Caps discoloring
  • Runnerboys
    Mordex
    • Dec 2021
    • 7
    Caps discoloring
    I'm new here, trying to get some help with a repair
    We found a short on the PPVDD_GPU
    I want to hope it's only bad capacitors, the attached pic shows the short area
    Getting 0V on all caps marked in red
    Other areas of the board seem to get the correct Voltages
    Can I assume the problem is with a burned cap?
    Will try to send direct Voltage to a cap in the circuit and check what gets hot first
    If we find a bad cap and replace / remove it, and assuming problem consists, what would be the next step for the troubleshoot?
    Also sending a pic of the caps in question, some are discoloredhttps://ibb.co/tZxj2sV but I don't know if that's normal or that's an indication for bad caps
    tnx in advance
  • Runnerboys
    Mordex
    • Dec 2021
    • 7
    Re: Caps discoloring
    please see attached pics
      • 31015
      i must have missed the part where you told us what you are repairing
      • Runnerboys
        Mordex
        • Dec 2021
        • 7
        Sorry for that
        It's for an iPad 11 2nd gen
        • PeteS in CA
          • Aug 2005
          • 3580
          • USA, Unsure of Planet
          Not all MLCCs are the same outer color.
          PeteS in CA
          • Runnerboys
            Mordex
            • Dec 2021
            • 7
            thanks,
