ESR 0.6Ω capacitance -15% absolute must change?
  • caprider
    • Jan 2022
    • 24
    I have one (of 3) hot swap Supermicro/Ablecom PWS-0050 SP382-TS server PSU that is mal functioning. Supermicro IPMI reports it as bad and led is orange on.
    I took it apart tested transistors, diodes, capacitor but haven't found the problem. I'm a beginner.
    In standby I have 5VSB, but not 12VSB, nor 3.3VSB. Here is the PSU Pinot: https://www.rcgroups.com/forums/show...Supply-Convert
    There are 3 x 400V, 100uF capacitors on the primary side.
    They measure:
    - capacitance 85-86 uF
    - ESR around 0.55 - 0.65 Ω (I've subtracted 0.15Ω that I measure when I connect my leads together)
    I know it's a good practice to change them. But could this explain the whole problem? Or these are workables ranges?
    Based on the physical dimension, the 3 caps are a bit expensive if not ordered from China. That's why I'm avoiding to quickly change them.
    What do you think?
  • PeteS in CA
    • Aug 2005
    • 3578
    • USA, Unsure of Planet
    Re: ESR 0.6Ω capacitance -15% absolute must change?
    That model is end-of-life.
    The capacitance is in spec, for +/-20% tolerance. I'm not sure the ESR you measured is abnormal for a 100uF, 400V electrolytic capacitor. It's hard to compare to catalog values, since companies don't seem to publish impedance values for higher voltage parts.
    When you apply power, what is the voltage across those capacitors? If it is much below 380V, the PFC stage (assuming it has active PFC) is not working.
    PeteS in CA
    • caprider
      • Jan 2022
      • 24
      I have 383VDC on the capacitors.
      And 242VAC on the bridge rectifier input (mains voltage).
        • 30952
        you will probably find the issue is a small - possibly surface mount electrolytic in flat compact psu's
        they are well built, but small caps never last
        • PeteS in CA
          • Aug 2005
          • 3578
          So the PFC appears to be working. That plus the 5VSB means your auxiliary regulator is working.
          Do you have that 383V at the inverter MOSFET Drain? If not, you may have an open fuse between the PFC and the inverter. If you do have an open fuse, you may have one or more shorted inverter MOSFETs.
          Does the controller for the Inverter have Vcc? Do you have the IC part number? Is it on the primary or secondary side?
          Does the PWS have 12V and 3.3V Standby outputs? Or simply a 5VSB output with 12V, 5V, and 3.3V main outputs? I suspect it's the latter.
          PeteS in CA
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            All of my Ablecom/Supermicro Hot swaps setups (which I'm pretty sure is the same standard as his) are just a 5VSB and (if memeory serves) a single massive 12V main rail. The hot swap "bridge" steps down (buck converters?) the 5V/3.3V rails for motherboard and drive use. ATX12VO before ATX12VO was a thing.
            sigpic
            (Insert witty quote here)
            • PeteS in CA
              • Aug 2005
              • 3578
              I should have done this earlier ... here's a pic of one of the 3 modules in a PWS-0050:
              It has, as I suggested above, a 5VSB output plus 12V, 5V, and 3.3V main outputs. Also as I posted above, the model is end-of-life, apparently quite a few years ago. You are correct, though, in saying that more modern Supermicro server power supplies are 5VSB or 12VSB and a very high current 12V output.
              PeteS in CA
              • caprider
                • Jan 2022
                • 24
                Useful questions, thank you. I will dig more for the answers.
                Looking for the IC that does PWM I found several op Amps and a PIC.
                Is it possible that this PIC is actually performing the PWM: PIC16F819?
                Everything is pretty dense with a secondary vertical board with PIC and OP AMPS. I'll have to take down again 3 heat syncs with MOSFETs and double diodes to track pins and see if I missed another IC. Almost all components are covered by the 3 T-section shaped heat syncs.
                I'm bringing in today another working PSU (same model) to see if it actually has 12VSB and 3.3VSB (the bad one does not). I also now have a 12V 21W light bulb and test the PSU under load, since it may not output voltages because of zero load.
                I assumed this is EOL and I can probably find an alternative replacement. I'm just using this repair project as learning experience.
