Which cap do i need to buy, please advise ?
  • rustinjust
    • Jun 2022
    • 49
    • England
    The cap thats blown says on it: 105kj450mff4, im here in the u.k so looking for a uk source online to purchase from, looking for decent quality but no too expensive. Please advise or link to a replacement cap if you can help, thanks.
    photo below
    • 31289
    Re: Which cap do i need to buy, please advise ?
    it's 1uF 450v polypropylene film i think
    whats it for/from?
    • rustinjust
      • Jun 2022
      • 49
      • England
      whats it for/from?
      Its from my 32inch lcd tv, the cap burst the other night while the tv was on and smoke came out of it with a plasticky smell. Im going to have a go at soldering on a new one, ive not attempted this before. Im hoping this with fix it. The tv was still working fine when the capacitor blew. I instantly unplugged the tv for safety reasons.
      Im assuming that replacing the cap may make my tv useable again ? Any good advice appreciated.
      Last edited by rustinjust; 06-08-2022, 08:54 AM. Reason: make adjustment to description
      • vinceroger69
        • Mar 2012
        • 6714
        whats it for/from?
        link for tv repair thread
        https://www.badcaps.net/forum/showth...38#post1139738
        • rustinjust
          • Jun 2022
          • 49
          • England
          Thanks, appreciated
          • prodigy83
            MacBook Pro M1 Pro Logic Board 820-02100 Mosfet where to purchase?
            by prodigy83
            My reference only: TT10141.
            Problem: I need to purchase a mosfet chip from board 820-02100 M1 Pro, that is supposed to be Q5820 but according to Digikey, the schematic diagram I sent them, neither are relevant to the actual mosfet specification I sent them. I just basically need to find this mosfet to purchase, I cannot find it anywhere and am hoping someone could point me in the right direction without have to purchase this entire allusive board. Already checked with Digikey, Mouser, Aliexpress, eBay. Any suggestions?
            Mosfet specs are as follows:
            Chip markings:...
            03-12-2024, 01:38 PM
          • Rickkap
            Xbox series x advise
            by Rickkap
            Hi
            I was hoping someone could give me some advise. A friend dropped off an Xbox Series X for repair—normally not something I deal with, but I'm helping out as a favour.
            Currently, the console powers on with a beep and then immediately powers off. On closer inspection, the HDMI port clearly needs replacing, and there's significant liquid damage/ missing components.
            Before I go down the rabbit hole of sourcing a donor board and replacing damaged components, I wanted to ask: based on the area I've marked in the photo, do you think this could be what's causing...
            06-08-2025, 08:50 AM
          • chth96
            what capacitor should I purchase for LCD display PCB?
            by chth96
            I want to fix Video door phone which works its doorbell but it is not able to display any screen.
            So I disassembled its plastic case and I detached FPC film cable from LCD display in order to inspect LCD display's PCB
            I measured ESR resistance of all smd capacitor on this PCB and I noticed that there is some SMD capacitor which has high ESR value(48ohm 50V 0.47uf,15 and 28 ohm 50v 3.3uf,10 and 8 ohm 35v 10uf)
            I desoldered this 5 suspicious SMD capacitor like below screenshot.
            images2.imgbox.com/51/b8/8WVZwDpV_o.jpg
            But I cannot identify specification of desoldered...
            05-24-2025, 09:25 PM
          • RossMoodley1967
            smd diode marked M7 on top and below K3 pls advise the equivalent. thank you
            by RossMoodley1967
            02-28-2024, 05:42 AM
          • chth96
            What capacitor should I purchase for Power Supply of obsolete game consoles?
            by chth96
            hello.
            I have Sega Saturn and 5 years ago, I recapped all of capacitor in the Power supply, Because At that time, It frequently freezed black screen after SEGA logo displayed.
            It hardly ever freezed after I finished to recap all of caps in the power supply.
            But Yesterday, It did not show any screen at all and its green power LED constantly blinked.
            To my surprise I found that all of two NXH 10v 2200uf capacitors in the secondary area of Power supply have been bulged and It measured 57 mF and 75 mF capacitance.
            It seems that quality...
            10-01-2024, 08:14 AM
