Post help identifying capacitors here
This is a sticky topic.
  • stevesg
    replied
    can anybody identify this 10U_0603_25V6M
    10U_0603_25V6M
    i need to know what to replace this with i assume it is 10uf and 0603 size, 25volt, but what does the 6m mean, is it 20% 10%
    many thanks
    replied
    Originally posted by scottl31
    So the markings 10V, 470 uF are all I need to worry about? All the other characters on there don't mean anything?
    The "HC" marks indicate that these are Nichicon HC series - a low impedance type of capacitor. So you need to get the same type - i.e. match the impedance/ESR and ripple current to generally within +/-30%. The brands and series I listed in my previous post should all be close enough. So just look for, for example, Rubycon ZLH or ZLQ on Digikey, and you should be able to find good-matching replacements.
  • scottl31
    replied
    Originally posted by momaka
    The cap that scottl31 posted above is Nichicon HC series, as lti correctly identified.
    EB series from Panasonic is not quite adequate in that case, if ESR and ripple current capability are to be observed.
    Relatively close replacements would be United Chemicon KZE and KZH or Rubycon ZLH or ZLQ. All of these are readily available on both Mouser and Dikigey ATM. Just match the capacitance and the voltage (10V, 470 uF), along with the diameter. Height-wise, UCC KZH and Rubycon ZLH and ZLQ will likely both be shorter, since they are newer miniaturized series.
    *edit*
    Forgot to add... Nichicon HW and HV series would also be close enough (if not better), along with Panasonic FR and FS. These are also readily available on Digikey and Mouser.
    Happy hunting!
  • GASPARD
    replied
    Tranks!
  • semiRocket
    replied
    Hi, first time I see I cap like this, I suspect it is anyway as it is marked as C124 on the PCB. The markings means 0.1uF, 400V?
    Well the in circuit ESR shows around 88ohms, I suspect something is not right...
    replied
    *edit*
    Happy hunting!
  • CapLeaker
    replied
    Mine are through hole with two legs. This one you mention at digikey looks like it's not through hole. Is this right?
    Click image for larger version  Name:	Screen Shot 2025-07-01 at 11.58.00 AM.png Views:	0 Size:	122.0 KB ID:	3672594
    Then just fit a regular through hole capacitor like
    EEU-EB1A471
    just watch the leg spacing, diameter and height.
  • scottl31
    replied
    470uF, 10V
    go for something 105c rated 470 uF 10V or 16V, at least 5000hrs rated.. Like
    EEE-FK1A471GV
    on Digikey.
  • lti
    replied
    That looks like Nichicon HC series. That's a through-hole series, but I don't see a plastic base or surface mount pads in your picture. For a while, Nichicon marked some of their through-hole series like that.
  • CapLeaker
    replied
    I don't know how to read the markings. Are you saying that either of those companies might have pictures on their site I can match this to? Thanks!
    470uF, 10V
    EEE-FK1A471GV
    on Digikey.
  • scottl31
    replied
    Mouser or DigiKey. But you can use just regular through hole capacitors too. You just bend the legs outwards.
  • CapLeaker
    replied
    Would anyone know where I could purchase a capacitor like this in the picture?
    Thanks,
    Scott Click image for larger version
  • scottl31
    replied
    Thanks,
  • m2farid
    replied
    Those one, please. Thanks
  • m2farid
    replied
    Hi could you please help me identify the capacitors arround bios chips
  • DRKNSIDE
    replied
    looking for identity and where i can locate one of these capacitors shows 20K 560J E13 or E73 can really tell, Thanks!
  • ghost180sx
    replied
    Originally posted by Hitto
    Yes, Marcon (''N'') which is a diminutive of Marconi (in honor of Guglielmo Marconi, I suppose) and these are very old capacitors available in stores here in Italy in the era mentioned by PeteS in CA. They are still available as N.O.S. on some shops.
    I also reinforce that, given their era, this is not a polymer. I would replace it with a Panasonic FC but also Nichicon PM would be perfect (E.S.R. not too low and capable of handling high frequencies). I would derate and use a 10V replacement.
    EDIT: I confirm, electrolytic. As per specifictions in the inventory of a shop which sells N.O.S. parts. Picture attached.
    Thanks Hitto & PeteS in CA!
    I'll be ordering some nice electrolytics as replacements.
  • Hitto
    replied
  • ghost180sx
    replied
    Originally posted by ghost180sx
    Does anybody have any old Marcom data books or data sheets to confirm it's a polymer or what the CFM series was?
ID:	3531321Click image for larger version
    My bad, these are made by Marcon, ending with an "n". Marcon Electronics, a former subsidiary of Toshiba Corp, then bought up by United Chemi-Con.
    See: https://www.procureinc.com/manufactu...ted_Chemi-Con/
  • ghost180sx
    replied
    Given the age, if it is an electrolytic I'd suggest Nichicon PS, PM, PJ, or PW series, in that order of preference, whatever fits. I'm not sure whether polymer caps were coming into use in 1996.
    Thanks PeteS, that's what my friends in the SGI collector community have done. Then again, some have failed to repair their PSUs or had them fail after a recap. Most of us are flying "flying blind" tho as SGI never released any schematics.
    My PSU is working but outputting high ripple. It's very noticeable and was getting worse the more I used my machine, so I took it apart to fix the supply.
    This is the only one of three like it in the supply that tested bad with my LCR meter. The other caps in the PSU were getting old but in OK condition and within tolerances.
    Does anybody have any old Marcom data books or data sheets to confirm it's a polymer or what the CFM series was? I'd feel better replacing these three with a FP high ripple tolerant and super low ESR variant if that's what these are.
  • varkatope
    Need help identifying capacitors on an MSI MS6163 ver 1. motherboard
    by varkatope
    Hey there, retro fans.
    I have an MS6163 version 1 board I'm trying to repair which was obviously used as a donor because it's missing a few parts, mostly capacitors. There are few high quality images online that would allow me to read the capacitor values (bad angle, blurry photos). I thiiiink I've figured out most of the values for the missing ones except for one in particular, number C210, which is in the bottom-left of the attached photo. Could someone with this board be so kind as to take a look at theirs and tell me the capacitance and voltage values of all the highlighted missing...
    12-15-2024, 09:48 AM
  • dragon3x
    After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
    by dragon3x
    Hi, I have some 32 bits computer motherboards that need repair, as they fail to
    power on.
    Here are some examples :
    (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
    switching supply area).
    (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
    than 6.3 V.)
    1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
    I replaced capacitors with aluminum-polymer.
    3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
    03-21-2025, 02:46 PM
  • slybunda
    AA and AAA battery charger capacitors?
    by slybunda
    hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
    it has inside:
    2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
    2 x 470uf 16v LZ105c branded as G.Luxon
    not heard of these brands are they any good?
    iv attached photos of the charger and the board inside for an idea on the type of...
    12-24-2023, 04:41 AM
    by sam_sam_sam
    After all of...
    07-13-2024, 08:14 PM
  • Ady2017
    Are there any datasheets available for Elna RJG capacitors?
    by Ady2017
    I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
    05-25-2025, 02:19 PM
