smd cap approx 5mm x 6mm high, markings 95TA, 47, 16v, is this 47uF 16v? Its been broken off a mobo when the owner tried to fit a graphics card. Ordering a single unit in the uk may be difficult but I've managed to find a cap on a graphics card with the markings 24, 47, 6A possibly 1mm higher but the same diameter could this be used?
Identify smd cap value
Re: Identify smd cap value
http://search.digikey.com/scripts/Dk...=565-2537-1-ND
Plastic base is: 5.3mm x 5.3mm
Cap is: 5mm x 5.8mm
Minimum 5 pcs = $3.32
ESR: 0.7Ω Ripple: 160mA
These are more for noise filtering & trace length compensation than power filtering.veritas odium paritComment
Although a slightly bigger case width, is this cap suitable?
http://cpc.farnell.com/jsp/search/pr...sp?sku=CA05545
Digikey shipping is pretty expensive to uk.Comment
>>Digikey shipping is pretty expensive to uk.<<
And exactly how would I know where you are located?
Location box in profile......?
RS Online has a better selection.
Either is fine, in order of my preference:
http://uk.rs-online.com/web/search/s...duct&R=0568474
http://uk.rs-online.com/web/search/s...duct&R=5370461veritas odium paritComment
Another one fr the masters if you have the time
What are the values of the caps missing off this board?
8 Around the CPU and one little on near AGP slot
While youre looking can you tell me whats wrong with the board?
939 DualCore AMD Opteron, 1800 MHz (9 x 200)
Abit AN8 / Fatal1ty AN8 SLI Series
3072 MB (PC3200 DDR SDRAM)
ATI Radeon HD 4300/4500 Series (1024 MB
Lian LI Aluminium mesh caseComment
by StuntHi i need somebody to help me identify this chip the markings is AKLG 302. It's on Hp Pavilion 14-am 245 G5 6050A2823301-MB-A02 motherboard
by digitalDNAHello,
I can't identify a component labeled Q1 on the main board of a redundant server PSU from Etasis, product name EFRP-465
ICs on the board have labels with prefixes U, so we have U1, U2, etc. The mysterious component is labeled Q1, so it must be a transistor (BJT)/MOSFET/etc.
I have attached the image for Q1.
I have searched multiple SMD reference websites without being able to identify the component.
Here is some important information from the board::
1. Pin 2 and the tab are connected to GND (after unsoldering Q1,...10-07-2022, 04:47 PM -
by BeertimenowHi is any1 know what component is it?
It is a LED driver or controller from Laptop screen.
Markings are "40=".
I've attached a photo if this ic.
Thanks... -
by Paxman_SwedeHello!
I have studied the board and...-
by Alfiehhey Im very new to repairing electronics with capacitors as well as using a multimeter so I need so help/guidance fixing this issue
recently I was handed a family members old NAD C320BEE that they had in their loft for storage for a few years but when powered on it went into power safety mode due to a problem on the protection circuit somewhere before it went into storage I was told it worked fine I found lots of people online talking about how the capasitors are known to be pretty bad in this model and can cause this issue the only problem being I don't have much experience sorting...-
- Loading...
