Unknown caps identifying thread
  • Behemot
    • 4845
    • CZ
    Since I find (for me) unknow caps usually once a month, I'll start separate thread for them to not pollute other threads
    Here is the first one. I swear I've seen the triangle logo somewhere but cannot recall it now.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Unknown caps identifying thread
    The caps I found in my monitor, never heard of them before
    I think the logo says "NK Con" but I find only one other hit on the forums for them, except mine...
    https://www.badcaps.net/forum/showpo...5&postcount=56
    • Behemot
      • 4845
      • CZ
      I've put my hand into crap bag, here comes the impression...
      1. Acon
      2. Fu Lee
      3. GJT
      4. SWC
      5. HI-Q probably from radio alarm clock
      6. REC and MW (?) from the same alarm clock
      7. nice Roederstein on the end...they're rather good, aren't they? I asked -HoNY- for ESR meter, I'll have them measured...
      • 370forlife
        Large Marge
        • Aug 2008
        • 3113
        http://capacitor.web.fc2.com/ is your friend.
        • Behemot
          • 4845
          • CZ
          Good, thanks. But still, I automatically count everything I don't know as bad, it's safety precaution, and these caps I didn't find here. So I've placed the images here for informing others rather than myself, I don't want to know anything about them anyway
          Only exception is the cap in 1st post cause it looks like from Japan and in that old TV was high-quality caps only so there is high possibility these one is good to. Also the web won't help as long as there are no logos.
          • japlytic
            • Oct 2005
            • 2086
            The triangle logo indicates Matsushita (now Panasonic). This was their past logo.
            • Behemot
              • 4845
              • CZ
              Thanks japlytic!
              • Toasty
                • Jul 2007
                • 4171
                The REC in post 3 is actually TREC. They have been the subject of posts here before.
                http://capacitor.web.fc2.com/t.html#trec
                veritas odium parit
                • larrymoencurly
                  • Oct 2004
                  • 960
                  It's for Panasonic/Matsushita:
                  For some reason, it's not shown at the http://capacitor.web.fc2.com/ website.
                  • Paxman_Swede
                    by Paxman_Swede
                    Hello!
                    01-14-2025, 09:51 AM
                    by momaka
                    03-12-2025, 03:42 PM
                  • crosswinds
                    Assistance with identifying replacement caps on ASUS P5VDZ-MX
                    by crosswinds
                    So, pulled a motherboard out from storage, was working when put away, wont post when I took it out of storage today.
                    Since it was working, and it looks to be essentially time that killed it I figured its a good idea to replace the caps before digging further.
                    Looks to be only good quality caps on this board, so might not be the issue. But it is closing in on 20 years now so, wont hurt i guess
                    Its a ASUS P5VDZ-MX board.
                    I would really appreciate some assistance on what the best replacement caps would be for these:
                    Panasonic(M)...
                    04-17-2024, 04:25 PM
                  • eryjus
                    by eryjus
                    05-10-2023, 11:21 AM
                  • fl0w
                    GeForce 6800GT recap, need help identifying caps and finding replacements
                    by fl0w
                    I just noticed that my Asus V9999GT (GeForce 6800 GT) had some swelling capacitors. I managed to identify the brown ones, which are Nippon Chemi-Con KZG series, 6.3V 820µF, which I plan to replace with this.
                    But for the yellow ones, I guess these are Fujitsu caps, without being able to identify which series... A picture of the video card is attached to the topic.
                    I need to replace:
                    • 2x 2.5V 1500µF => I plan to use this
                    • 2x 16V 330µF=> I plan to use this
                    • 1x 6.3V 680µF=> I plan to use this
                    Am I correct with the cap choices?
                    Thanks for...
                    10-02-2024, 11:28 AM
