 4 & 5 mm caps.
            As I said, odds are there is a leaky or partially shorted cap [probably 4 or 5 mm] that is pulling down some voltage effectively faking and locking in a WOL signal, WOR signal, or a pushed power button.
            Might also be in the 'green wire' circuit but the effect is the same.
            The delay is because the cap isn't totally shorted yet.
            - Dr Seuss
            • seanc
              • Nov 2008
              • 1319
              Re: No power off
              Oh don't get me wrong PCBONEZ, this is one 8iG1000MK out of 60 or so that have been out on rental.
              Some blew their Nichion HM caps, others have Rubycon and are fine, then there's this one that has a power-off/on issue.
              It's been at least a year since the problem was reported and I would have had the machine back if it had become a bigger problem.
              • everell
                • Jan 2009
                • 1514
                Re: No power off
                A friend had a computer that would run for a while, then reboot, randomly.
                Took a while to figure it out, but it turned out to be a bad reset button.
                In your case it might be the power-on button. Try turning the computer on, then unplug the power on button from the mobo, then shut down with windows and see if that fixes it.
                Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Re: No power off
                  I actually still have my notes on the 8iG1000MK
                  One had all KZG in VRM and MBZ for the scattered 1000uF.
                  Other had mixed HM and MBZ in VRM and HM for the scattered 1000uF.
                  Then the little 100 & 22 uF were a mix of G-Luxon, GSC, and Swcon.
                  Wanna bet your buggy board has GSC there?
                  - Dr Seuss
                  • seanc
                    • Nov 2008
                    • 1319
                    Re: No power off
                    You can bet.... If I see the PC again, I'll let you know.
                    Just remembered that a couple of the boards have baked a Rubycon below the AGP slot.
                    Apart from that, they're nice boards.
                    • PantherDave
                      by PantherDave
                      Hi all!
                      05-29-2024, 02:01 PM
                    • GLISIT
                      by GLISIT
                      01-16-2025, 02:29 PM
                      03-31-2024, 02:12 PM
                      09-06-2024, 05:59 AM
                      HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                      This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-12-2024, 02:15 PM
