Electric Button Breaker Thermal Overload Protection
  • SolomonMan
    • Apr 2019
    • 206
    All,
    I have two 120V compressors that I have been working on. Both are getting new Capacitors.
    As I am replacing the capacitors I am looking over the other electrical components.
    One compressor is a Harbor Freight 21 Gallon Vertical . The other is Horizontal Craftsman which is roughly the same size. The one Harbor Freight Capacitor was fried and the other looks like it may have opened. The Craftsman Starting Capacitor was/or has been leaking badly.
    The Harbor Freight Thermal Overload protector was lost over the past 10 years after the unit was originally torn down and put to the strip-down-use parts for another project pile.
    I can find no info on it for its original size. The outside of the tank says its 14.6 Amp/120V Compressor. It was originally a push button. Originally I was thinking of replacing it with a 15amp Thermal overload push button protector. After reading online about 1.25 times FLA/FLC which puts it more toward 20AMP (14.6X1.25) = 18.25. So what would be the proper size 15 or 20 Amp Protector?
    The Craftsman compressor situation is a little different. The Overload protector on it appears to be a flat device of sorts. It looks like it can manual reset itself (Get hot and shut off/cool and turn back on). I will try and get some pics. In either case the item appears maybe not to work. I am saying this as the starting capacitor is bad on the compressor and upon start up (testing) the house breaker will blow. I have tried it even on a dedicate 20AMP plug. Thoughts?
    Thanks for the help in advance,
    Chris
  • SolomonMan
    • Apr 2019
    • 206
    Re: Electric Button Breaker Thermal Overload Protection
    All,
    Please disregard the Craftsman overload Protection question.
    The small flat mechanical item turned out to be a Motor Switch. I found a part number on the unit and did a Google Search which brought it up for sale and then a I did a look at the purpose.
    The Harbor Freight Overload Protection question is still a valid question if anyone knows or has suggestions..
    Thanks everyone,
    Chris
    • redwire
      • 3912
      We'd need more info such as a model number, horsepower, the motor manufacturer etc. to help with a replacement overload that can fit.
      • SolomonMan
        • Apr 2019
        • 206
        Included is the tag off the side of the unit;
        Thanks,
        Chris
        • SolomonMan
          • Apr 2019
          • 206
          All,
          I am thinking I am going to use a Kill-A-Watt Tool to see what its pull is (a few times) and then go to the closest "related" thermal protection.
          Does that make sense?
          The two Capacitors arrived last night so hopefully this weekend I can try and spin this thing back up again.
          Thanks,
          Chris
          • SolomonMan
            • Apr 2019
            • 206
            All,
            The Central Pneumatic Unit is up and running.
            The Kill-A-Watt says 14.2 Amps.
            So I am thinking 15amp Thermal Protection mechanism.
            I also did a oil change. The electric motor does not appear to get hot or anything unusual at all. I let it get to pressure than drain it down 8 times in a row while I was working on the other compressor.
            I still have to pick up a pressure connector end as the compressor end leaks if its not hooked to a hose. The Thermal protector and the intake muffler is left to get both available on Amazon/Ebay.
            So for less than $40 its back up and running as a back up compressor for the one barn.
            Thanks everyone for the help[/consideration,
            Chris
              • 31191
              when reading current, it will rise with pressure.
              so if your compressor has a reservour tank you should watch the readings as it fills.
              • SolomonMan
                • Apr 2019
                • 206
                STJ,
                Thanks for the response!
                Yes I see what you mean on the rise of amps as pressure increases.
                On the Harbor Freight unit its not a large amount only about .15 Amps.
                On the Craftsman unit which is a higher pressure unit (135psi (crafstman) vs 120psi (Harbor Freight)) it was about a .333 amp.
                I ran both tanks multiple times and watched the amps. The 14.2 value given previously is the highest I saw out of Harbor Unit.
                Again everyone thanks for the help,
                Chris
                • SolomonMan
                  • Apr 2019
                  • 206
                  All,
                  I went with the 15 Amp.
                  I have installed and it has worked exceptionally well.
                  Thanks for the help,
                  Chris
                  • beetle1303
                    Electric oven tripping circuit breaker after turned on for 3-5 minutes
                    by beetle1303
                    My electric oven was working fine all the while from purchased 2 years ago. I have been using it weekly for about a year, but stopped using for a year now since then.
                    When I turn it on again yesterday, the tripped the circuit breaker and whole house no power supply. I reset the circuit breaker, and retried. Same thing happened.
                    This is what happened:
                    - Turned on the oven power supply, set temperature to 200c, everything worked for a few minutes, then the power tripped. Oven was warmed/hot.
                    - Reset circuit breaker, retried, same thing happened.
                    05-03-2020, 09:18 AM
                  • unimatrix93
                    LG fridge compressor not starting
                    by unimatrix93
                    Hello everyone, my old but loved LG GR-642 stopped cooling and frosting all together.
                    The display shows everything as normal, the focused cooling activated when I open the doors but the compressor wont start.
                    First I measured the terminals on the compressor at the back of the fridge. 0 volts.
                    Now I disconnected the compressor and measured resistance on its leads: around 8 ohms.
                    I dissassembled the main powerboard, couldn't find anything suspicious but I noticed that the comps relay wont send voltage to the pin, while Fan H and fan L is indeed at 230V....
                    11-22-2024, 03:27 AM
                  • e-repair
                    Broken connector on an electric boat power steering
                    by e-repair
                    Hey, i have to repair an electronic board on an electric power stearing. the package was damaged during delivery and the connector was broken. but i can't find a part. the connector is the same BUT reversed as fiat power steering. I searched on digikey, mouser and aliexpress and i can't find any part similar. it's an uflex electric power steering, but i don't have more reference on the power steering block. if needed, i can buy any complete part just to recover the conector on the board and put it on this board...
                    09-24-2025, 07:30 AM
                  • BigTroll
                    help with home a/c and circuit breaker
                    by BigTroll
                    while I was gone today the women called me and said the a/c isn't working and the breaker is buzzing so she turned off the breaker. The a/c is a old 1993 model York so its nearing the end of its days, on really hot days the a/c will trip the breaker.
                    I visually checked the cap and contactor and they looked okay, I also pulled the 250v ac fuses and switched the main ac breaker on and got no buzz. I did get buzz when I put the ac 250v fuses back in and flipped on the breaker nothing but buzzing. could it be a shorted wire or did the circuit breaker just finally give up the ghost?...
                    09-05-2020, 07:53 PM
                  • Francesc V.
                    Technics SA-AX530 in protected mode. Overload message
                    by Francesc V.
                    I got a request from a friend of mine to have a look to his amplifier. When switching on "OVERLOAD" was displaying, however from time to time, message disappears and protection was removed.
                    I took some time in visual inspection (no bold caps, no solder joins, no burnt components neither hot burnt areas). I took some time to measure transistors and diodes. Everything seemed ok.
                    I realized that when OVERLOAD was on, pin 13 on IC601 (RSN307M44A-P) measured 5V. From time to time, when Amplifier was not protected pin 13 measured the right -1.5V
                    (Pin 13 goes through...
                    11-18-2024, 12:39 AM
