Cleaning up capacitor leakage
  • jj5
    • Jun 2022
    I'm doing some OGXbox refurbs and the clock capacitors (PowerStor Aerogel) notoriously leak all over the board. I'm not sure what you call the electrolytic fluid which comes out and gets all over the circuit board, but I would like to know the best process for cleaning it up. Should I hit it with vinegar or isopropyl? Or both? Or something else?
    • 31255
    Re: Cleaning up capacitor leakage
    just isoprpanol
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8340
      99% IPA or Acetone. Depending on how stubborn it is.
      • jj5
        • Jun 2022
        Okay, thanks!
          • 31255
          be carefull with acetone, you can take the markings off some parts with it
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8703
            Don't forget try clean water too...especially since failed capacitors tend to use aqueous (i.e. water) electrolytes and water will dissolve it once more.
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              I would recommend cleaning using acetic acid if it leaked on the board.
              Every time I do I can see bubbles and hear fizzing as I put it on the areas with leaked electrolyte, so it does a chemical reaction that much better removes it.
              Of course you need to clean very thoroughly after with IPA as acetic acid will otherwise do damage on its own...
              Here an example of it in action:
              https://www.badcaps.net/forum/showpo...1&postcount=34
              • MORETTIGIAN
                by MORETTIGIAN
                Title:
                Description:
                Procedure performed:
                - Removed backplate
                - Reapplied thermal compound
                - Reassembled card
                09-18-2025, 12:14 PM
              • Prolog
                by Prolog
                12-01-2024, 08:27 PM
              • Agent24
                Dick Smith Q-1760 linear power supply filter capacitor question
                by Agent24
                I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                It has at least one problem.
                The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                I have already ordered a replacement potentiometer, so that's not an issue.
                Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                All are CapXon...
                10-21-2025, 05:39 PM
              • chth96
                by chth96
                12-22-2023, 04:34 AM
              • chth96
                by chth96
                06-02-2024, 07:31 PM
