Post help identifying capacitors here
This is a sticky topic.
  • PeteS in CA
    replied
    Given the age, if it is an electrolytic I'd suggest Nichicon PS, PM, PJ, or PW series, in that order of preference, whatever fits. I'm not sure whether polymer caps were coming into use in 1996.
    commented on 's reply
    pics would be good
  • ghost180sx
    replied
    Hey all. I'm recalpping an Artesyn P/N 22943505 PSU with SGI P/N 060-0021-002 Rev A for an Indigo2 IMPACT and have come across some bad caps that I can't identify a replacement for. They're red, very small, made by Marcom. I think they are FP-Caps (functional polymer/solid caps), but Marcom got bought up Nippon Chemi-Con a year before these caps were produced. They are 330uF, 6.3V, 105degC, red in color with a silver "-" stripe, 10x10mm and one of three on the board tested bad with an LCR meter. They are marked "CFM" (the series) and "9614" which I'm told is how Marcom prints the manuf. date of 1996 14th week.
    Let me know if you need a pic.
  • kalemaroni
    replied
    Originally posted by Bushcat
    Elite/Chinsan aluminum electrolytic, EH series, 4.7 uF with maybe 20% tolerance, 100 V, rated to 105 C. If you search on the web site, Chinsan uses both 4.7 and 5 to refer to its 4.7 uF caps (and the usual 4R7 in parts numbers). The link in the post above me will get you started on your long, long journey through the Chinsan parts list... it's just a standard low-impedance cap so there are a lot of alternatives.
    (Maybe that's a 47 and not a 4.7: the "." might be a reflection.)
    Thank you very much
  • Bushcat
    replied
    Originally posted by kalemaroni
    Anyone know what the above cap is? Have I not provided enough info?
  • filmbot
    replied
    Nichicon functional polymer, 560 uF, 6.3V
    Thanks!
  • kasfamily
    replied
    http://www.chinsan.com/welcome/
  • Bushcat
    replied
    Originally posted by filmbot
    Anyone able to help fully identify this cap?
  • filmbot
    replied
    Anyone able to help fully identify this cap? Need to get a replacement. It was ripped off a Asus motherboard.
  • kalemaroni
    replied
  • kalemaroni
    replied
    4.7uF 100v
    (M)105c EH(M)10
    9091537 (C)19091
    Would like to know what ESR it needs for buying from Digikey/Farnell/Mouser etc.
    replied
    Originally posted by Major_Custom_Computing
    Looking for help on this - missing from board. I'm new to this so not sure how to interpret.
    PC210 is 2200 pico farads , 0402 is the size , 25 Volts. You can find capacitor conversion charts online to convert between micro fardas uF , pico farads pF and nano farads nF .
  • Major_Custom_Computing
    replied
  • James Boden
    replied
    Hi Iam trying to look for this on the net it states it's a 560 , 2DDtn p. But I can't seem to find anything about it .. on my meter it comes up as 1.5 uf so Iam a little confused and have started to think Iam doing something stupid.. any enlightenment would be appreciated 😆.
  • radoslaw jaworski
    replied
    Hi all is anyone able to send me to right web page where i can buy one of those FP10K 07Cz 5 6 1 6.3. Thank You
  • jm1234
    replied
    I'm trying to replace what seems to be a film(?) Epcos capacitors labeled with:
    Z111774865 P10
    U12 J 900 D8
    I'm guessing it's a 120nF 900V? But I would appreciate exact reference, because google doesn't find Z111774865 at all.
    They came from a Siemens induction heater, 3 of them are connected in parallel between the 2 wires that power individual induction segment.
    Their size is aprox. 26mmx15mmx7mm.
    Thanks for any help
  • udonome
    replied
    Originally posted by lti
    http://www.paullinebarger.net/DS/RM%...E%20Series.pdf
    Those look a lot smaller than 8x12mm, though.
    Thanks for the prompt respond.
    From your PDF, the chart shows the only part that matches the description 16V / 220UF is size 8x12 , right?
    But those on my boards seems to be of size 6.3x11.
    So i have a question, do the "(IR) Ripple Current " value and "(Z) Impedance" value have to accurately match the original ones ?
    I guess there is enough space available to replace them with the larger 8x12 but will it affect / degrade / damage the board ?
  • lti
    replied
  • udonome
    replied
    pls identify these capacitor, they are all damaged and i need to fix this hikvision board
  • thinkfast76
    replied
    68uF, 16V tantalum or polymer. "519" is the date or lot code.
    Thx a lot , just find on a old macbook motherboard
  • varkatope
    Need help identifying capacitors on an MSI MS6163 ver 1. motherboard
    by varkatope
    Hey there, retro fans.
    I have an MS6163 version 1 board I'm trying to repair which was obviously used as a donor because it's missing a few parts, mostly capacitors. There are few high quality images online that would allow me to read the capacitor values (bad angle, blurry photos). I thiiiink I've figured out most of the values for the missing ones except for one in particular, number C210, which is in the bottom-left of the attached photo. Could someone with this board be so kind as to take a look at theirs and tell me the capacitance and voltage values of all the highlighted missing...
    12-15-2024, 09:48 AM
  • dragon3x
    After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
    by dragon3x
    Hi, I have some 32 bits computer motherboards that need repair, as they fail to
    power on.
    Here are some examples :
    (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
    switching supply area).
    (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
    than 6.3 V.)
    1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
    I replaced capacitors with aluminum-polymer.
    3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
    03-21-2025, 02:46 PM
  • slybunda
    AA and AAA battery charger capacitors?
    by slybunda
    hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
    it has inside:
    2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
    2 x 470uf 16v LZ105c branded as G.Luxon
    not heard of these brands are they any good?
    iv attached photos of the charger and the board inside for an idea on the type of...
    12-24-2023, 04:41 AM
    by sam_sam_sam
    After all of...
    07-13-2024, 08:14 PM
  • Ady2017
    Are there any datasheets available for Elna RJG capacitors?
    by Ady2017
    I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
    05-25-2025, 02:19 PM
