Nvidia Chipset problems - What's affected?
  • c_hegge
    • Sep 2009
    • 5219
    We all know about the problems with nvidia chipsets and GPUs. My question is, exactly what Chipsets and GPUs are affected? From what I've read, the 8-series GPUs are affected, but is there anything else?
  • Shodan486
    • Nov 2009
    • 203
    Re: Nvidia Chipset problems - What's affected?
    Quite a hard one to tell...
    Well, I only owned the NF3-150 once for a while and showed me no problems - probably due to the AGP which had no problems in those times with Nforce chipsets...but as for todays PCIe...really I have no idea. I personally do not recommend any contemporary (if they're still out there) Nforce crap - really don't know what happened in Nvidia...Have only some bad experience with RAM speed setup, it always degraded 800MHz to 667 and won't run stable at all, tried A-data & Corsair = fair brands, one low and the second high end manufacturer to me. But as for the GPUs, no experience...could you specify further what are the problems in peculiar? Lazy to browse google
    Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      There is a similar post here, I posted some links if you wanna read up on it...
      https://www.badcaps.net/forum/showthread.php?t=10765
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Last I heard it includes:
        G92, G92B, G86, G86A2, G84, C51, G72, G72M, G73, G72A3, MCP67, MCP73V and NV42.
        http://www.tgdaily.com/business-and-...chips-payments
        http://www.theinquirer.net/inquirer/...sets-defective
        I basically consider anything nVidia made with a 2007 or 2008 date code as suspect.
        Mann-Made Global Warming.
        - Dr Seuss
          • 31303
          6xxx-8xxx and all mobile equivelents.
          9xxx series is fixed.
          • c_hegge
            • Sep 2009
            • 5219
            6 series GPUs? I didn't know the problem went back that far.
            Reason I ask is because I have a system with an MCP61 chipset. Did the problem affect motherboard chipsets? or was it only graphics cards?
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              G71 too, remember it's all variants, desktop, mobile and workstation (Quadro)
              http://vr-zone.com/articles/3-year-o...resh/6515.html
                • 31303
                you need to remember it is mostly only a problem with laptops simply because you cant put a copper housebrick in a laptop
                although the agp / pci cards still cook the shit out of the caps.
                • Per Hansson
                  • Jul 2005
                  • 5895
                  • Sweden
                  stj; Yea, it is a heat issue
                  If the standard cooler is replaced with a beefy copper one (or as in my case a water block) then the cards will be fine
                  I have used a 8800GTS 512MB G92 for almost 3 years now, voltmodded and heavily overclocked...
                  I have noted tho that the maximum clock I can achieve has been reduced by 20Mhz
                  So clearly the silicon can't take a beating at high vgpu, not that this should be seen as anything strange of course, it's true for all silicon
                  But just that nVidia's bean counters probably did push the limits too far this time...
                  • piernov
                    NVidia bumpgate
                    by piernov
                    Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                    Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                    May complete this post at a later date with more details.
                    Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                    03-27-2021, 10:34 AM
                    NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
                    The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
                    10-02-2024, 08:52 AM
                    NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
                    The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
                    10-02-2024, 07:51 AM
                    NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
                    The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
                    10-01-2024, 01:54 PM
                    HP ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) ProDesk 400 i5-6500 Specification for Upgrade or Repair
                    This specification for the HP ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) boardview and ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                    09-12-2024, 03:30 PM
