Company Locked Laptops
  • brethin
    replied
    Re: Company Locked Laptops
    I believe changing the windows hardware ID from the one linked to Autopilot will also solve your problem.
  • MBAS111
    replied
    Hi thanks all for your help I think the best option to go with was to install windows home instead which seems to work
  • televizora
    replied
    It's Windows Autopilot. The message says "Sign in with Microsoft - School or work account"
    I've seen this before on several laptops. You can't bypass the screen, it demands it.
    There is workaround - installing very old version of Windows10.
    "It seems like" this "thing" writes something into the UEFI. Even complete wipe of the drive and new installation won't do any good. Even if the machine isn't connected to the internet. First it will demand internet connection to continue and wont allow you to create local account. When you connect it to the internet, it will demand you to enter your "work or school account" to continue, without an option to create new microsoft or local account.
    I've tried modifying ei.cfg, using different edition, bypassing the screen using OOBE bypass and command prompt to create new account. One can truly call this thing "malware".
    Even with enabled default administrator or creating local account or even linking another microsoft account, it continues to demand to enter the old "work or school account".
    Unfortunately, there isn't really much information about this. And I am not so keen on dissecting and digging in the bios flash of laptop that isn't my own to analyse the problem.
    Surely, rewriting the bios flash will get rid of it. But there is that little issue that most likely this won't be the only thing you will need to rewrite/modify. And information about this is relatively scarce.
    replied
    Originally posted by MBAS111
    when installing the option never pops up to install windows home
    install Linux,
    nobody actually wants win10 or win11 - even if many dont realise it yet.
    replied
    Originally posted by SMDFlea
    Seems like Microsoft Autopilot
    does this crap embed into the bios??
    i'v not heard about it before.
  • MBAS111
    replied
    Originally posted by RethoricalCheese
    Easiest would be to install either Linux or Windows Home since Autopilot is a Windows Pro/Enterprise feature and Home/Linux will not check if autopilot is enabled.
    There is a more advanced method aswell but since I haven't tried it myself, I won't even comment on that.
  • RethoricalCheese
    replied
    replied
    I am considered a noob in this matter even if i did get a dump is there any instruction on what exactly I'm supposed to be looking at? and what I do when I find the problem?
    There are a few threads, use the forum search: "Autopilot"
    replied
    Originally posted by stj
    it doesnt sound like a lock - it sounds like a persistant app as a bios-extension.
    similar to the computrace malware.
  • MBAS111
    replied
    this is probably some "malware" installed in the EFI bios.
    so you could try taking a full bios dump and looking at it in a bios editor like this:
    https://github.com/LongSoft/UEFITool
  • MBAS111
    replied
    is there a way of removing it then? I find it difficult to believe that there is not topic on this issue
  • MBAS111
    replied
    Youve already posted a bios unlock request,more than once... https://www.badcaps.net/forum/showthread.php?p=1201219 .If the Lenovo Autopatcher doesn`t work then the only option is unlocking via JTAG, and you`ll need a dedicated programmer to do that.
    T14s forum search - https://www.badcaps.net/forum/search...rchid=32154929
    P14s forum search - https://www.badcaps.net/forum/search...rchid=32154934
    I/O Programmers:
    Vertyanov SUCCESSOR
    SVOD4
    RT809H
    Hi the bios request for a different laptop I have 3 the first with a bios password and the other two as explained have a block onto a company which i cannot over come my question is if I get a fresh Bios will this solve the Issue? also you said about if the Auto patcher does not work i need to use JTAG. On which chip? and is there a instruction on this topic?
  • fxreen
    replied
    Windows Autopilot
    https://learn.microsoft.com/en-us/me...dows-autopilot
    Is there a solution? Yes, we make all models here.
    replied
    replied
    thinkpad P14S Gen 1 20S5-S25F00
    thinkpad T14S Gen2 20WN-S00K00
    I/O Programmers:
    Vertyanov SUCCESSOR
    SVOD4
    RT809H
    replied
  • MBAS111
    replied
    Originally posted by zomi
    What make and model ?
  • zomi
    replied
  • MBAS111
    replied
    Originally posted by TechGeek
    Contact the company who sold them to you and ask them to remove them from their device management system.
    Hi these are sold in to second hand stores and are checked to see if they are stolen and are not so when purchased the system was working until was reset to sell onto a customer.
    SO bottom line these are useless?
  • TechGeek
    replied
  • nerujan
    Need help removing “Managed by: ABC Company” from BIOS on Surface Laptop 4 and 5
    by nerujan
    I need step-by-step guidance for an issue I’m facing. I’m a technician, and I have several Microsoft Surface Laptop 4 and Surface Laptop 5 devices that were MDM-locked through Autopilot.
    There is no BIOS password, and I successfully removed the Autopilot lock using PowerShell. The laptops now work fine, but the BIOS still shows “Managed by: ABC Company” under the Management section.
    I would like to know how to remove this management information from the BIOS without changing the serial number. I’ve searched a lot but couldn’t find any...
    11-02-2025, 09:24 AM
  • NanoTesting
    Anyone else been having problems with chinese laptops using ESSX8336 / ES8336 audio?
    by NanoTesting
    This audio chipset has been a pain to deal with, most of the time its impossible to find drivers for chinese laptops that have no name/brand, or generic rebranded laptops.
    Huawei also started to use it BUT they no longer host drivers on their website since they want you to force their PC manager app that often refuses to install after bios flashing and apparently the generic drivers around wont work on some intel systems and others wont work on amd systems, the generic ones have worked only once and i think i have had this problem on 30+ laptops so far in the last year.
    02-21-2025, 12:33 AM
  • SuperAman
    Keyboard replacement not working issues with Win 10/11 (2) different laptops
    by SuperAman
    I have had an issue that I've never come across in all my years of laptop repairs and it has happened twice in the last couple of weeks. The issue occurred on 2 laptops.
    1. The first laptop a Lenovo Yoga 7 convertible 14 inch 13th gen i7. This laptop came in working, customer wanted to replace the top keyboard assembly for cosmetic reasons so I replaced the keyobard assembly and put their touchpad in it. After booting into windows it would not work, so I assumed I needed to update it or something. Since they didn't give me the Admin account, as it was a company laptop and the...
    08-31-2024, 07:30 PM
  • the_raz
    Need (unlocked) bios for HP Probook 450 G3 Notebook
    by the_raz
    I'm requesting a bios .bin for 2 of my hp Probook 450 G3's. Both of which I had forgotten the bios passwords. I stupidly flashed both of them with firmware "made" by the RCUnlocker software and I guess I shouldn't have. The last thing I did was flash both of them with RCUnlocker-fw thinking it would 100% work and left my programmer etc behind and won't have access to them for another 2 days so I figured I'd create a thread to see if I'd be so lucky that someone might have a working file laying around 😝
    Laptop number 1:
    Model: HP ProBook 450 G3
    Motherboard part number:...
    12-17-2024, 03:37 PM
  • Oknarb
    Microsoft Surface 3 1867 locked by organisation (autopilot)
    by Oknarb
    I have microsoft surface 1867 locked by organisation. When i try reinstall system, in moment connect to the Internet, it asks for for company email and pass. Can anyone fix it?
    SN: 019831602857...
    03-19-2024, 05:49 AM