                • caprider
                  • Jan 2022
                  • 24
                  After comparing with a good PSU. I see that the bad one is not starting (when connecting PSON and PSKILL to ground). The good one starts the fan, LED turns green and all output voltages are there, without needing a load.
                  In stand by I have several different voltages on output PINs:
                  PIN / good PSU / bad PSU
                  PSON 4.9V 7.9V (and bad one varies a bit)
                  PSKILL 4.9V 7.9V (bad one varies)
                  SB5 0.4V 3.3V varies up to 22V
                  A1 0.5V 1.6V
                  A0 0.6V 1.6V
                  I do have 5V on PIN +5VSB on both good and bad power supply.
                  One bad one is started (pins PSON and PSKILL to ground) LED remains orange, fan does not start, seems to do nothing.
                  Looks like an issue on the stand by power supply.
                  Any hints would be appreciated.
                  • PeteS in CA
                    • Aug 2005
                    • 3578
                    As best I can tell, the PIC16F819 is a general purpose microcontroller, https://cdn.badcaps-static.com/pdfs/...f215a009d4.pdf . Perhaps it is being used as a supervisor.
                    Your 5VSB is working. The problem is in whatever circuit enables the main inverter, its controller, or in the main inverter itself. Since I lack a schematic, I suggest tracing the enable signal path to find where it stops working or there is some other circuit keeping the inverter disabled.
                    I suggest making a list of the ICs' part numbers in the P/S and seeing what each IC is. For example, an LM339 is a quad comparator and an LM358 is a dual op-amp.
                    PeteS in CA
                    • markenero3
                      HELP Dell Precision 3480 Bios Password with absolute enabled
                      by markenero3
                      Good Day Everyone please help! I have Dell precision 3480 13th gen with Bios password and absolute enable. I already tried 8FC8 Patcher it works but the absolute still cannot be disabled
                      Here is my Orig bios file with Bios password and Absolute Enabled
                      Board: IDB40 LA-M402P
                      Service Tag : HFZW724
                      Thank you So much in advance....
                      02-20-2025, 11:23 AM
                    • Verlengsnoer
                      Bios splash/logo change
                      by Verlengsnoer
                      at firs, i hope this is the right place to post my question.
                      Im looking for a tool to change the bios logo.
                      everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
                      i know that HP has a build in option to change the splash logo.
                      but i want to change the manufacturer logo to an own logo.
                      I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
                      10-28-2022, 09:52 AM
                    • rustinjust
                      Advice needed-Technika 32-207 works but sticks on channel,won’t change channels ok
                      by rustinjust
                      My tv will work for a while and change channels with the remote as it should but then it will stick on one channel only and work ok but it won't change channels. I have tried unplugging it for hours and whilst unplugged pressing the power button on the tv to reset it.
                      The volume button on the remote still works but it just won't change channels once it decides to stick on one channel
                      It has built in basic freeview tv here in the uk, I've tried doing an automatic search to reset the tv but nothing works.
                      I have to turn the tv off and then on again with...
                      09-28-2023, 12:23 PM
                    • Junkrepair
                      Calculating ESR from tan delta -- tan delta's dependence on capacitance
                      by Junkrepair
                      I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
                      I found this nice little description of the conversion:
                      Calculating capacitor ESR from Tan(delta)
                      https://forum.digikey.com/t/calculat...-from-tan/2633
                      It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
                      06-12-2023, 02:45 PM
                    • Topcat
                      Topcat's Supermicro X10DAI Build - Plus NVMe BIOS Mod Inside
                      by Topcat
                      Yes, I know I don't post this stuff much anymore....the only reason I'm posting this one is because of a NVMe adapter incompatibility; seems rather planned by Supermicro.....or I'm atleast a bit suspicious. It's plenty new enough to have a UEFI bios but a short 'happy list' of NVMe controllers that will work with this board, as if by some 'miracle', all Intel....so lets start at the beginning; we'll get back to this later.
                      Of course the motherboard is as the thread title states; X10dai....but we'lre going to have some fun shoehorning this into a modern 'gamer case' that can actually...
                      09-29-2024, 03:55 PM
